My Gen3 was totaled; considering a Gen2
Discussion in 'Gen 2 Prius Main Forum' started by MikeNinMass, Mar 14, 2019.
  1. MikeNinMass
    MikeNinMass Junior Member
    26
    Cambridge, MA
    On New Year's Eve, some guy ran into the front of my 2010 and totaled it. Insurance gave me about $7k, which may be what it's worth to the market, but it was paid off and worth more to me than that. I'd like to get another Prius, but I see there are issues with the 2010, probably extending into 2011 until the serial number associated with the TSBs on engine knocking. Mine did that, and I didn't realize it was an issue.
    I liked the 2010, except for really hard seats and the blind spot created by the A-pillar if you sit high to minimize the blind spots created by the slope of the rear door windows. It had decent power, storage, quietness, etc. But I can get CARB 2008's with under 100kmiles and no accidents by Carfax, for around $7k. Low mileage 2011-1/2's and newer are around $11k. I want lower miles so I can be more sure of the maintenance history.
    Special considerations. I towed my 16 foot catamaran sailboat around, including up my steep 1/4 mile driveway with no issues. I've connected an inverter to the 12v battery to help me through power failures (car in Ready mode). I want to be able to run my sump pump if I lose power in a storm, about 800watts steady state, twice that at startup. I kept my 15" snow tires and 1-year-old Altimax tires from the 2010, which would be 8 less things to buy (yes, I know they are a little bigger, but the forum threads say they'll fit). Next year, my company is moving into the city where I live, so I won't have a 50-mile roundtrip commute, and I plan to bike to work most days, so my car needs will drop significantly, though the cabin with the sailboat is three hours away.
    Concerns with a Gen2 vs. Gen3
    -Smaller ICE, 25% less torque, less power: How does that affect engine noise on highway? How is acceleration onto highway? Towing (usually low speed backroads)? Engine wear? Will removing the air intake resonator really help (please don't answer "in theory" if you haven't tried it)?
    -How does 12v battery compare? I read the Gen2 had a small battery. Is it smaller than the Gen3? Effect on using an inverter?
    -How does handling compare? Should I get a Touring model? What's the difference and how can I tell? Does Touring have larger wheels making my tires useless? What extra features are worth looking for? (If I get a cheap enough car, I can replace the stereo with an Android Auto-compatible one.)
    How is braking with rear drums, particularly with moderate towing? The 2010 was fine.
    I had planned to run my 2010 into the ground, until someone else did it for me prematurely. I don't think it's worth the price difference to get to the "fixed" Gen3's, unless I can't use a Gen2 for towing and as a back-up generator. However, at 120k miles, my 2010 might have been ready to suffer the oil consumption blues. I also have a smart kid getting ready to go to a top college, but I lost my wife to cancer a couple years ago, so he has an underfunded college fund on my single income, and I'm trying to be frugal.
    I'm thinking of getting a 2008/09 with the CARB warranty. I guess the main question is: should I get one set up nicely to last, or buy a cheap one and live with it until the Gen3's come down in price, then trade up in a few years?
    Also, what else should I know about Gen2/Gen3 differences in terms of performance and durability? I'm a car guy, though I ready to not deal with all the inattentive and obnoxiously aggressive Boston-area commuters, but I like my cars to handle well and be controllable in emergency situations. I am also mechanically inclined.
    thanks,
    ---mike...
    Cambridge, Mass.
    kenoarto likes this.
    52,862
    Not much difference between the gen 2 and 3 imo.
    Buy my daughters 2008 with 130k, put a few hundred into incidentals,
    And save your money in case you need a battery, combo meter or brake actuator
  3. oil_burner
    oil_burner Active Member
    249
    126
    I can only comment on towing and highway driving, it will affect your engine life somewhat. I bought my 2nd gen at 218k and proceeded to drive quite hard. I moved cross country twice towing about 1500lb utility trailer, and another 300lb packed in the car. I also towed a motorcycle trailer loaded to about 1000lb every other weekend. And my regular commute to work involved a very steep mountain pass where I was at or near full throttle for 45mins. I tended to drive rather quickly too, 85-90mph. My head gasket blew at 270k, which is a far cry from some of these 400k+ examples. However, I'm not disappointed in the car due to how much abuse it handled. Mine was also consuming oil regularly, I just topped it up biweekly using cheap oil.
    Rear drum brakes were fine with towing, although I would not exceed 1500lbs. Would highly recommend new shocks and springs if you plan to tow.
  4. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Gen 3 looks better and handles slightly better. I think an inch or two more leg room in drivers seat so more comfortable?
    Gen 3 has that super tiny useless sunglasses holder made for kids. An adult can not put their sun glasses in the overhead holder (gen 2 is normal size).
