My Extended Test Drive... Need help!
Discussion in 'Gen 3 Prius Main Forum' started by Zanrok, Jan 16, 2012.
  1. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Typo fixed.
  2. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    As to the seat, leather ain't gonna help, so save your money.
    First off, did you read your manual with regard to the seat adjustments? Did you try playing with the seat height adjustment? I found that quite helpful to try different seat heights in order to find the right one.
    Secondly, lumbar pillows and other seat cushions are available at well under $50. Check at Walmart, Target, Pep Boys, etc., as well as at your Toyota dealership parts dept..
    As to the steering wheel, there is no help for the wheel positioning. You will just have to find the position that suits you best.
    One more thing I found that really helped was a slip-on steering wheel cover that had some padding. This allowed an easier grip on the wheel. - otherwise the steering wheel felt like a thin twig, covered with sandpaper.
    After driving my Prius for 20,000 miles, I must admit that I still have misgivings, and often feel that I should have given up some of the mileage for a greater degree of comfort [The Japanese still do not make many of their cars to fit European-size human beings.]
    ... but the mileage is GREAT!
  3. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    In regards to the seat and arm comfort while driving.....
    Is this something that would impact your daily driving, or more for extended driving? In other words, if you work and your daily commute is 15 - 20 minutes, would the seats and arm rests be an issue?
    In other words, if the complaints you had were for 1 - 5% of your driving experience/time and the car is comfortable for the remainder, you can work around the times when the car is lacking in comfort.
    I don't care for where the arm rest is on the door (too low), I think I get around it by not having my hands at "10 and 2" and instead using the hand holds in the lower steering wheel. I don't always keep them them (I try to do 10 and 2) but will revert if my shoulders start to hurt and/or I need to rest my arms.
  4. Zanrok
    Zanrok Casual Prius Lover
    181
    30
    Reno, NV
    You bring up a really good point Cody, and that's something my friends brought up as well. I mean okay I might have to adjust how i hold the steering wheel, for long trips ill bring a pillow, but everyday driving I think Ill be just fine.
    At this point in time I think ill be looking for a 2012 model 2 in the next few weeks. =)
    @Teak, its good to hear I am not the only one. hehe
    Thanks for advice everyone.
  5. Tideland Prius
    16,658
    Note that the height adjustment on the seat is not straight vertical adjustment. The seat is hinged in the front so raising the seat tilts the seat bottom forward. Also, I found that lowering the seat such that my arm can rest on the door armrest helps (I prefer to sit up higher until my head is just under the ceiling but then I can't rest my elbow on the armrest so I have to lower the seat).
