My Headlight Mods: Mini H1, Blacked Housing and LEDs
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Justdidit, Jan 16, 2013.
  1. USDM - With Amber lens and reflector
    27.3%
  2. JDM - No reflector and Amber LED bulb for parking light
    72.7%
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Which one is on the fence..
    The JDM look w/o Amber reflectors?
    These?
    Or just this in general?
  2. Unleashd
    Unleashd Junior Member
    71
    Oakhill, VA
    How is this project coming along?
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Daytime photo update:
    I'll get some night shots soon. The output of these H1s are freaking amazing. Puts the OEM HID to shame. LEDs are awesome for DRLs.
  4. Unleashd
    71
    Oakhill, VA
    Looks awesome. I think the black trim paint brings out the looks much better. LEDs are looking very good too.
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Thanks for the ideas and help!
    Unleashd likes this.
  6. Unleashd
    71
    Oakhill, VA
    You've given me more ideas for a summer project :)
  7. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    This project was definitely fun. Not sure why not more people aren't doing do this mod. The LEDs themselves are fairly cheap. It just takes some patience and attention to detail. Some websites sell this 'mod' for up to $900. Time and effort wise, I definitely think parts aside its worth $200 in labor alone. All worth it. :)
  8. Robert Meserole
    Robert Meserole Junior Member
    What process/ steps did you take when painting the trim piece? Also what paint did you use?
    Thanks,
    Robert
  9. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    I used a Satin Black.. This to be exact:
    My Old OEM HID painted lights...
  10. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Haven't had time to align my headlights yet, but here are a couple night shots of the light pattern.
    Pulling into the Garage
    A bit of the length of the cutoff - I'll get a better one later.
    Compare OEM HID 35w with 6000k DDM bulbs VS 55W DDM 6000k kit. Notice with the 6000k looks more white with the 55W. Makes the road light up nice and white...not as much blue.
  11. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    You can see from this photo, that there is some glare above the cut-off from not painting the housing black and leaving it chrome as it has been suggested. :(
  12. Robert Meserole
    I assume that you sanded the chrome prior to painting it? What other steps did you take?
  13. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Nope, just started with a light coat. Added 2 more coats after. Didn't seem to need to sand...prob wouldn't hurt tho. Other than taping off with green tape the areas I didn't want sprayed.
    As you can see from the photo:
    Make sure you have everything else covered. Mist and over-spray is horrible if it gets on anything you still want shiney!
  14. Robert Meserole
  15. Robert Meserole
    Sorry forgot to end the quote
  16. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    The 5mm LEDs i used aren't perfectly straight but taper a bit. They are very secured in the 3/16ths hold due to just friction. At one point I wanted to turn the LED in the hole and it took some needle nose pliers to even get the LED out.
    As shown the LEDs came prewired and this wire was clipped and tapped by solder to a 1 main pwr and ground. If I ever decide I want to swap out the amber reflector for a silver one, I may put a 'light barrier wall' to keep the light from the LEDs from entering the turn signal reflector area turning it a whitish-blue.
    Because i didn't use the amber lens covering the parking light this left a small slit to feed the wire back thru the reflector to a small hole i cut near the parking lamp bulb. I fed the wires thru that hole and connected them to the parking lamp wire pwr and ground.
  17. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i like the new look. glad you put back in the normal yellow reflectors as it's illegal in California to use anything else. I think it all shines really well. the black on chrome is a good ascent. I kinda like the idea of doing a two tone projector as you showed in that one photo (mazda?). Your normal all blacked out idea looked as if someone punched your prius in it's eyes.
    The results are soo good that i'm thinking of doing something similar. I love the clean cut offs. I don't know if id care to add the little LED row in. I like LEDs to replace all my halogens but the bands are a little overkill since everyone abuses that look. I'll definitely keep this info for changing out the projector and fogs.
  18. V8Cobrakid
    3,790
    152
    btw.. with the heat buildup, your paint may peel... when you showed the spray-can i instantly thought of the bbq paint since its rated for 400+ degrees
  19. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Ya, I agree with you...but I guess since I've done two other sets of headlights with this and no issues... I'd just use the rest of the can. BUT, yes, prob should have used Hi-Temp paint.
  20. Unleashd
    71
    Oakhill, VA
    If I aim the headlight at 2" lower at 20', I have the same issue on mine too. Though my reflector is painted black, the trim is still chrome and creates that glare above the cut -off. You can see that glare above the garage door handle in this picture. I have now aimed it at no drop off in 20' to avoid that glare and haven't been flipped off yet :)
    Daves09prius likes this.