    Gen 3 has that ridiculous "deeper" but not very large space underneath the trunk mat. So if you're really disorganized and just plop a bunch of things in a deep space I guess it is ok.....The gen 2 has a very nice under trunk mat storage that is quite enormous, just not deep. I have OBD scanner (with case), set of tools in a little suitcase-sized case, extra clothes, paper towels, windex, armorall wipes, etc....in the gen 2 underneath trunk mat. Could never fit in a gen 3.
    Gen 3 you might get the "check hybrid system" message but I think fixed on a recall or extended warranty? Other than that you pretty much never hear of "red triangles of death"/hybrid battery going bad. Gen 2 apparently is common (guessing maybe 1 in 20 or 1 in 30 before 250k miles?)..
    Gen 2 rarely gets a bad head gasket but apparently common on gen 3.
    Gen 3 in power mode pretty quick compared to a gen 2.
    Both gens burn oil like crazy.
    Imo a well maintained gen 3 is overall better but will pay premium price for it?
    A gen 2 you can severely abuse and it will continue to run forever. Can get them much cheaper than gen 3s.
    Can't remember noise level on gen 3 but the gen 2 is kinda noisy when motor kicks on.
    Leather is about 10X more comfortable than cloth if you plan on being in your car for more than an hour it is worth paying for it (can also find sets at junkyard and swap).
    I've had extremely good reliability/"luck" with both gens, and only buy at the 150k miles and up range.
  5. MikeNinMass
    26
    Cambridge, MA
    Thanks oil_burner and MilkyWay. Those thoughts were helpful. I was set to pick up a 2008 with 96k miles for $6k from a reputable Toyota dealer, but last week they got a 2012 with 120k miles they were offering for under $9k, so I went to see both. The dealer offers a 12 month, 12,000 mile powertrain warranty. It's probably my history with low-end torque, but I felt the Gen2 needed to rev higher than I wanted to get going, which added more engine noise. My first car in high school was a 1970 Dodge Dart with a V-8, and my first purchase was a 1990 Dodge Spirit turbo (with peak torque at 2000 rpm) which felt similar. It seems from oil_burner's experience that the higher revving doesn't translate into significantly shorter ICE life, but I like the Gen3 engine response better, and know there's power mode when I want it. Both cars are CARB-state originating, so the extended emissions warranty will end about the same time for both, one on years, the other on miles.
    I didn't realize the Gen2 doesn't have height-adjustable seats, and although I liked the steering wheel response better, the car seemed a little less stable. The 2012 has bluetooth/JBL and Nav/back-up camera, all of which I wanted (would upgrade from Crutchfield if it didn't), and decided to go with it, since I think the main question would be "only" head gasket. It had a light tapping noise on start-up from dead-cold (at least overnight in Massachusetts), sounded more like tappets than the pronounced knocking on my 2010. (Getting totaled might have saved me from an impending head gasket repair!)
    The 2012's Carfax showed a coolant change at 83k, so if the coolant-acidity-affecting-head-gasket-life theory is correct, hopefully that helped. Oil changes at 10k, initially and final ones at Toyota dealers, so presumably synthetic. Middle changes were at Sears, so, some uncertainty. The dealer is now doing a 128-point safety check/oil change. Said they'd also do the 120k service. I'm thinking that when I get it home, I'll check the ECG tube and intake manifold for carbon and oil. If not too bad, I'll do the whole EGR system cleanout and an oil catch can when the weather warms. If it's bad, I might start earlier, and continue to use my kids' car, which otherwise usually sits.
    Do you think doing a preventive head gasket change over the summer, before my son (also a gear head, but more on the computer vs. actually holding a wrench) goes off to college would be a good idea? I figure if I get to it before it leaks, there's less likelihood of warping.
    Then I could get an upgraded gasket, and only have to worry about the piston rings. Or should I just wait and see...?
    Thoughts?
    thanks again,
    ---mike...
  6. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Didn’t they revise both the rings and pistons to address the oil problem by 2012?
  7. Zeppo Shanski
    Zeppo Shanski Active Member
    312
    193
    Chicagoland
    Gen-2 is the best looking Prius that has been made. My 143,000-mile 2005 does not burn any oil. My last tank of gas went 48.6-mpg over normal regular driving.
    I'm just sayin'.
  8. MikeNinMass
    26
    Cambridge, MA
    2014 for the piston; 2015 for the rings
    By 2012, they didn't require the intake manifold TSB.
    Mid-2012 they changed the p/n for the head gasket. The one I'm looking to buy is early 2012, though
  9. Skibob
    2,912
    1,505
    Northern California
    Somehow I thought it was sooner than that.
