My gosh, are the front fender liners really this big?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Purrius, Sep 25, 2022.
  1. Purrius
    Purrius Member
    172
    50
    Northeastern US
    My 2010 is currently in the shop, but I ordered these beforehand and they just came in. They look way too large, but I can't compare them to the car so I don't know if they actually are?
    Here's the auction screenshot and the auction.
    Here's the photo of mine (please excuse the clutter, ps3 controller for scale).
    These are the part numbers that were listed
    Partslink Number:
    TO1228168
    TO1248158
    TO1249158
    Is it just me?
    douglasjre likes this.
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I don't know where the Xbox controller is going to go, but the fender liner looks good.
    I recently installed a new front fender liner on my 2016 Toyota Corolla S plus, and it pretty much looks the same.
    Make sure that you get all of the assorted fasteners that are needed.
  3. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    Yes, it's just you... But then again I never play video games?
  4. Tombukt2
    Tombukt2 Senior Member
    13,871
    2,521
    Durham NC
    You good clips included
    Purrius likes this.
  5. Mendel Leisk
    42,368
    @Purrius you should be able to post pics directly in the thread, with the “Upload a File” button.
    The wheel well liner is a long, convoluted piece, with an odd, shop-bolted bar splice near the front. Requires maybe 15 fasteners, and there’s one near the back that’s pretty much impossible to remove without destroying it.
    #5 Mendel Leisk, Sep 25, 2022
    Purrius likes this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I wouldn’t buy anything for until your head gasket gets replaced.
  7. PriusCamper
    13,472
    5,439
    Do you ever re-read what you wrote to make sure it actually makes sense? Of do you not care about making sense?
    mikey_t likes this.
  8. Purrius
    Purrius Member
    172
    50
    Northeastern US
    I mentioned in the post, I'd already ordered these before the issues came up.
    Raygon likes this.
  9. Tombukt2
    13,871
    2,521
    Durham NC
    Yep I'm saying. you good clips included. Ready to go . Install .they that big. See wen ya remove .
  10. PriusCamper
    13,472
    5,439
    Just in case you didn't know... What you wrote makes no sense at all. You are NOT being helpful at all.
    mikey_t likes this.
  11. Tombukt2
    13,871
    2,521
    Durham NC
    Yeah otay.
  12. Purrius
    Purrius Member
    172
    50
    Northeastern US
    I understood what you meant, which I feel like is all that really matters, as it was in response to my post. So no worries, mate.
  13. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Always use all new fasteners all the way around without exception. I generally expect the holes to be damaged and I use oversized lock pen designed body fastener kits. I buy a big box of them and I drill all holes oversized to accommodate the new fasteners. Be absolutely certain that you have fixed the front portion incredibly well because it is notorious for catching air getting pulled down and trapped under the front tire which guarantees the entire wheel liner rips out again
  14. Purrius
    Purrius Member
    172
    50
    Northeastern US
    You were all correct, the parts fit if even with a bit of tight fitting and a tiny bit of after market drilling. Thank you kindly, and I mean it. <3
    PriusCamper and Mendel Leisk like this.
  15. PriusCamper
    13,472
    5,439
    "after market drilling" for underbody panels is always way easier than all the fools who spend a fortune on OEM fastners that are more of a hassle than a convenience.
  16. gatorback
    gatorback Junior Member
    60
    I need to replace the fender liner: can you provide a link to your oversized lock pen designed body fastener kit? The advice here seems sage.
    I am not certain, but I think that one of these Amazon kits is said fasteners?
  17. Tombukt2
    13,871
    2,521
    Durham NC
    I just use fuzzy inserts the correct size. I haven't had a liner top out yet except in accident .then vehicles ruined .
  18. rjparker
    rjparker Tu Humilde Sirviente
    11,129
    6,982
    Texas Hill Country
    You can reuse most of the fasteners and can get generic fasteners at any auto supply. Even a few factory fasteners are not too bad at the dealer.
    Don't expect the aftermarket fender liner to fit like the factory liner. Be prepared to drill your own holes and improvise a bit.
  19. Purrius
    Purrius Member
    172
    50
    Northeastern US
    I buy aftermarket clips in bulk from ebay, I just look for toyota fender clips and go from there. (Sometimes they're a bit more brittle/fragile though, so keep that in mind.)
    The liners I previously mentioned in this thread are still going strong, though. :D
