My first time using Toyota Roadside Assistance really sucks
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Jun 6, 2025.
  1. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I have a small 2.5 ton jack that just barely can lift one Prius wheel. I can lift that jack, but for now I travel with the scissor jack. I use my Makita 18v impact wrench to loosen the wheel lugs that were put on by the dealer's gorilla (and operate the scissor jack).
    JeffD
  2. Mendel Leisk
    42,373
    Scissor jack with it's traditional crank handle will get it done too. This is something you do VERY sporadically, and you will be motivated.
    If anything needs more air, a floor-standing bicycle pump can do that as well (usual disclaimer about motivation)
  3. Mendel Leisk
    42,373
    A piece of plastic or cardboard would do too.
  4. Winston Smith
    Winston Smith Active Member
    476
    344
    OH
    2024 Prius
    LE AWD-e
    Sitting on the ground seems rough, and getting up seems rougher, but you are correct to note that I'd be motivated.
    Being realistic about what one can do seems central. One of the reasons for rotating my own wheels is just to know i can do it.
    Pumping up a car tire with a bicycle pump sounds like something that would be written on a death certificate.
  5. bisco
    52,891
    yeah, i could do it if i had to. last time was in my garage. bought a spare for the pip and wanted to make sure it fit.
    took 3 days to recover, but at least i didn't wind up in the er :oops:
  6. silvertounged devil
    silvertounged devil Junior Member
    48
    Yorktown Virginia
    2024 Prius
    A Harbor Freight 3/8ths impact gun (Bauer) with a scissors jack will raise it off the ground in seconds (I've done it) and pop the lug nuts off. A pair of large c-clamp vise grips to break the bead. then a couple of bead levers to get the tire off. As long as you understand the purpose of a drop center rim it's not that hard and I will be 75 in a few months. Pop lived to 103. If you are physically unable then road side assistance can do the job or Uber to a tire shop. The issue is the tire. If I get a spare it can be made smaller with rope or string to collapse the sidewalls to get it smaller for a better fit in the spare tire well.
  7. silvertounged devil
    48
    Yorktown Virginia
    2024 Prius
    I have a Bauer tire inflator with a 5 AH battery that will inflate the tires easily, several times all 4 on a single charge. It runs my little cooling fan for pickleball for hours. Set it up to stop at the desired pressure. Anyone who tries to mount a tire with a hand pump is looking for a trip to the ER.
  8. frodoz737
    frodoz737 Top Wrench
    4,810
    2,562
    33
    I've busted a tire manually once in my life when I was young. Not happening again. If I don't have the proper tool for the job (as it relates here) I go to the shop that does. YMMV
  9. Mendel Leisk
    42,373
    ^ Same story here, once was enough, never want to do that again.
    I guess one-man’s-ceiling…
  10. silvertounged devil
    48
    Yorktown Virginia
    2024 Prius
    It means I have that option.
    Then it will never happen.
  11. Mendel Leisk
    42,373
    An unmounted, full-size tire, possibly bulkier than a ready-to-install, mounted, temp spare, isn’t likely to be too popular.
  12. Zeromus
    Zeromus Active Member
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    Lots of very affordable, plug into the cigarette lighter, pumps available too. They won't be the fastest, if they're really cheap, but they do the job. I got one for $20 on sale at Canadian tire and I use it to top off my tires when I do a seasonal change. Works well. Small and fits under the trunk's floor cover.
    If you have a slow leak, or just need to top up a spare or something its fine.
    The topic of the thread is roadside assistance though. And yeah... all the roadside assistance programs suck. Toyota's, CAA, whatever it is. They basically just have tow truck companies contracted, and they pay them for their time instead of you. You are at the mercy of whatever operator takes the call from their network at the time you need help. And the wait times are always long. They always have been. The most prompt service is always directly calling an independent, super local to you (within a close distance) shop/tow operator.
    Also, at least where I live, if you are on a major freeway, the city or province (I can't remember which level of gov backstops this) will ensure a tow operator will arrive to move you asap. If you don't want to pay the fee to get to your preferred shop, then the tow truck will only move your car off the freeway to a safe location on a side street as a public service paid by the city/province. Cops can also help you off the freeway too. But there are also laws against how long a car can stay on the side of the freeway, so if you call a roadside assistance program like Toyota/CAA, they'll prioritize your vehicle anyway.
    I can only assume that Paul was on a highway rather than a freeway, or maybe more rural in location if they let it take that long. Or maybe the laws in Alberta are different and they don't have something that enforces fast removal from freeways and programs set up to support it.
    #52 Zeromus, Jun 11, 2025
  13. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I don't need any kind of a spare if I have run-flat rims.
  14. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I've gambled and won, so far. No spare, but plug kit and inflator. Including on 13,500 mile road trip-- PA-AK-PA, which included the 135 mile Denali Highway which is mostly gravel. One flat on that trip and plug kit worked fine. Your experience may vary!
  15. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I had an inflater/sealer kit with my Gen 3. I would have been afraid to use it after 12 years. The goop was probably solidified. Anyhow, someone else's problem now.
  16. bisco
    52,891
    why don't they just make solid rubber tyres?
  17. Hammersmith
    Hammersmith Senior Member
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I vote for wood wrapped in iron.
  18. bisco
    52,891
    i think you're on to something
  19. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I read an article about that in one of the popular mechanics magazines. All the attempts up to that time, experimenting with puncture-proof tires resulted in a reduced ride and poor handling characteristics.
    I know that this technology has been further developed, but so far, we only see such tires on slow vehicles like construction equipment.
  20. bisco
    52,891
    someone had semi solid a tyre with a honeycomb design. not sure what happened to it
