My official Prius mods thread.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by DocVijay, Dec 18, 2005.
  1. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(PRIUSGT @ Apr 4 2006, 06:10 PM) [snapback]234934[/snapback]</div>
    Yes, I'mplanning on getting an aftermarket exhaust. I'm just going to get the Tom's system, as I know it won't interfere with the rear braces. I could do it cheaper myself, but I don't have hte time these days. I'll just get it and bolt it on. Much easier.
    I'm also interested in some sort of intake. As of now there are none, so custom is the only way to go. There are likely some aftermarket kits out there that could easily be adapted to work on the Prius, as I'm sure it shares similar parts with other models. It may be as simple as using the adapter in the kit and a very short length of silicone to mate it to where the factory intake enters the engine.
    I would love to get more power, but it's not that high of a prioroty right now. I'm buying a Lotus Elise in about two years, so that will satisfy all my power and speed needs. The Prius is my DD, and I'm just trying to make it more fun. It'll be around for probably quite a few years, so I'm not going to do anything that would potentially compromise the durability.
    Other than those minor restrictions, anything is fair game. And after the extended warranty is long gone (which will barely be three years at this rate), even the turbo is a go.
  2. PRIUSGT
    PRIUSGT New Member
    Sacramento
    <div class='quotetop'>QUOTE(bernzx @ Apr 4 2006, 06:25 PM) [snapback]234961[/snapback]</div>
    I used a Dragon style muffler. IE. universal muffler. I looked for one with a silencer insert so I could add it if I wanted a stock sound or take it out for aggressive sound. It is louder than stock. If stock is 70DB I would say it went up to 75-77DB. Louder but it does make the car sound a lot more aggressive and not is not to loud. Well aggressive as far as a hybrid goes LOL. I will try to get some sound clips for you all.
    What it looks like with the silencer.
    FYI The opening is 1 inch diameter pipe. The stock prius pipe diameter is 1/2 pipe. U need to make a coupler pipe if you do anything other than TOMs. If you want more power you can take out the 2 resonators on the car. Though not sure how loud that will make it.
    <div class='quotetop'>QUOTE(DocVijay @ Apr 4 2006, 07:55 PM) [snapback]234992[/snapback]</div>
    LOL Turbo. Might as well make a SC, more power off the line LOL. I will let you know what I come up with on the intake. It has to be good for at least 1 HP 2 max
  3. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(PRIUSGT @ Apr 4 2006, 09:06 PM) [snapback]234995[/snapback]</div>
    Sigma also has the "Ganador" cat back setup. That one has twin tips, and is about 10dB louder than the Tom's. The Tom's is only 1dB louder than stock.
    As for a supercharger, maybe the TRD Scion can be modified to fit...
  4. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(DocVijay @ Dec 28 2005, 08:27 AM) [snapback]179896[/snapback]</div>
    Bjorn -
    Going WAY way back here for a moment (man, you need some links to find this stuff in your huge thread!)... The guys who are serious about HIDs say that a relay definitely should be used because of that initial start current. Obviously when running there is no issue, but the severe start current can be a killer to car's system (this all comes from HIDplanet.com). Where did you read about the ignitor storing enough energy for this? How? In caps? How long can it store it? I keep waffling about doing this mod... thinking I should do it right with a projector lens, but then the cost keeps getting in my way - and they're down there in harm's way. I think I'll at least try the cheaper way first. Do you have a shot of your fogs shining on a blank wall (garage door)? I'm very curious to see how uniform the beam is, and the horizontal cutoff. I'm not all that impressed with the uniformity and cutoff of the HID headlights that were DESIGNED for the HID bulb, so I have my doubts about the quality of the fog's beam.
    (I hope we don't stir up the debate about doing HID conversions again! Shhhh.)