  10. MilkyWay
    823
    359
    23
    MI
    HGs, from what I have seen and read....are about as rare as a hybrid battery going bad on a gen 2....but even more rare than that.
    I have read about it from time to time but not that often.
    As long as you keep the EGR cleaned out every 100k miles should be good.
    I also have a 2012 that I am renting to an uber driver. Had about 230k when I gave it to him maybe 4 months ago. They are very nice cars.
    Last two vehicles that had head gaskets were fixed with blue devil for me lol. I'm talking about HG symptoms of: no heat, low coolant on dash, bubbles in coolant reservoir, and twist off cap and coolant shoots up....every symptom was fixed by having my mechanic use blue devil. One was a 06 Chevy 2500HD 6.6L diesel...the other was a 2001 Infinity Qx4.
  11. MilkyWay
    823
    359
    23
    MI
    Mine didn't burn until about 175k or 180k.....Now burns 1 quart every 1000-1500 miles. I'm at 205k now.
  12. MikeNinMass
    26
    Cambridge, MA
    I plunked down the money for the 2012 yesterday, but this morning I realized I was thinking about the preventive part, and my car search, all wrong. Because of the one-year powertrain warranty, I should be hoping that it burns oil per TSB 0168/0169-16 within the next year so they replace everything to new specs, including the newer head gasket and pistons/rings. Actually, I should have been looking for the one that was most likely to need the work, not the best maintained one!
    So... should I do all the EGR and oil catch can stuff to keep it running longest, or nothing to get it to fail early? When I asked for the repair sheet, it noted "oil leak," but the sales rep said since they didn't fix anything, it was likely that there was oil spilled from a fill. I'm guessing it might have been PCV into intake manifold.
    I'll pick it up next week, make sure the oil is at the top of the dipstick line, and monitor the oil level. Any other suggestions?
  13. Skibob
    2,912
    1,505
    Northern California
    A quart in 1100-1300 miles is a pretty good burn rate.
  14. 09Prius2
    09Prius2 Member
    201
    88
    FL
    A couple years ago these cars were a good deal. Now they are just a headache. They electronics failure rate is high and the commonly failed parts are getting very expensive used if you can find them at all. And good luck going to the dealer.
    Things you may have to replace: brake actuator, coolant valve / pump, combo meter, display screen just to name a few. All mine have gone within like the past 2 weeks in addition to other things.
    The rear drums stink on wet roads. When the regen braking cuts off at 7mph and the front discs are still wet, the car lurches forward and the rear drums lock up and skid. I cant imagine this being pleasant or safe while towing.
    That being said, if the frame can handle the 1000 lbs or however much it is, its more about not exceeding transmission temperatures. You would probably be wise not to exceed 50-55 mph max.
    The Critic likes this.
  15. oil_burner
    249
    126
    I think your rear brakes just need a service, mine certainly don't lock up on wet roads. Drums are cheap for replacement shoes. When I tow I just do the speed limit, although one time I was in a rush pulling about 800lb and held 75 mph for 2 hours, no harm done just 29mpg.
    I wouldn't go around messing with the head gasket on a good engine, I'm in the camp that these engines can never be put back together as tight as factory with their special robots. Just make sure you do regular coolant changes. I put in a low mileage junkyard motor instead of replacing my HG. Since I was able to get a motor with 75k on it for $500, it wasn't worth the trouble to try and rebuild an engine with 275k of wear on it.
  16. Mendel Leisk
    42,354
    Don't abuse it; fix that Prius!
  17. Skibob
    2,912
    1,505
    Northern California
    I agree with the brakes being off but personally I think I can do a much better job reassembling an engine than any robot can. The Nissan GT-R engines are all assembled by hand. There’s a reason for that.
  18. Mendel Leisk
    42,354
    After a bit of searching, here's a pretty good video on Toyota engine assembly. In one shot you can see blocks trundling into an assembly corridor, and no signs of robots. There is a cool computer-guided applicator for the timing chain cover sealant.
  19. Zeppo Shanski
    312
    193
    Chicagoland
    A whole lot more Priuses are made than Nissan GT-Rs. It's not as economically efficient to have cars of that little volume made on the same type of computer guided/driven process. I don't really think the tolerance consistency of computer-built can be matched by hand.
    I'm sure somebody will tell me how wrong I am. Being just conversation I know that I could very well be wrong.
  20. oil_burner
    249
    126
    tons of robots, notice every bolt is driven in by some calibrated driver, every surface is clean enough to eat off of. The head is torqued with a machine that does all the bolts at once. As opposed to me in my garage scuffing up mating surfaces with a scotch brite pad and doing bolts one at a time with my clicker torque wrench. They are assembled by "hand" but no 3/8ths socket wrenches to be seen.
