My official Prius Plus mods thread.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Cheap!, Nov 29, 2006.
  1. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(Cheap! @ Aug 9 2007, 04:30 PM) [snapback]493222[/snapback]</div>
    I did not make it to San Diego this time. Next time I'll get a chance will be in Boston, in September.
  2. GripperDon
    GripperDon New Member
    52
    What ever happened to you?
  3. mrbigh
    3,686
    699
    Long Island, NY
    <div class='quotetop'>QUOTE(Gripper @ Sep 9 2007, 02:50 AM) [snapback]509433[/snapback]</div>
    Run out of thread.....
  4. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(mrbigh @ Sep 9 2007, 10:52 AM) [snapback]509538[/snapback]</div>
    Sorry, I've moved and I'm taking care of that stuff. I am also working on some modification kits when I can find time. I'll post more about that stuff tomorrow.:D
  5. Cheap!
    Cheap! New Member
    1,157
  6. Cheap!
    Cheap! New Member
    1,157
    I want to make converting a hybrid to a PHEV easier for those who want to do this conversion. I'll be the first to say it is not for everyone. However, for those of you who are thinking about converting, I am starting to make kits for parts of the conversions that are difficult, or time consuming, or that just hack up your car.
    My OEM fan was modified, so when it comes on, it comes on full blast. This is helpful because it keeps the OEM battery cooler in the hot summers down here in Houston. In my car the fan turns on when the OEM battery is at about 96 degrees. It stays on until the battery cools down below that. Nothing else is changed regarding that fan.
    Then problem is that the wires to my OEM fan were cut, and spliced, and soldered, and taped. It takes about 30 minutes to do. During the conversion events that is a lot of time. That is why I've located the parts to build a plug and play modification for this conversion. Unfortunately when you start adding up the parts it is much more expensive, but this fan modification will now be reversible. I’m not trying to become rich selling these parts, because I will still tell you how to do this modification the Cheap! way.
    You could even add this to your car if you don't want to convert to a PHEV. It would give you more air flow over the OEM battery if you are trying to cool it in the summer or even heat it in the winter. They are not for sale yet, but I will bring one to Boston next week for the Nilar conversion I'll be helping with, and I'll install one at the Austin Maker Faire in Darren's car in October.
    I'll make a few of these and also I have plans to make a few other things that will make these conversions go a lot quicker. The Red, Green, and black (soon to be blue) wires go to a Molex connector that hooks on the low power control board. If you don’t have a low power control board yet, you could just add one resistor at the end to make it work. More on this later…
    [attachmentid=11380]
  7. Cheap!
    Cheap! New Member
    1,157
  8. GripperDon
    52
    Low Houston, I used to work at the MSC and sure did not love the summers, but Arizona has been a bear this year.
    As i am sure you are aware the Camry system is basically the same as the Pirus, different sized battery, notors, ICe, etc. basicall the same system and the controller is really exactly the same algorthims. Having said all that the Nissan Altima hybrid (my car) is the same as the Camry. So to the point, I would like to implement the Pirus system into the Altima, comments, where can I get the componentry and information as to implementation. I am a retired EE / ME and have the necessary Airconditioned garage space and tools..
  9. GripperDon
    52
  10. mrbigh
    3,686
    699
    Long Island, NY
    <div class='quotetop'>QUOTE(Cheap! @ Sep 12 2007, 10:31 AM) [snapback]511251[/snapback]</div>
    Happy parts hunting......
  11. mrbigh
    3,686
    699
    Long Island, NY
  12. Cheap!
    Cheap! New Member
    1,157
    I was able to build mine with three 45 cent diodes, but the connectors that allow you to plug and play so you don't have to cut wires were expensive. If you have a better source for the connectors, please let us all know. Otherwise for you can do this mod for about two bucks if you don't mind cutting the wire. I did mind and now I wish I would have had more time to locate these parts before my conversion.
  13. Cheap!
    Cheap! New Member
    1,157
  14. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    What's a "Nilar convention", and does this mean you're gonna be in
    my neck of the woods in the near future? Are you driving up?
    _H*
  15. hobbit
    4,089
    468
    Bahstahn
    _H*
  16. mrbigh
    3,686
    699
    Long Island, NY
    <div class='quotetop'>QUOTE(hobbit @ Sep 12 2007, 11:28 PM) [snapback]511713[/snapback]</div>
    Cheap may be referring to "Nilar convention" confused by Boston's Embedded Systems Conference upcoming event. I'm planing to attend to.
  17. mrbigh
    3,686
    699
    Long Island, NY
  18. hobbit
    4,089
    468
    Bahstahn
    Interesting. Is the PHEV conversion they've got slated to happen
    another Pat's Garage / Hymotion install?
    _H*
  19. GripperDon
    52
    Oh well I guess this is time to move on. This seems to be a private thread. No replys unless you are part of the click. Bye
  20. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(Gripper @ Sep 13 2007, 11:11 PM) [snapback]512325[/snapback]</div>
    Sorry about not keeping up with this thread. I've got a lot going on in my personal life.
    However here are some of the things I've been doing with my "Prius Time."
    Attended a "Mothers for clean air" event in Houston
    Attended a Houston Electric Vehicle Association meeting
    They were very interested in Plug-ins. I met some really nice folks.
    Started purchasing parts for a new conversion demonstration in Austin, in October that I am overseeing
    Met with the Austin Electric Vehicle Association and spoke about PHEV's and their benefits
    Also asked for volunteers to help with the Austin conversion in October.
    Getting things ready for the Embedded Systems conference in Boston
    I will be flying out, early next week. The conversion demonstration in Boston will use "Nilar" Nickel Metal Hydride batteries, with a twist.
    Other then that, I am about to pull out my entire pack and redo my conversion to make it look better. Much more like Chris' conversion.
    I'll try to post more after Boston. This summer, I have been driving my PHEV everyday and I have now moved further away so I have to decide if I want to upgrade my battery pack so I can go even further on EV, and EV assist.
    <div class='quotetop'>QUOTE(hobbit @ Sep 12 2007, 10:28 PM) [snapback]511713[/snapback]</div>
    I'm looking forward to meeting you and getting a chance to talk to you about your experiences with your car.
    <div class='quotetop'>QUOTE(hobbit @ Sep 13 2007, 10:39 PM) [snapback]512318[/snapback]</div>
    This is a Calcars open source event where we will answer questions while we work. I'm not sure where your neck of the woods is but if you are near Boston, it wood be great to talk shop with you.
