My girl wanders...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Kevfra, Jun 7, 2018.
  1. Kevfra
    Kevfra New Member
    Yuma, AZ
    2012 Level 4, 50k miles, like new condition, and new to me. But she wanders, and wow does the crosswind make it wander! Steering feels tight but it just wanders. Rolls straight as can be, doesn't seem to be any alignment issue. I have found a lot of info on this relating to the Gen 2 but not to my Gen 3. Same regarding links to braces, all are for G2. Maybe Toyota improved things on the 3? But not mine.
    So, are there braces I can add or change to improve this problem?
    James Powers and Burna J like this.
  2. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    2 quick fixes are just a rear sway bar and a front strut bar. each takes about 15-20 mins to install, super easy. I use these 2:
    For Toyota Prius 2009-2015 Cusco 951 540 ALHD Front Type OS Strut Tower Brace | eBay
    2010-2015 Prius TRD Rear Sway Bar Prius Sway Bar Genuine Toyota PTR11-47010 | eBay
    However, if you can... I highly suggest buying and supporting HybridPit great guys over there that support the Prius modding community. I havent modded in almost 2 years, but will go to them when I get "the itch" someday and start to mod again.
    Toyota Prius TRD 2010, 2011, 2012, 2013, 2014, 2015 | Hybridpit ($245)
    Toyota Prius - Cusco Strut Tower Brace - STB 951540-ALHD ($180)
    There are other options. Just have to browse. For example, Tanabe ($123) makes a great looking front strut that is functional at a great price. But it blocks your fuse box. Or you can get the Tom's front strut ($295) which is a fully solid piece with no bolt joints, so its super sturdy. But has a premium price tag. Go with your gut (y)
    #2 Starbrand, Jun 7, 2018
    James Powers and orenji like this.
    52,791
    welcome! what tires and pressures are you running?
  4. Mendel Leisk
    42,286
    Get an alignment check? Only the front toe can be adjusted, but everything can be checked. I'd second tires too, and there's a thing called conicity, that can cause pull to one side, swapping the front tires side to side can help to diagnose it.
  5. Kevfra
    Kevfra New Member
    Yuma, AZ
    Michelin Defenders. Good tread and no uneven wear. Car does not pull at all, it just wanders.
  6. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Get the alignment check. If in spec, the front tires should have a slight toe-in. Our Prius v (wagon) wandered a bit and the aliment data printout showed a very slight toe-out before the alignment. Now that it is within spec the wander is much better!
    GrGramps likes this.
  7. bisco
    52,791
    never marry a girl with a wandering eye.;)
    Daigi_ likes this.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Ain't gonna lie, thought the post was gonna be about infidelity.
