My experience with the P0A93 alarm.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gen2shenanigans, Aug 18, 2025.
  1. gen2shenanigans
    gen2shenanigans New Member
    Hello, fellow Prius people and P0A93 alarm enthusiasts. There is a TL;DR at the end.
    I have a 2007 Toyota Prius, 163K miles. I have had this car since 2012 and began experiencing the dreaded combination meter issue in 2014-ish. However, it wasn't until 2016-2017 that the issue became more problematic but was "solved" by our trusty unplugging of the 12V. That worked until the beginning of this summer, where the issue was permanent - as in, dashie no workie. I took it apart and replaced the capacitor. Yay! The car has been working great... until August 1st.
    On August 1st I got a master warning light (red triangle), malfunction indicator lamp (check engine), and brake system warning lights (yellow). I drove it home, approximately 20 minutes drive. I checked my brake fluid level, it was fine. I unplugged my 12V to see if the issue would resolve and it did not save the brake system warning lights. I reached out to my brother, as he had an OBD2 reader. No codes were shown, which is not shocking as I deleted them when I unplugged the 12V.
    My brother thought we should check my oil and it was below the low mark (we replaced it). In the end, we used the entire bottle, which I found odd - however, it does appear the Gen 2 Prius likes to burn oil as it ages. I did not have any issues for several more days until I was driving over 50 mph. All of the lights returned... so this time I bought my own OBD2 reader and I got the aforementioned alarm code. I found PriusChat forums on the topic and checked for turbulent flow... well, I see it moving around in there so Wth? I found the level to be below the low mark, though... without any evidence of an obvious leak. So I bought some of the good "Toyota Super Long Life Coolant" pink drink and topped her up. She drove like a beaut, AC blasting and none of the previous "mugginess" blowing through. Oh, yeah, I forgot the mention that a month or two prior there was this intermittent issue with my AC feeling "muggy." I chalked it up to an aging car and the scorched heat (well over 100 F most of the days).
    I should mention that I bought an OEM replacement inverter pump from Toyota when I bought the pink drink. What can I say, I like the hedge my bets. I was driving back to Toyota today to return the >$250 dollar part (yeah, you read that correctly). Guess what, it all comes back! I promptly got off the highway and took the next safest option home all-the-while waiting for the fuse to blow and the car to die - I read this can happen? Then the "mugginess" returned to the AC, I pulled over and thought about my options again. It wasn't a safe area, so I idiotically bet on getting it home. But first, I checked the alarm... guess what, P0A93. Wth? I looked in the reservoir, it was still full of that pink drink. I reset the alarm and finishing driving it home. No other alarms but the mugginess was still present on the AC.
    When this alarm occurs, I feel a slight decrease in power - it's the best way to describe it. The Cruise Control also stops functioning. I believe the Cruise Control stops functioning as a safeguard - but please correct me if I am wrong. At no point did I have any other indication that something was going wrong. The pedals did not feel odd, there was no odors, there was no issue braking.
    So... my idea is that I have an intermittently failing inverter pump that I can't consistently replicate an alarm for. I still see turbulent flow. I am torn on taking this $250 part of the box and replacing it, just for the issues to persist. So if anybody has any other thoughts before Wednesday let me know! As far as I know, this is the original inverter pump. I haven't been the best at keeping records and doing personal maintenance, but after being screwed on a bad battery from the dealership I have taken the steps to be a good father for my Prius. I was just a stupid kid, forgive me!
    P.S.: My brother said I should bleed the coolant, but I hear that's a pain in this nice person and I could introduce air. The level was low, but not low enough that I could see any bare "tank." Surely this isn't a pesky air bubble causing this alarm at high demand times on the car?
    TL;DR: I think my inverter pump is intermittently failing at high demand times (>50 mph and AC). There is still turbulent flow when I look after the car has cooled. The level was low, so I topped it up. It worked fine afterwards... for a couple days, even with driving it on "high demand" and no recurrence of P0A93 alarm. Went to return the inverter pump, but it all happened again. The level has not decreased since and there are no obvious signs of a leak. I guess I'll just replace the inverter pump?
  2. JC91006
    16,931
    8,640
    enough with the gen2shenanigans, just replace the pump. they don't last forever and average only 100k miles
  3. gen2shenanigans
    Aye, aye! I will report back with results.
  4. ChapmanF
    18,946
    P0A93 tells you the inverter/transaxle cooling system isn't cooling well enough, things getting too hot.
    It doesn't tell you that's because of the pump or not. One way people often make issues take longer to solve is when they start by assuming a code tells more than it does.
    It's up to a human to figure out whether the overheating is because of an intermittent pump problem, or because of a fans problem, or an occluded passages problem, or whatever.
    If your scan tool is good enough to show INF subcodes, some Prius generations give an INF code with P0A93 that gives an opinion from the car on whether the pump or the fans might be more likely at fault. I don't happen to remember if gen 2 is one of those, and don't have that manual readily at hand just now.
  5. gen2shenanigans
    Thank you for your response. This is part of my conundrum with taking out the inverter pump and replacing it with this new one, although it sounds like this part inevitably fails. Mine is definitely not that good, and without a way to reliably replicate this code I don't know if I could safely get it to my brother's to see if his can provide a sub-code. When I went out today after it cooled, I didn't see much turbulent flow when I turned the car on. It definitely seems more diminished than prior? But again, I can't tell if I am just seeing something that was never there or there is definitely no turbulent flow now.
    I feel a bit boxed into changing out this part, but I suppose I'd rather change it myself and THEN take it to a mechanic if I still have issues. It strikes me odd that I can't seem to replicate this alarm. But I'm nervous to make a bigger issue by pushing my inverter to the brink.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,996
    930
    Southern California
    Which pump is in there now? I had a Dorman briefly. It worked great, except on those trips where it just decided not to start. Intermittent failures are the worst, you keep testing the part and it works every time it is tested, then it fails in normal use when you aren't looking. Replaced it with an OEM pump and the problem went away permanently. If the inverter pump has not been changed since 2012 it is due for a failure, or more like way past due if you drive a typical number of miles per year. A fan failure can generate the same code, but you can test that those run by turning on the A/C on a hot day and leaving the car in park. When the loud noise up front starts go check (carefully!) that both fans are spinning.
    Bleeding the ICE loop(s) is a pain, but bleeding the inverter loop is trivial. You just run a little piece of clear tube from the bleed valve for this loop over to the top of the tank next to the inverter, turn the car on, and open the bleed valve. When bubbles stop coming through the tube for a couple of minutes tighten the bleed valve and clean up. And I do mean clean up. Be sure to wipe/wash any coolant off the bleed valve. It dries to pink crystals and if it isn't pristine you won't be able to tell later when you see pink crystals if there is a small leak there.
  7. gen2shenanigans
    I am not sure, I believe it is the OEM inverter pump. I have yet to remove the part and examine it. As for checking the fan, I just went out there and I am having a difficult time visualizing it. Any tricks on how to view those safely?
  8. pasadena_commut
    2,996
    930
    Southern California
    With the car off find an angle where a flashlight will clearly illuminate some of the blades for each fan. This is easier in the shade than in direct sunlight. Start up the car and turn on the A/C set to max cold. The fans should start pretty soon if it is a hot day. You should hear them start from within the cabin - they are not quiet. Then go out and look again with the flashlight from those predetermined angles. If you see the blades just sitting there that fan, or the circuit powering it, is broken. What you should see is either a blur or nothing.
