My official Prius mods thread.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by DocVijay, Dec 18, 2005.
  1. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(Cheap! @ Jun 26 2006, 11:44 PM) [snapback]277183[/snapback]</div>
    (I'm going to assume you're being serious...) Trim rings? Absolutely not. I got rid of those the day I brought it home! The trim rings are there for looks only and serve no practical purpose except minor protection from curb damage to the wheel, although they would likely be destroyed in the process.
    These wheels are all about maximizing performance, handling, and mileage.
  2. TomKahn
    TomKahn Junior Member
    Indianapolis, IN
    I upgraded to using 205/60 R15 Falken Ziex Ze 512 and I am very happy with them at $43 each.
    You can see them at: http://www.edgeracing.com/2005/Toyota/Prius/tires/15/
    Falken Ziex Ze 512
    205/60R15 20.1Lbs. 420 Treadwear UHPAS H Rated The Falken Ziex 512 received first place in a comparison test done by a leading consumer magazine. One of our best sellers due to its high treadwear More...
    Stock Status: Usually Ships Within 24 Hours.
    Great in the rain, Better in the dry, Good in the snow. This mod did more for better handling then the bt brace or any other mod. I recommend highly.
    Tommy Kahn
  3. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(TomKahn @ Jun 27 2006, 01:32 PM) [snapback]277446[/snapback]</div>
    I already know the tires I'm getting. They're the General Exclaim UHP, size 215/45 WR17. They weigh only 18 pounds, which is considerably less than pretty much all other tires of that size. UTQG is 380 treadwear, AA traction, and A temperature. They also happen to be rated very highly on TireRack.com, placing first in the Ultra High Performace Summer tires. Oh, and they look pretty cool to. All this for only $72. Normally you get what you pay for, but there are some exceptions.
  4. DocVijay
    1,455
    Tampa, FL
    OK, the wheels, tires, and sensors should all be here by the end of the week. If all gets here I'm going to try and get the tires on and balanced on Friday. Then I'll just popo over to Toyota to see if they can't just plug in the scan tool and program the new sensors in. This combo should weigh in at around 31.5 pounds, or about 1 pound under stock. Also, by using the aluminum nuts rather than the heavy steel, I should be able to save another 1/2 pound per wheel. Overall I'll be saving about 1.5 pounds per corner from stock, and 12 pounds per corner from what I have now. Finally I'll be able to really see how much of a difference the weight makes in accelerating, braking, and economy.
    I'll be sure to post pictures as soon as possible.
    Recap of parts:
    Centerline RPM Forged, 17x7 wheels, 42mm offset, 13.5 pounds
    General Exclaim UHP, 215/45 17
    Toyota TPMS sensors
  5. <div class='quotetop'>QUOTE(DocVijay @ Jan 28 2006, 02:37 PM) [snapback]199420[/snapback]</div>
    Where did you et the bulbs???
  6. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(TheParadox @ Jun 27 2006, 09:58 PM) [snapback]277778[/snapback]</div>
    I don't remember. I have the link on my laptop (I'm on my desktop now), but I'll check tomorrow. If you search Google for chrome bulbs you should be able to find lots.
  7. DocVijay
    1,455
    Tampa, FL
    The tires arrived today and I weighed them. They are 18.0 pounds on the dot! Nice and light.
  8. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(DocVijay @ Jun 27 2006, 09:00 AM) [snapback]277326[/snapback]</div>
    Wrong assumption. I was just kidding. {[However, they still look sweet!](Not Kidding.)}
  9. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(Cheap! @ Jun 29 2006, 11:18 AM) [snapback]278589[/snapback]</div>
    OK. Sometimes you can't tell on this site. :blink:
  10. DocVijay
    1,455
    Tampa, FL
    The tires are being delayed beucase of the long holiday weekend. They get here on the 5th.
    Our third child is arriving on the 4th, so it may be a while before I get it all done...
  11. dpower
    dpower Member
    98
    48
    Katy Tx
    <div class='quotetop'>QUOTE(DocVijay @ Jun 29 2006, 08:20 PM) [snapback]278902[/snapback]</div>
    Great rims. I ran Centerlines for years on many of my hot rods. Light and strong, Im surprised to see the great prices with rims from japan going for $500+ each.
    David
  12. dpower
    dpower Member
    98
    48
    Katy Tx
    <div class='quotetop'>QUOTE(dpower @ Jun 29 2006, 11:00 PM) [snapback]278949[/snapback]</div>
    Now that Ive got the suspension getting the way I want it ive been looking at improving air flow. Most of the body kits just look flashy to me, I ran across somthing that looks interesting.
    http://www.japanparts.com/images/ImageFrom...p?base=1&no=721
    I've put in the order and look forward to finding out what, if any, improvments it makes.
    David
  13. dpower
    dpower Member
    98
    48
    Katy Tx
    <div class='quotetop'>QUOTE(dpower @ Jun 30 2006, 10:17 PM) [snapback]279488[/snapback]</div>
    Well dam, they want $350 for shipping and the product is only $315. I guess Ill have to find another source.
  14. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(dpower @ Jun 30 2006, 11:17 PM) [snapback]279488[/snapback]</div>
    Those are the underbody panels that come on the 2006. Check your Toyota dealer, as they should have the parts.
  15. B Rad
    B Rad New Member
    295
    <div class='quotetop'>QUOTE(DocVijay @ Jun 27 2006, 01:10 PM) [snapback]277475[/snapback]</div>
    Were did you go !!!! I am in dire need of finding out how you new Wheel/Tire combo has worked out !!!!!
  16. DocVijay
    1,455
    Tampa, FL
    Our third child was born on July 4th, so I've been a bit busy...
    It may be a while...
  17. B Rad
    B Rad New Member
    295
    <div class='quotetop'>QUOTE(DocVijay @ Jul 11 2006, 12:47 PM) [snapback]284500[/snapback]</div>
    OK: That sounds like a pretty good reason, Congratulations !!!!!!!!!!!!!!!!!
  18. DocVijay
    1,455
    Tampa, FL
    Well, I got the tires mounted. Of course, there HAD to be a snag... I dropped off the tires and wheels at the shop, and then go home. After they call to tell me they are ready, I go to find the piece of paper where I wrote the TPMS sensor ID #'s, and... I can't find it. It's MIA. *&&#($&@^%$! So now I have four mounted and balanced wheels, and when I go to Toyota, they're goingto have to break the bead anyway to get the ID #'s off the sensors. I should have tatooed it on my body do I wouldn't loose them. Ah well, poop happens. Anyway, I plan on mounting them tonight. Pics soon to follow. Of course, now that the kids outnumber us, soon is a relative term. :lol:
  19. benighted
    benighted New Member
    530
    Westport, WA
    That kind of makes me glad I have an '05 without the TPMS if I want to upgrade my wheels. TPMS seems like more hassle than it is worh...
  20. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(benighted @ Aug 6 2006, 10:23 PM) [snapback]298822[/snapback]</div>
    No not really if you do it properly. Also, if you don't switch wheels you'll never have any issue with it. I'm just doing it in a much more convoluted manner than is relly necessary. But then again, not much of what I'm doing is REALLY necessary! :p
