My finger sensors stoped working, i can't lock the car
Discussion in 'Gen 3 Prius Technical Discussion' started by Galusca Gabriel, Apr 22, 2022.
Tags:
  1. Galusca Gabriel
    Galusca Gabriel New Member
    Romania
    Hi prius owners! i have a gen3 2010 prius that won't lock the doors anymore when i touch the finger sensors on the door handle, nether the top or the bottom sensor won't lock the car, on the passager door it does the same thing, i tried with the second key or changeing the key battery, but no luck so far, is there a fuse that can be blown? it's wierd because i can unlock the car by grabbing the handle but i can't lock it with the finger...
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Did you try the pinch method by touching both top and bottom? That's my default method now as cold weather decreases the effectiveness of the sensor.
    Galusca Gabriel likes this.
  3. Galusca Gabriel
    Romania
    sure, that was the first thing i did, but no luck..
  4. fuzzy1
    10,272
    Does the "lock" button on the key fob still work?
  5. Galusca Gabriel
    Romania
    yes, the button on the key fob works just fine
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    Given that, on a 12 year old car, I don't think I would worry about it......too much or at all.
    Other things likely will be failing soon too and some of them WAY more important.
  7. vvillovv
    vvillovv Senior Member
    3,772
    1,319
    NY
    did you do the 4 doors lock unlock, than back to the one door unlock switcharoo a few times and still no joy?
    The instructions for the 2010 say to hold all 3 buttons on the fob 5-10 seconds to make the switch in both directions from 1 door to 4 doors and back again.
    Of see if the repair manual can help you track down the what's going on.
    #7 vvillovv, Apr 23, 2022
    Montgomery likes this.
  8. Galusca Gabriel
    Romania
    this trick does not work on my prius, i tried it with both keys and nothing happends
  9. vvillovv
    3,772
    1,319
    NY
    So what's it set at now driver door unlock or all 4 doors unlock when you use the fob?
  10. Galusca Gabriel
    Romania
    all 4 doors unlock from the key fob
  11. vvillovv
    3,772
    1,319
    NY
    Is there any response form the lock actuator when trying to use the handle sensors?
    Have you tried taking off the inside door panel and pulling the electrical connectors yet? to begin diagnostics
    Or finding the door handle part #? for possible clues of it's operation
    #11 vvillovv, Apr 25, 2022
