My first 60MPG+ tank and also My first 700 mile tank
Discussion in 'Gen 2 Prius Fuel Economy' started by sandman, Aug 19, 2008.
  1. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Previous tank: 500 mi, 55.6 mpg; fill-up: 9.00 g
    Long tank: 785 mi, 98.1 mpg; fill-up: 8.00 g
    next tank: 220 mi, 36.7 mpg; fill-up: 6.00
    current tank: 425 mi; 50 mpg; fill-up: 8.5 g
    Cumulative mpg (34,205 mi): 50.81 mpg
    I drove from Fresno, via Hwy 41, in the Great Central Valley through Yosemite Natl Park (Hwy 120) to Lee Vining (Hwy 395, fill-up tank) to south of the Mammoth Lakes Airport. I rode the High Sierra Fall Century, then did the return trip back to Fresno. The good fuel economy is optimum P&G and lots of gliding down the western slope of the Sierra Nevada (at speeds 40 to 65 mph). This 2007 Prius does not seem to get as good of fuel economy on the level as my 2005 Prius. Nevertheless, the vehicle and I keep getting better.
  2. sandman
    sandman Member
    277
    32
    kentucky
    Thats impressive..Way to go ..
    Thats the biggest MPG swing from one tank to the next, I have ever seen,,:)
  3. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    Awesome mpg's, congratulations! (I guess I spend too much time running the a/c sitting in the Hardee's parking lot eating burgers:)
  4. nooaah
    nooaah New Member
    380
    Philadelphia
    If the tank capacity is only 9.something gallons, how are you getting 700 miles?
  5. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    First of all, the tank capacity is not limited to 9.* gallons. I have 12 tanks in my logs that are over 9 gallons(9.220, 9.29., 9.301, 9.500, 9.565, 9.600), 1 tank above 10 gallons(10.880), 1 tank above 11 gallons(11.300), and 4 tanks above 12 gallons(12.051, 12.162, 12.400, 12.400). I do have to note that only 1 tank has taken more than 9 gallons in a winter month and that was 9.565 on 12/20/08. I know that someone will be quick to point out that I'm only 1 case but, I have heard from Fire Engineer that a Prius bladder can hold over 13 gallons. I've said it many times before but, I have stuffed my tank everytime during the car's 23K+ lifetime without any negative results of any kind.
    Also, if you can keep your mpg up high enough, 700 miles is not a really long distance for a tank. I recently had a tank of 867.4 miles and used 8.580 gallons. Please don't take that as bragging; I only report it to show what is possible when a Prius is driven for max efficiency. I just don't want to see anyone leave anything on the table when it comes to what our awesome cars are capable of.
  6. sandman
    sandman Member
    277
    32
    kentucky
    The prius actually has a 11.9 gallon tank, but with the bladder sometimes you cant get that much in it, but sometimes you can..:)
  7. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Nice job sandman.
  8. diamondlarry
    559
    Elkhart, IN
    Sandman, I feel bad that I started commenting on other stuff and neglected to congratulate you first.:redface: Congrats on the 60+ tank! There aren't too many that have done this and I know the effort that went into it.
  9. nooaah
    nooaah New Member
    380
    Philadelphia
    Well, I'm down to 3 pips after 330 miles and I'm supposedly getting 52mpg. Should I fill it up soon or just go to 400 no matter what it says?
  10. sandman
    sandman Member
    277
    32
    kentucky
    When last pip starts blinking get gas immediately!!!
    No problem Larry,, I have actually had 8 tanks in a row over 60MPG..Once I got that P&G method down pat, and my Scangauge, its much easier to obtain..:)
  11. jackblack99
    jackblack99 New Member
    60mpg huh? i was happy when i hit 20!!
  12. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Assuming for the moment that you're not one of the trolls that just signed up let me inform you that you've been the victim of some serious misinformation.
    The batteries are not hazardous to the environment and are 100% recycleable.
    I'm sure you've heard much other misinformation as well. If you're interested most/many of these have been addressed and rebutted:
    http://priuschat.com/forums/prius-main-forum/26050-prius-myths-their-rebuttals.html
  13. 60psi
    60psi New Member
    don't steal my fun from me!
  14. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    The last several posts have been reported to mods.
  15. efusco
    19,891
    1,196
    Nixa, MO
    Thanks, deleted/banned. Keep reporting as you see others....it's like shooting fish in a barrel.
  16. nooaah
    nooaah New Member
    380
    Philadelphia
    I understand that much, it's just getting annoying. When should I fill my tank? After I've been driving for awhile or when it's cold? I'd assume if I'm riding for awhile, it will get warmer and the bladder will expand.
    I just don't understand how I'm at 345 miles on this tank now, down to 51.8mpg, 2 pips left.
    Maybe I should just fill it now anyway and try to see how I'm doing with my tires at 40/38 (I had 32/30 up until Saturday).
  17. PaulHS
    PaulHS Member
    200
    SE PA
    I'm not going to give advice but only describe the things that have helped me. First, I start thinking about filling when PHriuS reads two pips. I try to fill on a hot day, in mid-afternoon, figuring that the resin bladder will be most pliable at that time. Second, I get my gas at the same station every time, and I try to face the car slightly uphill at the pump. Third, I pump at high speed til I've pumped about 5 or 6 gallons, (the theory is to expand the bladder) then pump slow til she clicks off.
    Since I started this technique, my average fill-up has gone from 7.5 gallons to 10+ gallons. It works for me.
  18. rsacker
    rsacker Junior Member
    Los Angeles
    Can anyone make sense out of the "Consumption" panel with the little bars that pop up every 5 minutes? After 5 miles I get a bar that says, let's say 30 mpg, with 1 1/2 little green cars in it (50 watt hours regenerated each). Then after 5 more minutes a second bar pops up AND the first bar gets a little longer and loses the 1/2 green car. In short, the bars keep updating with green cars coming and going, until of course, the first bar is scrolled off the screen or my trip ends. What is going on??????
  19. sandman
    sandman Member
    277
    32
    kentucky
    This tells you what your MPG's where each 5 minutes..Depending on what you average each 5 min. determines how tall each bar will be..The little green cars tell you how much energy you generated through coasting and braking. This is how the Prius takes motion that is usually wasted and uses it to charge its battery ..Hope this helps make some sense out of it..:)
  20. nooaah
    nooaah New Member
    380
    Philadelphia
    I actually didn't know that haha. Thanks.
