My first real test of Charge Mode efficiency
Discussion in 'Prime Fuel Economy & EV Range' started by Lee Jay, Sep 16, 2017.
  1. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Until you experience winter driving.
    HypersonicPrime likes this.
  2. HypersonicPrime
    75
    59
    NC, USA
    In the winter you could reset your electricity consumption in the car's settings to reset your average miles/kWh. This would give you a more realistic estimate based on your current driving conditions.
  3. john1701a
    12,840
    5,312
    58
    Nope. Where are you experience true winter driving, the conditions are quite random and very unpredictable. The temperature vary significantly too.
    I'm currently editing video of my first winter drive like that now... no charge-mode use though, this one was all electric.
    Mark57 likes this.
  4. Tideland Prius
    16,678
    True winter, the temperatures are less variable than some places that either frequently sees the influence of downslope winds (chinook, santa ana) that significantly warms up the surface temperature or a place that frequently sees storms that bring in warm airmasses with a warm front then see sudden drop in temps with a cold front (e.g. southern Ontario or the St. Lawrence River valley)
    Trollbait likes this.
  5. john1701a
    12,840
    5,312
    58
    Here's that video...
    Arctic_White likes this.
  6. Trollbait
    12,821
    That is my guess in the case of the Clarity.
    For the Prime, it is because of charging limits. For longer battery life, you want the charge rate to slow down as the pack gets closer to full. You can maintain the fast charge rate up to 80% for most chemistries, but the final 20% can take almost as long as the first 80% with this slowing.
    HPrimeAdvanced likes this.
  7. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    Correction: It's 57.7% not 50.7%
  8. HypersonicPrime
    75
    59
    NC, USA
    I didn't see it, but based on other data from your MID, I'm going to guess your A/C load ratio was about 24% on that drive (due to necessary use of heat). Your initial EV range estimate (without climate on) should have been about 30 (because your average mi/kWh of 4.6 is skewed high from not usually having to use so much accessory power). Your actual range is probably about 23 miles right now, which would make the initial estimate of ~30 seem unreliable until you reset the mi/kWh value.
    It would be interesting to reset your electricity consumption, drive at least one wintery day to set a new baseline, then record your next day commute (same conditions and climate usage) to see if the distance estimation is more accurate. Your current mi/kWh should be closer to 3.5 right now.
  9. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Had to do another one of these today. averaged 73.8MPG using charge mode + Ev.
    benagi and priuscatprimeguy like this.
  10. john1701a
    12,840
    5,312
    58
    Here is another real-world data sample...
    vvillovv and priuscatprimeguy like this.
  11. vvillovv
    vvillovv Senior Member
    4,337
    1,518
    NY
    I wonder if the traction pack heater is switched on when in charge mode.
    The pack is heated from the bottom which is better than no pack heater
    but with cold air being blown through the pack while charging
    (unless the air intake gets heated too) the bottom of the pack can be
    hotter than the top for the entire charge.
    Probably not noticeable with a fresh battery though.
    #31 vvillovv, Mar 7, 2018
  12. jdonalds
    541
    225
    I see you're in NY. I thought only the Canadian Clarity cars had traction battery heaters.
  13. Lee Jay
    5,850
    4,036
    No, they all do.
  14. jdonalds
    541
    225
    From everything I read only the Canadian Clarity had a traction battery heater. What source do you find that shows the American Clarity PHEV has that heater?
  15. Lee Jay
    5,850
    4,036
    I'm sorry, I was thinking Prime, not Clarity.
  16. Trollbait
    12,821
    The Clarity has liquid cooling for the battery pack. Most other plug ins using such a system can also heat the pack this way, which helps with charging efficiency. It also allows charging at reasonable rates without damage when the Li-ion cells are below freezing.
    Primes in Canada and Alaska have an additional heating function over what the rest of North America gets. It is possible Honda saying Canadian Clarities have a battery heater could mean in addition to the basic battery heating.
