***My First Prius***
Discussion in 'Gen 2 Prius Main Forum' started by ktyler2, Mar 13, 2015.
  1. ktyler2
    ktyler2 Junior Member
    25
    Utah
    Hello!
    I just bought my first Prius--a silver 2009 in excellent cosmetic condition with only 28,000 miles. The car still qualified as a "certified used" and I paid $12,900 at the local Toyota dealer. They even threw in a set of brand new tires (mounted and balanced) and some new floor mats. Needless to say, I am very happy with the purchase so far!!
    I commute about 85 miles per day for work, so my plan is to drive this car as long as I possibly can. With that goal in mind, what are the best things I can do right now, and regularly over time, in order to keep repair costs down and maximize the life of this Prius? I am looking for tips related to any and all parts of the vehicle (battery, engine, etc). Also, how long can I realistically expect to drive this thing? Is 200,000 miles a reasonable target?
    As far as fuel economy is concerned, I am interested in suggestions as well. I was driving a Camry Hybrid before, so I am already familiar with some techniques for maximizing gas mileage. I have the tire pressure at 42/40 and am pretty light footed when it comes to acceleration and braking. Coming from about 41-42 MPG in my TCH, I was crossing my fingers for >50 MPG in this thing. I was pretty pumped to get 479 miles from 8.686 gallons on my first tank--55.15 MPG!! I don't know if this is sustainable for me, but if I can keep it above 50 I will be thrilled...
    Please offer up any advice/suggestions/feedback. It will be greatly appreciated.
    Thanks!
    Data Daedalus and Burna J like this.
  2. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Oil changes and inverter coolant changes.
  3. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Be sure the front disc brake caliper bolts are re-lubed every so often, say every 24,000miles/2years.
    Already drain/fill the transaxle. Consider getting a magnetic drain plug for the transaxle. Ready post #473 below.
    ATF fluid changes ARE Required. | Page 24 | PriusChat
    Read this for some additional insight.
    What services you need and what you don't | PriusChat
    Since you are in a snow environment, a spare set of wheels and snow tires.
    NEVER FILL the oil above the top dimple on the dipstick. If you don't DIY oil changes, nearly all oil change places, tire stores, independent shops, and even some Toy dealers, overfill the crankcase. Horror stories and big dollar repairs have resulted.
    CHECK the OIL LEVEL regularly and frequently! Realistically, you won't start burning oil until you get closer to 100,000 miles. Many stories of people coming here for help b/c the "low" oil light came on. That is actually a low/no oil pressure light. Appeared momentarily when the driver braked hard, or took a turn hard, causing the oil level not to be in contact with the oil pump pick-up tube, thus no oil pressure. If you never check the oil level, you will not know the car is telling you hey, I'm consuming oil, be sure to top off as needed.
    #3 exstudent, Mar 13, 2015
    The Limey likes this.
  4. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Welcome--nice find!
    In addition to what's been mentioned, the mechanical engine water pump sometimes develops leaks on the Gen II. It shows up as pink, crusty buildup around the water pump pulley (low, on the passenger side of the engine). If it's not leaking, it doesn't need attention, but if it starts, the pump should be replaced (about $100 DIY).
    The life of the high-voltage pack is often best measured in years than miles, so even though there's not much on the odometer, there's question as to how much longer the pack will last. It's been theorized that the pack lasts longer when driven more frequently, which yours may not have been. It might not take to you 200,000 miles (unless you rack those up in the next few years). You might want to start setting aside a fund. Also try to keep the pack cool--park in the shade, if possible, use a windshield shade and the cargo cover if in the sun, etc.
    Since your commute sounds like a highway one, one of the best MPG strategies (although it sounds like you're doing great already) is to moderate cruising speed. Wind resistance increases dramatically above about 60 mph.
    If you do run into any issues, search or post on the forum before taking the car to a service department, if possible. You're likely to find much more cost-effective solutions here.
    Enjoy!
  5. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The tyres play a big part in the economy of the car. Although the dealer put two new tyres on the car what actual tyres did they fit? and what are the other two tyres? The OEM tyres although reasonable for economy are certainly not the best.
    Your also at the ideal millage to change the transmission oil. This is considered a lifetime fill, but through oil analyse has been found to contain high levels of metal from the bedding in process.
    John (Britprius)
    Data Daedalus and usnavystgc like this.
