My first ever Prius and first ever Toyota. First maintenance task: Spark plugs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by VFerdman, Jul 18, 2017.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Thanks for the coolant info, @edthefox5. I was all set to change it in my wife's '07 with 118k miles. It still looked nice and pink, but it was due. I happened to mention it to our mutual friend, Todd, and he said that if it still looks nice & pink, don't bother. Now you're making me have second thoughts. Or is it third thoughts, now? Now I need to run my own test. LOL! But will need to let the bank account catch its breath for a bit.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    You think it's nice and pink. If you need convincing Take some out of the reservoir and put it in a glass in the sun and look through it and you'll see how loaded it is with aluminum. It's like anything other fluid or oil in a new car. Change it all around 10,000 miles and your good for the life of the car. It's that initial break in wear that does the most harm. Inverter coolant is cheap and easy to replace only hardship is getting to the dump bolt which is why I do the trans and the inverter fluid and the ac microbial cleaning when the car is up high in the air.
  3. VFerdman
    VFerdman Senior Member
    1,186
    1,215
    Western Massachusetts
    Please fill me in here. Are there separate coolants for engine, inverter? Does ATF go through the radiator like it does on most convetional automatic cars? I think my coolant was changed at some point (I need to look at my records), but I will replace it if it's been too long. Even if I do not get +5 mph. I believe coolants and lubricants are important to refresh in cars. But there is a fine line between changing those things in good intervals and over-maintaining. I am very much NOT and over-maintainer. I think newer cars are all designed with longer intervals and the lubricants and coolants have gotten so much better over the years as to validate the longer maintenance intervals. I think 30K miles for a ATF is a bit too soon, but checking it at those intervals is valid. Same for the coolant. ATF will become black in probably less than 1K miles because of the detergents, so there needs to be a better test than color. Coolant I am not sure. I would just replace it at Toyota's recommendation (which is what?)
  4. Mendel Leisk
    41,464
    My personal preference: change coolant at the Toyota spec'd intervals, either miles (kms) or months, whichever comes first.
    There are two separate circuits, engine and inverter, with separate radiators.
    In Canada the first change interval for both is 160K km (roughly 100K miles) or 120 months, for both circuits.
    In the United States the first change interval is 100K miles or 120 months for engine circuit, and 150K miles or 180 months for the inverter circuit.
    I believe for all of the above intervals, subsequent changes are 80K kms (50K miles) or 60 months.
  5. edthefox5
    10,096
    4,833
    Clearwater, Florida
    2 separate coolant loops. In separate cells inside one radiator.
    Engine coolant standard system through top cell of rad.
    Inverter coolant which is circulated through the inverter electronics heat sink then through a substantial circuit in the transmission then through the bottom cell in the rad. The Inverter coolant dump bolt is in
    bottom of the trans right next to the Trans ATF dump bolt.
    In the G3 they went to a separate cell for both rad & Inverter coolant. Much better cooling.
    They need it becasue the mg's are much smaller and higher torque than the g2's.
    Both loops in G2 use Toyota LLC Coolant. Red stuff.
    ATF in G2 and G3 is not circulated for cooling into the bottom of the rad like most cars.
    There is no detergents in trans fluid.
  6. VFerdman
    1,186
    1,215
    Thank you. That is good information. So there is a separate water pump for the inverter? I have a receipt from PO that states a water pump replacement. Which one? no idea. Also, when replacing the water pump I would think corresponding coolant was replaced. But no charge ro that, so I am assuming it was not changed.
    Is Toyota LLC coolant special? I know Volvo coolant is pretty expensive (around $30/gallon) and I stuck with that because of all the aluminum it runs through. I assume Toyota is similar.
    I am very surprised that ATF for Toyota lacks detergents. Most ATFs have them. As do most motor oils. They turn black almost as soon as they are used for a few thousand miles. Does not mean they are worn necessarily. Worn ATF in conventional cars tends to smell burnt (way worn and past due). since I know ATF was not replaced yet on my car I will do it ASAP (in thenext few days). Is there anything I need to know about it? I know I need a crush washer and some fluid, level the car for drainage, etc. It would be really useful for me to be shown where the drain plug is (preferably in pictures). I have never been under a Prius :)
    Also, is there a Toyota recommended interval for inverter coolant replacement? Sorry for all the newbie questions, but I am a newbie to Prius.
  7. Mendel Leisk
    41,464
    Look in your in your Owner's Manual regarding the coolant (you can download a pdf version from Tech Info if it's missing), and you'll see they spec a specific Toyota Coolant, and say or equivalent, as long as it's ... , and from here on they go into a lot of technical jargon, overhead my head, so I just go with the Toyota spec.
    Look in the Warranty and Maintenance Booklet (same story if it's missing), the coolant change intervals are spelled out there.
    I posted third gen intervals above, in post #24 (forgot where I was, lol), it might be sim though.
  8. jerrymildred
    11,517
    14,152
    Tampa, FL
    I used these pictures. Hope it helps. It wasn't perfectly clear, but not too hard to cipher out.
    Toyota Prius: How to Change the Transmission/Transaxle Fluid - PriusDIY.com
    VFerdman likes this.
  9. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Again transmission fluid does not have detergent in it. I know of no trans fluid that has detergent in it. Most modern trans fluid touts long life never change. Last thing you need there is detergent. I run Redline D6 pure esther base stock. No nothing in it.
    Never seen new trans fluid turn black in a 1000 miles. Thats one f'ed up trans.
    New crush washer is nice but the washer on the G2 trans is solid aluminum and really shows no crush. I have changed my trans fluid 3 times so far on the same washer.
