My new car
Discussion in 'Diesels' started by seftonm, May 24, 2010.
  1. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    Grats on the new vehicle!
    Nothing like it, enjoy!!
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Congrats! It sounds like you are pretty excited about your choice.
    Keep us posted with your maintenance stuffs.
  3. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  4. dsljay
    dsljay Junior Member
    Breinigsville, Pa.
    Nice car. We had a 1996 Passat TDI and we loved it. We got 54mpg on our Fl. vacation and 37 city. Sold it a few years ago. Diesel in Pa is about 40-50cents over gas. That sucks.
    Did you find tdiclub.com .
    Well good luck., Jay
  5. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    First off, Congrats! Awesome vehicle!
    The Jetta SportWagen TDi was on my short list. Really liked the acceleration and handling! I was also impressed with how quiet it was and relatively no smell. I owned a diesel Rabbit Pick-up back in the day, consistantly got 50 MPG out of it. But, that was in the days when diesel was half the price of gas, so the noise and smell was easily overcome by the cost savings at the pump!
    I choose the Prius over the the SportWagen for two reasons and they were both financial... Diesel here cost $.40 more per gallon than unleaded and the Prius cost me $3000 less than the best deal I could work on the SportWagen! Three Grand buys a lot of gas!
    What do you think about the 10K between oil chages? Also, the dealership I was working with offered free maintenance (which included an oil change every 10K miles) for the first 3 years/36K miles. Do they offer that in the Great White North?
  6. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    Americans get the free 3 yr / 36k mile maintenance, but we do not. 10k miles between oil changes is the same interval as my old TDI. I've gotten used to it now and kind of like not having to change it so frequently. Some of the TDIs in Europe do 20-30k mile oil change intervals when using the long life oil in the right conditions.
    The SportWagen is quite a nice car, but it's hard to argue with an extra $3k in the bank. If they could lower the price a little, it would maybe help the sales. One thing which is nice to see is that over 80% of SportWagens sold are being fitted with the TDI. It's the only engine to get if getting a SportWagen, IMO.
    Jay, I did find tdiclub. Same username for me over there :)
  7. Tideland Prius
    16,631
    It's the only engine to get in a Jetta imo (ok.. fine.. except the 2.0T =P). Do not want the 2.5 litre "guzzler" and the days of yore 2.0 that they're bringing back.
  8. hill
    8,979
    The newest V-dub's electrical systems are a whole lot more reliable than bygone days, that's for certain. One of my car pool bud's has a TDI that's a few years old, with over 100,000 miles on it. He's spent over $6,000 US keeping it running due to tranny & electrical issues, and that kind of corroborates what i've heard in the past. As for emissions, I'm guessing the chart below is no longer aplicable to the brand new 'clean' diesel?
    Just curious ... what special things DO diesel manufacturers have to do, in order to reduce particulate emissions?
  9. bisco
    52,544
    stop making them?:eek:
  10. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    Hi hill, I can't view that image for some reason? usbseawolf2000 made a comparison somewhere on PC that shows the emissions from a "clean" diesel. You may want to do a quick search for that to see how it stacks up against other engines.
    Particulate emissions aren't particularly difficult to handle. Manufacturers use a diesel particulate filter which traps the particulates. After a while (usually 300-500 miles in the 2.0 TDI), the ECU will determine that the filter needs to be cleaned. This is done by sending raw diesel fuel down the exhaust stream into the particulate filter, where it combusts and burns the particulates away. In the 2.0 TDI's case, this fuel gets into the exhaust stream by firing the fuel injectors after combustion in the engine has taken place, and the fuel is then pushed out during the exhaust stroke.
    NOx is a tougher animal to handle IMO. There's two strategies to handle it, one focuses more on reduction during combustion and the other is more focused on treating it after it's been generated. The 2.0 TDI takes the first approach, which uses lots of EGR whenever possible. Unfortunately, this lowers efficiency a little and leads to more particulates being generated and therefore more fuel consuming particulate filter regenerations. Aftertreatment, which all the other light duty diesel sold here do, relies on a urea solution to eliminate NOx. It gives better fuel economy but there's the expense of urea to add on. Personally, I like the urea approach.
    Here's a quick image showing the 2.0 TDI's exhaust system and regeneration frequency for the various emission system components:
    I traded in my 2001 TDI with about 105k miles on it when I got this car. No significant issues with it, but I know experiences with that generation of VW can vary widely. Electrical can be a problem and the old Jatco automatics they used to use were pretty bad. I wouldn't have had any concerns about keeping that car for a few more years based on how things were going with it so far.
  11. CheesyRider
    CheesyRider New Member
    White Bear Lake
    Congrats! I also have a new TDI with a 6 speed manual. Well, it's actually my wife's car, but I get to drive it fairly often:)
  12. austingreen
    austingreen Senior Member
    13,708
    4,230
    Austin, TX, USA
    It should be noted a little EGR as used in the prius increases efficiency, but since there is less oxygen available it reduces power. I don't doubt the high levels of egr used in a tdi reduce efficiency, but the system should be there. As NOx regulations get tougher no doubt the cost of reduction in diesels will continue to go up. This is likely through larger displacement engines and urea injection.
  13. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    Nice car, CheesyRider!
    Urea is not especially expensive. EGR systems will require EGR coolers, larger engines, and more advanced turbochargers compared to urea injected engines. So I don't think the cost difference will be that big. The E350 Bluetec with urea is only a ~$1500 upgrade over the gasoline E350, which is pretty much the same price difference between a VW 2.5 gas and the 2.0 TDI.
  14. durallymax
    durallymax Member
    142
    Under The Hood
    Urea is pretty cheap. Just bought my first drum for our new tractor. $4.19 per gallon at NAPA.
  15. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    At least the urea is now being made easily available. That was the initial concern
  16. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    seftonm, are you using imperial measure for your MPG? H
  17. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    Hi Hal, I measure in US gallons. My mind can work with L/100km or US MPG, but imperial MPG is something that I never quite got used to for some reason.
    10k mile service coming up in a month or so. Will see how that goes. Doesn't look like anything major but I'm hoping I don't end up paying Audi / Porsche prices to get my VW serviced. Both of the VW dealers here also handle more expensive brands with VW being their entry level product.
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    Mike, did you buy your Golf at St James or Auto Haus?
  19. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    Auto Haus. Still debating where I should take it for service, but Auto Haus is closer so will probably end up going there unless I hear St James is consistently better.
  20. Tideland Prius
    16,631
    Would be curious to know. My smart's service was close to MB service pricing!