  6. ktyler2
    25
    Utah
    Thank you to everyone for the advice! I have already spent hours reading up on the forums here. I will definitely be a regular reader.
    The agreement with the dealer was actually to replace all four tires on the car. I specifically asked them if I could request a certain tire and they said it could be probably be arranged. They eventually gave me an allowance of $400 for the tires and labor. I did some research on Tire Rack and eventually chose the Continental TrueContact tires. They were ordered on Thursday 2/26 and installed on Monday 3/2. To my surprise, I wasn't charged anything extra. So I drove away very happy.
    I immediately noticed a difference in driving quality with the Continentals. They were much smoother than the original Goodyear Integrity tires that were on the car when I bought it. Now it's almost two weeks later, and I have inflated the tire pressure to 42/40. Some of the smoother ride quality has obviously diminished, but they still feel much better than the Goodyears. In addition to the smoother ride, I have also noticed better stopping power. Some of this is probably just because they are new, but I had noticed the Goodyears struggled a bit on the wet Utah roads. Not so with the new Continentals. As far as fuel economy, I am going to fill up my second tank today, so we will see if I get anything close to the 55MPG I got on my first tank. If I can stay over 50MPG with the added benefits of the new tires, I will be feeling even better about this purchase than I already am now!
    I am thinking I will change the transaxle fluid and check the engine oil level. Does anyone have recommended fluids/oils? Should I pay more for ATF-WS and synthetic engine oil? Are there really any performance/longevity gains to be had with "better" fluids/oils?
    Tanglefoot mentioned the HV Battery life is more based on age than on mileage. Since this one is already 6.5 years old, is there an easy way to find out the current state of the battery?
    #6 ktyler2, Mar 14, 2015
  7. bisco
    52,405
    no, you need an appropriate scanner such as mini vci or pay the dealer to do it. figure and 09 battery to have the equivalent of 60 or 70,000 miles. peanuts. all the best!(y)
  8. jdenenberg
    jdenenberg EE Professor
    3,953
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Yes, you should use the Toyota WS ATF and most find that full syn oil does a better job of cleaning an lubricating youe engine than "dino" oil.
    JeffD
  9. exstudent
    2,214
    905
    Torrance, CA
    For your safety, a spare set of wheels and snow tires would be a good thing. I forget the slightly larger tires sizes you could go on the 15" or 16" wheels, which would be cheaper than getting the exact size listed in the door jamb.
    I think BritPrius knows interchangeable tyre sizes well, maybe he'll chime in?
  10. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    The True Contact looks like an excellent tire, and it's classified as an "EcoPlus", so it should roll nicely and deliver good MPG, as well as traction. That tire has such high ratings in all conditions, including snow and ice, that I imagine there's no need for a second set of tires for winter. I was originally debating a second set but instead went with an all-season tire that is rated well in ice and snow (although not as well as the True Contact) and it does great, year round, without the cost, storage need and inconvenience of a second set.
    The Goodyear Integrities are fairly disastrous tires. About the only thing they do well is roll, but they wear fast, get noisy and have pretty awful traction.
    I didn't mean to concern you too much about the HV battery. I debated editing that post. They usually last a long time, but if you do start setting aside a replacement fund, it might sway Murphy's Law so that you don't experience a failure. Signs of a failing battery include fast changes in state-of-charge and the battery cooling fan often running at high speed (the vent is in the rear seat side bolster). There are also other things that can go wrong (transaxle, inverter, ECU, multi-function display, etc), so a rainy day fund is never a bad thing. Some might consider it overly-cautious thinking though. Overall reliability has been very high and cost of ownership, low. It's usually best to be prepared, but relax and not worry.
    Choice of lubricants and fluids is a personal thing. There's various debate about it. I would use Toyota fluid in the transaxle but I've never used full-synthetic in an engine before. I did a few synth-blend changes with the Prius, but have since reverted back to dino oil.
    #10 tanglefoot, Mar 15, 2015
  11. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    Thanks for posting a review of the Continental TrueContact. We are having a set installed on the summer wheels today, but they won't be getting mounted on the car until old man winter decides to call it quits for the year. We've just received another five inches of that that fluffy white stuff today.
    For what it is worth, our last set of summer tires were the Continental ProContact with Eco Plus. These were vastly superior to the OEM Yokahamas, and the fuel economy was unchanged. They had 4/32 tread remaining at 48,000 miles. Hopefully the TrueContact will be an even better tire. We will post an update after running a few tanks of gas on them.