  5. bernzx
    bernzx New Member
    56
    <div class='quotetop'>QUOTE(PRIUSGT @ Apr 4 2006, 08:06 PM) [snapback]234995[/snapback]</div>
    PRIUSGT, thanks for the information on your exhaust system, this was very helpful. By the way I just saw "Failure to Launch" tonight and there was a blue Prius driving around near the end of the movie.
  6. Escalade_on_22s
    Escalade_on_22s New Member
    70
    Las Vegas, NV
    Doc,
    I just went to tirerack and purchased the WedSport TC005 16x7 wheel with the Firestone GTA-2 195/55/16 tire combo. This was the lightest thing I could find which would offer the slightest shred of performance. The combo only cost $1500 shipped and mounted.
    WedSport TC005 weight: 12.7 lb (2 lb less than stock)
    Firestone GTA-2 tire: 19.6 lb (2.5 lb more than stock)
    The overall weight is within 6 oz of stock, and the combo should provide much more cornering potential combined with the TRD Sportivo kit I have on order. I hope to preserve/enhance stock MPG with much better handling. I also have the JDM ver A body kit on order, which MIGHT help reduce airflow under the chassis when combined with the lower suspension. I really hope to see improved MPG numbers! If not it should at least look completely original.
    Bryan
  7. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(darelldd @ Apr 8 2006, 02:47 AM) [snapback]236682[/snapback]</div>
    Sorry, I missed your post somehow. Anyway, I really don't think it will be a very big issue as to the startup current required to fire up the bulbs. What I did have to do is go from a 15 amp fuse on the fog light circuit to a 20 amp fuse. The 15 amp would sometimes blow on startup, maybe 1 out of 4 times. I'm not concerned about it for several reasons. First, the legth of the current spike is very short, as shown by the fuse not blowing every time. Also, it seems the actual current is barely over 15 amps, other wise the fuse would blow almost always. Because the duration of the higher current is very brief, the wiring should be able to handle it without even breaking a sweat. I'm not planning on changing anything. Anyway, only time will tell...
    I don't think you need a projector lens to do it right. The design of the fogs is actually quite good for an HID conversion. If you look there is a metal reflector cap that covers the bulb, so the direct light of the bulb is not there. The reflector gets to do it's job and shape the light as intended.
    One note though. Make sure your ballasts are securely mounted. I had zip tied mine in place and one had come loose. It stopped working. I have no way of knowing if the knocking around killed it, or it was just a bad unit, but to eliminate that possibility I'm going to screw them in place more securely. A new ballast is on it's way now. The other still works just fine.
    As soon as it arrives, I'll take a picture agasinst my garage door to get the beam pattern. The cut-off is very sharp for the fogs. I'll try and pull hte headlight fuse so that I can get a pic of just the fog light pattern too. Check back...
  8. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(Escalade_on_22s @ Apr 12 2006, 02:29 PM) [snapback]238659[/snapback]</div>
    Let me know how that combo works. I imagine it'll be great. Also, you'll likely get you'rs before me. The wheels have to be shipped from Japan. Even though it's considerably more expensive ($2200 for just the wheels), I wanted a 17". Also, I wasn't concerned about getting tires from the same place, so I'm getting the Generals I listed in post #1. Also, and most importantly, 3 pounds under stock each!
    I had a friend ask me that if hte 17" wheels/tires were that light, why not go for a 15" and get way under the factory weight. Well, it turns out the 15" tires are not necessarliy any lighter than the 17" General. Most are actually heavier. Also, the wheels don't get too much lighter. I could save another pound in the end, but I'd loose the handling I've grown to love.
    By all means post your results with the Sportivo kit. I'm just annoyed someone else got it before me... :p
  9. Begreen
    Begreen Member
    670
    Western WA state
    <div class='quotetop'>QUOTE(DocVijay @ Apr 12 2006, 12:23 PM) [snapback]238673[/snapback]</div>
    Hey Doc,
    I just wanted to stop by and say thanks for all your detailed posts and advice. My car will probably not see half of the changes that you've incorporated, but it will see some of them. HID fogs will likely be next. The photos, steps and feedback really help boost confidence. Keep up the fun stuff and great posts.