    #29 edthefox5, Jul 20, 2017
  10. VFerdman
    1,186
    1,215
    Okay, maybe I am confused, but most ATF I put into transmissions go in red in color and when you check them in a few K miles they are black with maybe a hint of red tint. Prius may be different because it is a very different transmission in principle.
    I have reused solid aluminum washers many times myself Aluminum does not work harden so much, so it can be done. The other type of crush washer is copper tube type. Those crush once and that's it. Copper work hardens pretty quickly and becomes brittle, but I still have reused those copper ones a few times. Does the fill plug have a washer? If so, also aluminum?
    Thanks!
  11. edthefox5
    10,096
    4,833
    Clearwater, Florida
    What car turned brand new trans fluid black in few thousand miles? Never seen that. Thats a pretty worn out trans.
    Bro start using the search feature with basic questions. You need alot of reading. If you need to dig into the car real deep you can rent a one or 3 day subscription to the factory service manual on toyotatechinfo.com.
    Buy a sub last time I looked its like $10 a day and get your printer ready and have at it.
  12. VFerdman
    1,186
    1,215
    I just changed the trans fluid. According to the PO it was never changed in 175K miles. It honestly did not look that bad. It did not smell burned, it was not black. It was dark red, like a very dark red wine. This was also a pretty simple task. One thing I have to ask is this. How do you know if your car is level as far as trans fluid level check is concerned? I mean do you take a level to it? If so, where? My driveway is not super level, but I chose the most level part to do the job, so I am just going with that. How do others do it? Just eye ball it?
  13. Mendel Leisk
    41,464
    I put a level on the pinch weld running under the doors. Side to side I just assume is level: I'm on a garage slab.
    Method: raise front with floor jack and settle onto jack stands. Then raise rear, going a little too far (checking with aforesead level), settle onto more jack stands.
  14. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Not true AT ALL. In point of fact, due to it's comparatively high detergent levels, ATF has L..O..N..G been used to free sticking hydraulic lifters in old engines. Even machinists use it for cleaning, it lubes well too!
    Due to modern synthetics and material science, I do not believe the levels of detergent are nearly as high today as back in the '70s for example (Type F and Dexron come to mind ;) ).
    ATF also does a wonderful job of removing varnish deposits from the guts of the engine in the "new" car you just bought :)
    I have ZERO data on the Toyota WS fluids, but given they are used in most Toyota products, see no reason they would be detergent free, as no other ATF is.
    johnnyb588 likes this.
  15. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    Raytheeagle likes this.
  16. 05PreeUs
    1,097
    564
    MSP
    Given that the "transmission" in a Prius is not a transmission at all, in the traditional sense, it has no sliding gears, no clutches, no valves or control parts.... your findings are normal. The only thing the fluid does is provide lubrication and some cooling to the MG bearings and final gears.
    I would not worry too much about it, at most even with the nose high, you are off maybe a cup (8oz). Total is ~4 qts, or 128oz, and you are shy of that by *maybe* 4oz.
  17. VFerdman
    1,186
    1,215
    Thank you, all for the comments. I just took the car on a family road trip around 450 miles round trip. Single tank of gas and I could only fit just under 8.4 gallons into the tank. Worked out to something like greater than 52 MPG! This is with a full trunk, AC going the whole time, a lot of highway driving at 75 MPH (or higher), two adults and a teenager in the car. While at destination we drove nice and easy, of course and there was a lot of slow moving traffic everywhere. WOW! I am very impressed. The main screen said I was getting 49 PMG, but at the pump I was blown away by the actual fuel consumption. I thought I was not getting all I could into the tank by not being familiar witht he way this tank behaves with auto-shutoff of the pump, but hard as I tried, I could not get more than just under 8.4 gallons in there. I am pleasantly shocked as I was not hyper-miling, especially on the highway. I stayed with traffic flow and sometimes passed slower drivers in RVs and such with a nice punch to the accelerator. Very, very impressive gas mileage. I hope it continues.
  18. VFerdman
    1,186
    1,215
    My next task is coolant change in both circuits. I bought two gallons of Toyota LLC (may need a third gallon from what I am now finding out). What I would like to do, ideally, is to use the vacuum gadget to fill the systems. I saw a bunch of videos and it seems that vacuum fill is the simplest and most reliable as far as air purging. I really am not interested in trying to coax the air out of the system by hand. I will do that if I have to, but I have read here that some auto stores loan these vacuum tools. I have looked around where I am in all the usual suspects (Auto zone, Adavnce Autopart, etc.). They did not have the proper tool. They had a vacuum tester, that could apply a vacuum and gauge it, but no means to suck in the fresh coolant. If anyone here ever rented the appropriate tool, please let me know where.
    As it stands now I am prepared to purchase a tool from Amazon (under $100). I don't mind buying the tool if it will do a better a quicker job than by hand. My philosophy with tools is that buying them is still cheaper than having the job done for me (especially at a dealer). And then I have a nifty tool to keep. Since this tool is only used rarely (every 50K miles?) I would rather rent it, of course, but my search for rentals has come up empty so far.
    If you know of a resource, please let me know. Also, if you know of a particularly good version of this tool, also let me know.
    Thanks!
  19. jerrymildred
    11,517
    14,152
    Tampa, FL
    Congrats on the great trip report. Don't forget that you'll need several tanks to get a real feel for your mileage because the rubber bladder in the tank makes full ups very inconsistent. Either way, though, those look like nice numbers. Also, you don't want to try to ram in extra fuel beyond the first click because it'll eventually damage the system. There are lots of threads here about that bladder.
  20. 05PreeUs
    1,097
    564
    MSP
    You can save ~$20 by shopping around, or do a DIY thing with a wet-dry vacuum and a PCV ball valve ;)
    Either way, vacuum filling is THE best way. More and more OEMs are requiring it as a SOP.
