my iphone keeps disconecting from my 2024 prius
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by cheap e, May 14, 2026.
  1. cheap e
    cheap e Junior Member
    my iPhone keeps disconnecting from my 2024 prius, I've erased and reinstalled many times but keeps disconnecting every time I turn the car off. Any ideas anybody?
  2. vertex
    vertex Active Member
    673
    144
    new york
    2018 Prius Prime
    I have similar issues with my 2023. Seems like a common problem.
  3. mingc
    mingc Member
    104
    70
    Portland, OR
    2023 Prius
    XLE AWD-e
    I was having the same problem with my Android. Like you, I kept un-pairing and re-pairing with not much improvement. However, the last time seemed to have done the trick. It is now rock solid. I don't know what I did different. So, all I can say is keep trying. Good luck.
  4. Tatsuya
    Tatsuya Junior Member
    Toronto
    2024 Prius Prime
    SE
    My theory is that the apple updates are messing up the wireless CarPlay connections, but I can't say for sure.
    My solution: connect the phone via wired USB-C connection. Works every time now.
