My first up close Gen 5 Prius sighting
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Nov 14, 2023.
  1. Gokhan
    Gokhan Senior Member
    6,714
    2,661
    Paramount CA
    For the very first time, I saw a parked Gen 5. It was a silver LE. I immediately swerved and parked to walk around it.
    My impressions:
    This car looks tiny! It looks like a subcompact. I don't think there is any mainstream car out there today that looks smaller or about the same size. Gen 4 looks much bigger and substantial. I am thinking Toyota made it smaller to reduce the costs.
    They indeed tried very hard to make it look like a sports car. It still looks like a Japanese toy car, but it indeed looks sporty. No one would mistake it for an Italian luxury sports car, but if you are into sporty-looking little Japanese cars, then this is the car for you.
    Unfortunately, the car does not look substantial because it looks like a little subcompact, which somewhat negates its sporty looks.
    The interior looked really, really small.
    Silver didn't look bad, albeit looking a little toyish.
    The rear-door handles are even more odd-looking in person.
    While I was going around the car, I realized that there were boxes in it and someone was sleeping under a blanket in the reclined driver's seat.
    It is an understatement when Consumer Reports said "Toyota made a better car but a worse Prius." Definitely don't buy one without test-driving it and seeing if you are OK with the smaller size.
    #1 Gokhan, Nov 14, 2023
    Downrange likes this.
  2. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    Perception is everything!
    Here's the comparison specs: upload_2023-11-14_12-56-15.png
    2023 is up all around except for HEIGHT, which is down 2 inches.
    Preebee and Tideland Prius like this.
  3. Tideland Prius
    16,678
    You really didn't need the second part of your title. Clickbait much?
    bisco, Roqu3, otatrant and 2 others like this.
  4. Trollbait
    12,822
    The lower roof line results in the car having a profile that is more sedan wedge than aero hatchback.
    Tideland Prius likes this.
  5. Gokhan
    6,714
    2,661
    Paramount CA
    It looks very small in person. I even compared it to my Gen 4 Prius Prime parked a little ahead.
  6. Argyros
    275
    142
    2023 Prius
    facts don't lie; its bigger, period.
  7. Tideland Prius
    16,678
    Very small? It's 2 inches shorter than the Gen 4 Prime and 1" longer than the Gen 4 Prius as @Argyros has shown above.
  8. Gokhan
    6,714
    2,661
    Paramount CA
    The metrics don't tell the whole story. The car appears small in person. You need to see it for yourself.
    #8 Gokhan, Nov 14, 2023
  9. Tideland Prius
    16,678
    I’ve seen it many times. They’re car shares here plus I’ve seen private ones (red, blue, grey and black. No yellow Prime yet though they do exist. And I’ve seen a white one in the showroom). They look bulkier than the Gen 4 (and I can compare since the car share has Gen 4, Prius c and Gen 5 Prii).
    nerfer and Preebee like this.
  10. converseguy
    converseguy Junior Member
    2023 Prius
    You can say it appears small to YOU. I drive my 2024 Prius Limited every day and it neither looks nor feels small to me.
  11. srwax
    srwax Junior Member
    29
    31
    Las Vegas, NV
    2023 Prius
    I feel the same way.
    I'm 5'8 seating in the front seats doesn't feel cramped at all and views through the front window are wide and gorgeous.
    Only when I sit in the back seats I feel the low roof for it's touching my hair.
    Preebee likes this.
  12. Gokhan
    6,714
    2,661
    Paramount CA
    OK… It is good to know that it is probably a perception/illusion issue.
  13. Tideland Prius
    16,678
    The cargo room is definitely smaller than the regular Prius (probably slightly bigger than the old Prime). That's where you'll notice a difference, especially if you're coming from a Gen 2/3 or a Gen 4 without a spare tyre - you lose that height.
  14. Trollbait
    12,822
    And the gen4 Prime's length increase is from bumper styling; a bolt on fascia.
  15. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    Well, I can speak to this since I have both in my driveway! Here's the straight poop: the Gen 5 is a lot smaller in appearance! What's the reality? OK, it's posted above, but those numbers do not tell the whole story. Aside from the obvious and significant loss of headroom both front and rear, there is a large loss of leg room. Not overall length, but the width of the compartment where your legs go. This is one of the areas I have identified as key for me, since I'm tall and often take long road trips. I enjoy being able to change my leg position a bit, and this is constricted in the Gen 5. A lot.
    The rear hatch is approximately 3.5 inches narrower. (I measured this a bunch of posts ago, so that's not exact, but close.). And, of course, it's also shorter. You will not be able to load some objects that fit fine in the Gen 4, even my Prime. This is a fact, I have tested it. Forget about putting larger adults in the back seat - not gonna be a nice ride for 6 footers, especially whoever sits behind me. The only thing that seems bigger, wider - is the dash board. It goes forever. And that's not entirely bad. There are some design features I really like about the Gen 5, but to say it's not smaller - then point to the external measurements as objective proof - misses the whole point.
    I may well trade my 22 Prime in on a new Prime in the next month or two - one is coming in with my name on it, but it's not without a lot of tough decisions. Will I be OK on those long two-day excursions, with 10-11 hours per day behind the wheel? I'm fine at present with my Gen 4; will I regret trading to a Gen 5? Will I hate having to cram my seasonal tires-on-wheels in there twice a year? Probably. What about that impulse purchase that won't quite fit in my new ride? I really wish we could have had the choice between two Priuses - one with mostly the old body style and upgraded battery, and maybe engine, and the new ersatz sports sedan. It may be ugly, but the Gen 4 is much more practical than the Gen 5. And yeah, it's bigger!
    nerfer and Tideland Prius like this.
  16. Preebee
    Preebee Senior Member
    888
    780
    Midwest
    2026 Prius Plug-in
    SE
    About as close to the behavior of a jilted lover as you're gonna find outside of an actual relationship. You can't help but feel sympathy.
    #16 Preebee, Nov 16, 2023
  17. Tombukt2
    Tombukt2 Senior Member
    13,848
    2,515
    Durham NC
    they just arent substantial like my Gen II . heck my genIII are way too flimsy No worries though i wouldnt look at these till 10 yrs old
  18. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Ebbinghaus illusion... Which orange circle "looks" smaller? LOL
  19. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    I've seen both in person. The Gen 5 is more pleasing and sporty and powerful. Its a tool for a job. Given the cost and availability I've decided to go BEV. But I still always ask for a Gen 4 Prius at every AVIS counter I visit.
  20. Gokhan
    6,714
    2,661
    Paramount CA
    Photos typically have a lot of distortion. In the upper photo, Gen 5 is a lot closer to the camera than Gen 4, making it appear much larger than it is.
