My oil plug fell out after an oil change, is it ruined?
Discussion in 'Newbie Forum' started by Rebecca4846282, Sep 13, 2019.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    That’s a good one:).
    Had me laughing for a bit:ROFLMAO::LOL::ROFLMAO::LOL:.
    Needed that today(y).
  2. Rebecca4846282
    Rebecca4846282 New Member
    United States
    UPDATE. Here is a pic of it. Going to put oil in it tonight and see if it works.
    51,897
    from that pic, it sure looks like it fell out
  4. Mendel Leisk
    41,411
    That pic might corroborate @Raytheeagle 's impact wrench idea.
    RRxing, Raytheeagle and bisco like this.
  5. bisco
    51,897
    are the threads gone too?
    jerrymildred likes this.
  6. Mendel Leisk
    41,411
    I wonder if the blue is old news, or fresh: they strip the bolt, then apply a bunch of goop?
    Merkey likes this.
  7. bisco
    51,897
    is it loctite?
    Merkey and Raytheeagle like this.
  8. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Oh, I thought it was melted blue nitrile glove... But medium-strength Loctite is blue.
  9. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Could be;).
    I’d say they marked it saying it was done, but probably got distracted and then moved on:cool:.
    But at least the threads in the fill bolt hole look fine and not marred, indicating it wasn’t stripped at least :).
    Definitely save that pic for later(y).
    mikey_t, Mendel Leisk and bisco like this.
  10. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    The threads I can see don’t look stripped;).
    It can be done to see if the bolt position has been moved or tampered with:whistle:?
    @Rebecca4846282 , has an oil consumption test ever been requested on your Prius?
    Good luck and keep us posted (y).
  11. Rebecca4846282
    United States
    PROBABLY FINAL UPDATE: we put oil in it. It’s fine. I’m guessing the hybrid battery saved it from seizing or causing any damage because a) it didn’t sound funny when I drove it and b) it switched to the hybrid battery when the light came on. Very happy I don’t have to buy a new car
    Montgomery, benagi, mikey_t and 7 others like this.
  12. Salamander_King
    11,016
    8,948
    New England
    Wow! That's unbelievable, but I am very happy for you.
  13. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Just keep an eye on the oil dipstick for awhile to ensure it doesn’t vanish;).
    Glad it is sorted(y).
    Montgomery and Mendel Leisk like this.
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    @Rebecca4846282
    Please stay in touch with some follow ups. At this point, it's drastically important you frequently check the oil level on the dipstick. If the engine incurred any unusual wear due to the previous oil problem, it will be at the piston rings/cylinder wall where it will show up as oil consumption. Other wear would occur at the main and connecting rod bearings, but this usually results in loud ticking/clacking noises if significant. I'm actually very curious if the Prius has a self-protect mode if oil pressure isn't detected above a safe threshold. If your engine continues to burn no significant oil, then it seems like it might have that.
  15. bisco
    51,897
    congrats!(y)
  16. PriusCamper
    PriusCamper Senior Member
    12,736
    5,152
    Pacific Northwest, USA
    The thread ratio is too fine for vibrations to spin it and that primarily happens with nuts, not bolts...
    cyberpriusII and vvillovv like this.
  17. Mendel Leisk
    41,411
    Besides frequent oil checks, listen too for changes in the way the engine sounds.
  18. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    is that blue stuff a joke?
    if it is a joke who's it on and what's the punch line.
  19. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,155
    1,768
    Mars Hotel
    As Carolyn says, "Who says the Prius needs oil."
  20. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    It happens all the time when the bolts aren’t tightened correctly. That’s why oil change places replace car engines, because they know their at fault.