    - Will
  10. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(Begreen @ Apr 12 2006, 04:42 PM) [snapback]238703[/snapback]</div>
    Thank you very much for the comments. Always nice to see someone else enjoying my insanity!
    BTW, here are some pics of wheels I'm getting.
  11. Escalade_on_22s
    70
    Las Vegas, NV
    <div class='quotetop'>QUOTE(DocVijay @ Apr 12 2006, 02:23 PM) [snapback]238673[/snapback]</div>
    I'll be real anxious to hear how your 17's work! It looks like I'll be about 1.5 lbs heavier per corner due to tire weight, but my footprint should be 25mm narrower. It'll be interesting to see who's mileage creeps up the most (if any). I initially wanted 17's also, but I didn't know there was a tire that light in that size. Mainly I just couldn't justify spending $550 per wheel... my spending cap was half that! I'm happy with a 16x7 that only weighs 12.7 lb at half the cost. If you can, do some G-tech testing... I'll do some this weekend and post the results when I get the new wheels on Monday. I'll have to wait about 6 weeks on the suspension kit :(
    Bryan
  12. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(Escalade_on_22s @ Apr 13 2006, 10:42 AM) [snapback]239078[/snapback]</div>
    Yeah, I hear you. I couldn't justify it either... to my wife. SHe laid it down last night, put the brakes on the spending on car crap. Note, she said put the brakes, as in slow down, not stop... ;)
    Anyway, I guess I will slow down for a while. It does get a bit out of hand sometimes...
  13. TomKahn
    TomKahn Junior Member
    Indianapolis, IN
    <div class='quotetop'>QUOTE(DocVijay @ Dec 18 2005, 03:14 PM) [snapback]175326[/snapback]</div>
    DocVijay,
    Do you know what the difference is between the BT stiffening plate and Tom's floor brace? They look like they go on in the same place. Are they just different manufacturers and designs of the same part?
    Thanks,
    Tommy Kahn
  14. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    there were pics posted. toms brace goes all the way across the floor.. bt brace replaces your current chassis brace.
  15. ml86
    ml86 New Member
    92
    Tulsa, Oklahoma
    <div class='quotetop'>QUOTE(DocVijay @ Dec 28 2005, 02:36 PM) [snapback]180029[/snapback]</div>
    Any attorney that drives a Prius can only be half bad.
  16. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(TomKahn @ Apr 14 2006, 10:54 PM) [snapback]240007[/snapback]</div>
    Here is the thread where it was installed and the diferences explained.
    http://priuschat.com/Tomand39s-Floor-Stiff...ace-t12736.html
  17. DocVijay
    1,455
    Tampa, FL
    TRD Sportivo Suspension Kit is ORDERED!!
    Stay tuned (in about 8 weeks...).
    Until then I also orderd a sharkfin antenna, so at least I can install that.
    And hopefully JL Audio will finally release the last part that I'm waiting for (Cleansweep CL-SSI) and I can get my audio system installed, along with some headrest monitors/PS2 for the kids to enjoy.
  18. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    I want to see the pics of the Kenstyle spoiler install..... :D
  19. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(priusguy04 @ Apr 15 2006, 10:06 AM) [snapback]240142[/snapback]</div>
    Me too, but it's going to be a while before I order that.
  20. SaeGai06
    SaeGai06 Member
    102
    Bay Area, California
    <div class='quotetop'>QUOTE(DocVijay @ Mar 23 2006, 04:31 PM) [snapback]229255[/snapback]</div>
    Hey Doc,
    Just finished installing my TOMS Parts that i received. I posted it on your "What's my next project?" Post.
    Here's the link: http://priuschat.com/index.php?s=&showtopi...ndpost&p=240296
    I absoutley love the handling now. Can't wait to order the Sportivo suspension too.
