My install and review of the AIMS Prius 2kW Pure Sine Wave Inverter for Backup Power Generator
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AHetaFan, Mar 3, 2013.
  1. bwilson4web
    16,433
    If you have an interest, I would be happy to desolder the toroidal isolation transformer to see if it blocks the likely ground fault signal. Send me by 'conversation' a shipping address. You'll need to mount it safely. Perhaps on perf board inside a case, plastic would be OK, with some vents.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Yes, I was expecting a much higher reading between the DC cables and ground than 2 Megohms. This would be reading the DC cable to the Inverter/Converter input. I have the 2010 Repair Manual in a pdf file and need to see if I can find a Mohm value.
    It will be interesting to see the AC signal with the oscope this weekend.
  3. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I sent you a PM 'conversation'.
  4. bwilson4web
    16,433
    Got it!
    We're letting the seller have first crack at resolving the problem. If we get to a point where it looks like progress has stopped, this becomes a way we can move forward. But no need to preempt the seller.
    jdcollins5 likes this.
  5. AHetaFan
    AHetaFan Member
    104
    55
    I did get an opportunity to speak to AIMS today. Shall I post what I learned?
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I would say yes. I have an email string going between Jack Chen and AIMS tech support. I was waiting for a further answer from AIMS and plan to call tomorrow.
  7. AHetaFan
    AHetaFan Member
    104
    55
    OK I think we both know the same thing then. Just waiting for them to get back to me when they are ready with a response.
    It isn't normal for the negative terminal to be 0 ohms resistance to the case. They have a sample inverter they tested which does not have this problem.
    Just speculation but I imagine one of those mounting screws you can see on the underside is missing an insulated standoff or contacting a nearby circuit path on the board circuit board that it shouldn't. Hope it is this simple.
  8. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I an glad to hear that they have tested a sample inverter which did not have the problem. The first response was that the negative terminal is NOT connected to ground.
    I looked at the inverter PCB on mine the best that I could and it was elevated above the case bottom by nylon insulators, albeit too short in my opinion. The solder terminals on the bottom side were awfully close to the case bottom.
    If I do not hear anything this morning I am planning to call this afternoon.
  9. AHetaFan
    AHetaFan Member
    104
    55
    They agree there should not be continuity between the case and the negative DC terminal and their unit doesn't have continuity between these so hopefully just an assembly error that will get sorted out.
    bwilson4web likes this.
  10. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I agree. It should not be difficult to determine where the connection is being made and repair it.
  11. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I received an email from AIMS this afternoon asking me to check the Inverter PCB to see if it reads continuity to case ground. If it does I need to send the unit back to them for testing to try to find where the 240VDC is grounding to the case.
    I will test it when I get home tonight and let you know.
    AHetaFan and bwilson4web like this.
  12. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I talked with AIMS when I got home tonight and he recommended looking for any nylon insulators with metal washers instead of nylon washers. He also said that he would loosen the insulator screws one at a time and see if I could possibly find the one that was causing the connection to ground.
    There are 12 screws on the bottom of case that go to the insulators that support the inverter PCB. I could only get to about 6 of these from the top of the PCB. I tried loosening one of these at a time and them move them around to see if I could get any type of change on the continuity reading to case ground. Nothing that I did would even make the meter resistance reading wiggle.
    I started to loosen some of the screws from the bottom but began to get nervous that I may not be able to get the nylon insulators to line back up to re-insert the screws. I decided it was time to close everything back up and ship it to AIMS and let them dis-assemble and figure out where the PCB was making contact with the case :) .
    He did tell me that there have been 3 people, with this model inverter unit, in the last couple of days that have reported the same connection between the DC negative connection and case ground.
  13. AHetaFan
    AHetaFan Member
    104
    55
    I'm inclined to leave it all to AIMS as well. I'm waiting until they get back to me with instructions. I was happy with the way they handled my power light problem. Only downside was paying shipping one way. I knew I was on the bleeding edge all along so I expected there would be some issues with this project. Just this wrinkle to work out and project will be complete.
    I'm glad you discovered and reported on this. Safety first. (y)
    bwilson4web and jdcollins5 like this.
  14. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I appreciate you leading the bleeding edge ! Yes this is just a minor detail. Once we get the repaired units back from AIMS we should be ready to go. They seem to be easy to work with and genuinely interested in finding and correcting this problem.
    I wanted to fix the problem without having to ship it out but it was going to be more of a disassembly than I wanted to get in to. I think once they remove the board from the case the ground connection is going to be easy to find and repair.
    I am just glad that I laid the unit on top of the HV battery case the second time and found this problem now rather than in a situation where you needed the emergency power.
    DadofHedgehog and bwilson4web like this.
