My oil plug fell out after an oil change, is it ruined?
Discussion in 'Newbie Forum' started by Rebecca4846282, Sep 13, 2019.
  1. bisco
    51,897
    okay, they didn't tighten the plug, and the parts guy is your witness. the oil change place owes you an engine.
    this is a pretty common occurrence, and they have insurance to cover it, so don't take no for an answer.
    was it jiffy boob?
    Skibob and mikey_t like this.
  2. PriusCamper
    PriusCamper Senior Member
    12,736
    5,152
    Pacific Northwest, USA
    Number one rule of any investigation is how often does the person's story change or contradict itself from how reality actually works.
    If this story were true it would of gone as follows: heard a noise, car started running rough and smelled oil and saw smoke (oil on exhaust system) red triangle goes on, pull over, car is still smoking, call friend, while trying to to look at car and where smoke is coming from I see a long train of oil from where I was drving.
    Of course if you eliminated the witness who claimed oil drain plug was "completely gone." Then you're talking about a loose oil filter or damaged oil pan from road debris.
    My guess is original poster is testing her false story so it seems credible enough to pin the blame on the oil change place. But the story failed the test.
    51,897
    not everyone recalls things in the same way. and someone who is clueless about cars might have a different interpretation of events.
    Skibob, jerrymildred, mikey_t and 2 others like this.
  4. PriusCamper
    12,736
    5,152
    Yes, but if you lose your motor oil while driving it goes everywhere, especially on the exhaust manifold and that creates smoke... I guess they need to add that into their story so the scam works... But without a police report, I'm sure the oil change place's lawyers will say that there's no case against them.
  5. Mendel Leisk
    41,411
    Just for the record, I think the oil change was at a Midas.
    Skibob and bisco like this.
  6. bisco
    51,897
    idk, if you drain plug falls out while you're driving moderately, it might all pour onto the road
  7. PriusCamper
    12,736
    5,152
    PS: Stating the you're already a disgruntled customers at Midas prior to incidence further weakens the validity of your claim...
  8. bisco
    51,897
    yeah, i'm a disgruntled midas customer too, and I've never been :p
  9. Mendel Leisk
    41,411
    Yeah if it behaves the same when the car's running as it does when doing an oil change, about 95% of the oil is drained in 20~30 seconds, it's down to a drip.
    One thing though: the drain bolt could have been hung up on the last thread, draining slowly, till it finally shook loose. Who knows.
    mikey_t likes this.
  10. bisco
    51,897
    gullible to what?
    seems like a typical quickie oil change story
  11. PriusCamper
    12,736
    5,152
    Gullible that you and others would believe this ridiculous story after you thought it through... First it was 20 minutes driving and then it was 5 minutes of driving but 20 minutes total between phone calls tow truck, etc. so dishonest.
  12. bisco
    51,897
    yeah, in 20-30 seconds, you might have travelled 2,500', or more meters
  13. bisco
    51,897
    i don't understand the motive
  14. PriusCamper
    12,736
    5,152
    The motive is a ruined engine and denial / blaming someone else is the first stage of the grieving over the car being ruined.
  15. bisco
    51,897
    well, it won't matter one way or the other what we have to say. hey either changed the oil, or they didn't.
  16. PriusCamper
    12,736
    5,152
    And apparently the original poster will be treated similarly by Midas...
  17. Mendel Leisk
    41,411
    Less meters. Just sayin'
  18. bisco
    51,897
    shows you my metric skills :rolleyes:
  19. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Regardless of the sequence of events leading to this discussion, it seems conclusive that OP needs a new engine for her 2007 Prius Base. The value of the car is less than what it would cost to fix it. End of story.
    Mendel Leisk and PriusCamper like this.
  20. PriusCamper
    12,736
    5,152
    Unless you purchased a used engine from a wreck and installed it yourself... Of course that's not what this thread is about. And if the original poster really was being honest they would be pissed and say so... But instead the silence is even more evidence of the real story of what happened not being presented.
    Salamander_King likes this.
