My new Prius scares the crap out of me
Discussion in 'Gen 3 Prius Main Forum' started by Oldhippie, Mar 16, 2016.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,440
    3,308
    Madison, Wisconsin
    I had to explain to a new Prius owner the other day that "B" did not mean "Battery" mode.
    They incorrectly thought that you had to switch into that gear in order to use the hybrid battery.
    Sergiospl and bisco like this.
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    My mnemonic is engine Braking.
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    Every Prius owner should have one of these.
    HybridBull likes this.
    51,948
    that's what the toyota salesman told them.:cool:
  5. qdllc
    qdllc Senior Member
    1,377
    400
    In my neck of the woods, there are few places where B would be better than regen braking. There's just not that many steep downhill runs. Times I thought I'd get to use B, I wound up either not going fast enough for it to matter or the run wasn't long enough that it would stress the brakes to just use regular braking.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Oldhippie, welcome. The car makes a number of sounds and you'll eventually just tune them out.
    If you push the brake all the way down it'll beep and keep the brakes engaged for a few seconds after you remove your foot. It'll beep twice when the brakes release. Pressing the gas pedal will also cancel this function.
  7. HybridBull
    HybridBull Junior Member
    Tampa
    Also, keep an eye on your fuel level. The low fuel chime is easy to miss at first!
  8. Oldhippie
    Oldhippie New Member
    Evanston Il
    JimN
    Now that's very interesting about the brake function. I had noticed that and it sure seemed like a malfunction to me. Most of the caution and hesitation I experience, most of the incessant chirping, happens while simply backing my car into the alley. The car seems to spend a moment thinking before it engages reverse too. Not a good way to start the morning. It creates the impression that the computer is driving the car and I am a redundant feature. Knowing that the brakes are supposed to be that way, that I am not headed for imminent brake failure, that helps.
    I mentioned in the first post I have been driving for 48 years and have never had an accident. I have also spent a lifetime working with my hands. I work with physical objects, not ideas, not electrons, not quantum events. Getting used to the fly-by-wire concept will not be easy. For those who imbibed video games together with mother's milk a Prius might feel completely normal. For me it is not. This is not an ordinary car.
    Thanks again everybody. I'll take it from here. For those wondering why someone like me would even buy a Prius...... This car is six years old but only has 52,000 miles. The previous and original owner was a mechanical engineer and maintained the car extremely well. When my mechanic did the inspection it took him only seconds to declare "Engineer car. I'm not going to find anything." He finished the inspection anyway and said it was a perfect car, more perfect than most are when new. I'd been looking for a car quite a while and had seen nothing but trash. I honestly did not know that what I was buying was not precisely a 'car' in the normal sense.
  9. tv4fish
    tv4fish Member
    202
    46
    My opinion - The Owner's Manual has to be "Politically Correct" - in other words Toyota deems it necessary to Cover their *** to make sure EVERYTHING is addressed in the manual. Otherwise -- can you say "lawsuit" --- over who knows what some small detail didn't cover.....
  10. Caniac
    Caniac Active Member
    232
    164
    Happy Valley
    I have switched back and forth between my Prius and whatever other car we owned for almost 10 years. I drive the Prius the same as I drive any other car so I guess I just don't get it.
  11. Mendel Leisk
    41,463
    There's not much to get used to. One thing tho: I'd be reluctant to use valet parking. There's been a few bad outcomes: botched jump starts, cars left running.
  12. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    What car did you drive before the Prius? I came to my 2012 Prius c from a 1996 BMW hatchback, and the Prius had all sorts of features that didn't even exist when my previous car was made.
    I suspect you'll find that the manuals for all modern cars are as complex as the one for your Prius, but as others here have said, you can mostly "just drive it" and figure out the details later. And everyone at PriusChat is almost unfailingly helpful if you have specific questions.
    kenoarto likes this.
  13. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    You can turn off the reverse beeping, or have a dealer turn it off (except for a single initial beep, which isn't so bad). There's more than a little truth in what you say about computers doing the driving. You inform them of your wishes, and they execute them, if they don't have other ideas. All cars are becoming more like that. (Automatic braking coming to all new cars by 2022, for example)
  14. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    I cringed looking at the manuals. I just drive the car and refer to the manuals as needed, or surf Priuschat for the answers. I didn't find driving the Prius any different than other cars other than the joystick type shifter. Have yet to use 'B', probably not needed in my neck of the woods.
  15. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    What was your previous car Oldhippie? I know if I my previous vehicle was a 1973 Toyota truck, I would be intimidated by the Prius. But since it was gradual steps with newer and newer cars, I don't feel as lost.
    My dad whom likes to park and repark cars to share optimum space with the neighbors has never driven my Prius. As each of his offspring comes home every day, he would takes the keys and repark their car. It used to drive me nuts cold starting my car three times every night to move a few feet. But the Prius transmission stalk and lack of a key starter is still too much intimidation for him.
    #35 mmmodem, Mar 18, 2016
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I don't know, when I get a new vehicle I enjoy reading the manual. But that's just me.
    The Prius, being a hybrid, perhaps the manual is longer than the average ICE vehicles, but I don't really remember it being that bad.
    Nothing in it that I found difficult to understand. Today's legal system perhaps makes all manuals overly wordy. They have to explain and warn about nearly every possible eventuality, but again I don't think that is Prius exclusive.
    Personally? I wouldn't use my Prius to jump start a vehicle. As stated above with all the electronics now in vehicles IMO it's just not worth the risk. Not when portable jump start stations are plentiful and relatively cheap.
    As far as your philosophical approach to ownership?
    I find the Prius to be very much a "car" in the normal sense.
    You've bought a hybrid. Toyota calls the system employed HSD or Hybrid Synergy Drive. While the system itself may be more complicated than your average ICE only vehicle, Toyota has made operation of that system nearly automatic. In other words, you can drive it simply as you would any other vehicle.
    Minutia like The Smart Key System, How to Safely Jump Start It, are all things covered in the owners manual, and IMO not any more complicated than with most other vehicles.
    Things like keyless entry, push button start, and even dash input that helps you monitor fuel economy are things that may of had an early genesis with Prius, but now are common on many if not the majority of new vehicles.
    I hate to break it you you. Yes you bought a Hybrid. But also...yes you bought a car...in the normal sense.
  17. 348
    348 Junior Member
    71
    36
    Central Oregon
    I've got 20,000 miles on Enzo since July, have yet to crack open any of the manuals.
  18. bisco
    51,948
    o/p, if it makes you feel any better, my wife's hairdresser bought a hybrid camry, drove it off the lot, and when the engine stopped at the intersection, turned around and traded it in for a regular camry. she said it freaked her out, and she couldn't live with it.
    Bay Stater and HybridBull like this.
  19. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  20. ericbecky
    4,440
    3,308
    Madison, Wisconsin
    That's the guide I was thinking about.
    Just walking through that with a friend is a good way to familiarize yourself.
