My heat pump works well below 16 degrees
Discussion in 'Prime Main Forum (2017-2022)' started by rsl360, Jan 7, 2018.
  1. bisco
    51,882
    exactly.
    drysider likes this.
  2. rsl360
    rsl360 Junior Member
    17
    16
    Cape Cod, Massachusetts
    Well, we don't know how efficient it is. But there is no reason for it to stop working. The heat pump on my house is rated to work down to -4f. However, I generally don't use it if the temperature is below around 40f. With what I pay for electricity vs fuel oil, it's not efficient. But thermodynamically, it still works all the way down to -4 degrees. And no, it does not have a heater, other than the one that keeps the compressor warm, and that only draws about 30 watts.
  3. padroo
    padroo Senior Member
    2,763
    2,252
    I really don't know much about the Prime heating except that it has a heat pump. Does it have a conventional heater or not? I always wondered why cars didn't tap the catalytic converter for instant heat.
    51,882
    by conventional heater, if you mean a radiator under the dash and engine coolant, yes wonder if tapping the cc would interfere with operation?
  5. bisco
    51,882
    this is what i meant in post 19, thanks for putting it more eloquently.
  6. CharlesH
    2,796
    1,163
    Roseville, CA
    Yes, the Prime has a conventional engine coolant heater core in addition to the heat pump. And the Gen 3/4 Prius (including the Prime), has a coolant loop to the engine exhaust to bring the coolant up to temperature very quickly. I believe it uses the exhaust gas coming out of the catalytic converter. As I understand the chemistry, one wants the catalytic converter to get hot as soon as possible, so one wouldn't want to cool off the exhaust gas before entering the converter.
    #26 CharlesH, Jan 7, 2018
  7. padroo
    2,763
    2,252
    Thanks, I will check that out. I really haven't had a chance to get under mine yet, it's been cold and snowy. Now that you mention it I believe I remember it being mentioned in the YouTube video from Weber College in Utah, John Kelly showed the whole cooling system of the Gen4 Prius. Hoses, Hoses and more Hoses. lol
    I think I fell asleep during this video. The part to watch starts at 16:30 about the exhaust heat exchanger.
    #27 padroo, Jan 7, 2018