  15. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I wanted to complete all testing today before shipping the inverter unit back to AIMS. I tested the DC cables to ground leakage current after replacing the fuse in the multimeter. The readings were DC+ 0.080 mA DC and 21.0 mA AC. The DC- readings were 0.150 mA DC and 22.0 mA AC.
    I left the multimeter on the ammeter reading too long one time waiting for the value to settle out and the car triggered a ground fault alarm again ! The ground fault signal works very well!
    I put an oscilloscope on the DC + and - cables to ground and read the ground fault signal. It is a 25 VDC, 2.5 KHz signal riding on top of the DC battery cables. See attached picture.
    I connected the inverter with the unit isolated from chassis ground and connected a small table fan. I took a look at the inverter output and I am glad to report that we indeed have a "pure sine wave" output. See attached picture for the waveform.
    I checked the DC input voltages with the inverter in operation and the DC - terminal remained at 0V and the DC+ terminal read 220 VDC. The ground to the negative terminal is a continuous ground.
    I was concerned about the low megohm reading to ground of the DC battery cables (~2.0 Megohms). I opened the relay compartment to remove the inverter wiring harness and took a reading of just the cables going to the Inverter/Converter module. The Megohm readings improved very little with the wiring harness removed. This made me feel better about leaving the wiring harness connected permanently. I am still a little disappointed that the resistance to ground is not higher than it is.
    After the final testing I took the inverter unit to the Mail Room to ship it back to AIMS. When the unit returns with the 220 VDC terminals isolated from ground I should be ready for the first emergency power situation.
  16. bwilson4web
    16,433
    Awesome! This is the first time I have seen anyone measuring the ground fault signal.
    Now the isolation transformer wiring makes sense. With the windings in opposite phase, it would block the 2.5 KHz signal but pass the DC. Hopefully the design has something similar and it is just the fault to ground that is the problem.
    Well done!
    AHetaFan and jdcollins5 like this.
  17. bwilson4web
    16,433
    Would you ask him if two of these units can be frequency synchronized so we could provide 'whole house' power. Many homes in North America have two, 120 VAC feeds that are 180 degrees out of phase. This is fed to the main breaker box and then fans out to the rest of the house circuits. Having two units, frequency synchronized would allow whole-house power with a single, isolating switch where the utility line comes into the house.
    Also ask what sort of output, overload protection is provided? Does the unit electronically limit output current to protect the power electronics and then trip 'offline'? Would it still work if two units were tied together and one tripped?
    The reason I ask is we had an inrush, load problem that would trip the overload protection circuit. I had left the house on Prius power and taken the electric bicycle to run an errand. When I came back, there was a slow, oscillation as the overload circuit shutdown; after a pause, powered up; the inrush tripped the overload. I was amused but my wife had a different opinion.
    Thanks,
    AHetaFan likes this.
  18. AHetaFan
    AHetaFan Member
    104
    55
    Yeah got to be quick when measuring to ground. I tripped the ground fault also. Lacking any tools to reset (My old ODB II doesn't work with a Prius) I had to disconnect the battery to clear the hybrid system warning.
    Thanks for doing all this I don't have access to an O scope.
  19. AHetaFan
    AHetaFan Member
    104
    55
    The Inverter manual says the inverter has "Electronic Overload Protection on with automatic shutdown".
    Description from the manual:
    "When output AC voltage drops below acceptable levels (106 VAC):
    -Increase Battery Capacity
    - reduce the load
    Although the inverter can supply momentary surge power, occasionally some products rated less than the rated continuous output power may exceed its surge capabilities and trigger its safety overload shut down feature. If this problem occurs when attempting to operate several AC products at the same time, try first switching on the inverter with all AC products switched off. Then one by one switch each on, starting with the highest surge product first."
    Once I connected a 1000 watt heater and a 1300 watt induction cook top intending to run it on low to see if they could be run together. (Previously I had measured 500 Watts draw from the cook top on Low and thought avoiding a high heat setting would work) They were connected through my Killowatt so I could measure the voltage and current. This worked fine with the cook top on low. When I tried to increased to a hotter cook top temp though I encountered voltage reduction even though the Killowatt was measuring around 1700 watts total. Apparently the cook top generates brief large surge currents when it cycles on and off to maintain set temperatures. I then hooked up the two 1000 watt heaters and a high wattage three way light bulb. The inverter maintained full voltage until over 2000+ watts. On the highest setting on the 3 way bulb the voltage dropped.
  20. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I would recommend you emailing AIMS at [email protected] to get the answer to your questions. AHetaFan answered the ones on the overload protection but I think AIMS would need to answer your questions concerning the synchronized units and what would happen if one tripped.
    The guy that I have talked to is Andrew Frey.
