My gen 2 2005 goes off after running the engine .
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kolez2000, Aug 23, 2021.
  1. kolez2000
    kolez2000 Junior Member
    64
    West Africa
    I just this gen2 2005, the 12v battery is flat, I had to jump start it. After the engine came on, it run well......but it goes off after some 20mins, I would still need to jump start it with a 12v battery....pls what could be the Issue?. It's my first time on hybrid.
  2. JC91006
    16,480
    8,397
    Maybe you have a bad 12v battery and that needs to be replaced. Have you tested it? Are there any warning lights on?
    SFO likes this.
  3. ChapmanF
    15,569
    What voltage do you measure at the battery terminals, or between the front fusebox jump point and body ground, while the car says READY?
  4. kolez2000
    64
    West Africa
    Thanks, I have changed the 12v battery and it's fine.
    My ac blowing hot and my compressor making noise. No gas in the system and rye oil is low. What do advice? To resolve the ac issues?
  5. bisco
    49,444
    new a/c
    kenoarto likes this.
  6. kolez2000
    64
    West Africa
    New ac? How about I oil the compressor and charge it? Will it not chill?
  7. bisco
    49,444
    be careful. read through the a/c threads before attempting anything. prius high voltage compressor is a bit different and can be easily damaged
