My experience with 2013 Plug-in prius
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Valjean, Mar 29, 2016.
  1. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    He said the Bolt EV would be able to get 300 and that seems quite doable. I got 57 miles on my EPA 35 rated 2011 Volt a number of times while driving around doing normal errands and commuting much less on a controlled track. Ideal in an EV is usually around 15-20 mph with constant speed and no stopping. True ideal driving gets you nearly 2x the EPA estimate so 300 miles in a Bolt is "easy". The only problem is staying awake while you drive 20 mph for 15 hours. If you go 26 mph you can set cruise control. Need AutoPilot!
  2. Topp Cat
    Topp Cat Member
    71
    66
    We drove from S.F. To south San Jose was 54 miles and still had 7 miles of EV in the volt , S. F. To Gilroy in our 2014 Corvette fill and refuel at same gas station 157 miles on 3.8 gal that over 41 mpg real life experience! Well that put me better that the Best of the Best then!!!
  3. hill
    9,039
    post #18. He says 2014 volt, and that's the basis of my comment.
    No disagreement re what he said - we can get horrible efficiency via horrible circumstances & great via great conditions. Plus or minus for driver's skill.
  4. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    The reference to getting 300 miles in post #18 was to the Bolt EV:
  5. bisco
    52,863
    can you explain the first sentence? i have never gotten 5 miles, no matter the conditions.
  6. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    As a PIP owner who regularly only gets about 9 miles of EV, and who has complained before about the engine coming on so easily (heat, a/c, the slightest extra nudge on the accelerator), I'm somewhat sympathetic to OP's complaints. Less than 6 miles seems pretty unusual though. However, I have noticed that jumping onto a Houston freeway with EV on at 65 to 75 mph will rather quickly deplete the battery. Haven't bothered to test how quickly (or how far it goes), since I generally turn EV off when I'm doing that.
  7. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I think Bisco got it already. OP's numbers on the opening post suggests 10 miles EV per charge.
  8. bisco
    52,863
    while i think the o/p's concern is normal, his lack of communication makes it difficult to sort things out. but sometimes an internet rant just makes us feel better, and we can move on with life.
  9. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Some seek out a venue to vent frustration from not having studied well before purchasing. Some make an abrupt discovery upon joining about something they had overlooked. Some post for the sake of exchanging information and learning more.
    We see all kinds here. It serves as validation of Prius reaching a diverse range of people.
    DonDNH likes this.
