My Open EVSE Build Thread
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by trentofdestiny, Nov 1, 2012.
  1. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    EVSE_by_mwolrich - open-evse - A portable EVSE built with an Open EVSE board. - Open Electric Vehicle Supply Equipment (EVSE) - Google Project Hosting
    Scroll to the bottom for some new pictures of 30A OpenEVSEs, using OpenEVSE V4.0 thruhole PCB, I am building for a few members here. I call these builds "10 pounds in a 5 pound bag". You have to become a packaging expert to get it all in. The Anderson Powepole quick disconnects will be mounted below the AdaFruit RGB LCD display.
  2. mrbigh
    3,686
    699
    Long Island, NY
    I like the term "10 pounds in a 5 pound bag".
    52,854
    yesterday, we decided to play golf because it was so nice out. i only had about two hours to charge and thought, 'dang, i wish i had an L2!'
  4. mitch672
    1,077
    198
    Randolph, MA
    You will, soon :) (assuming you have a 240V outlet availble)
  5. bisco
    52,854
    i have the breaker in place. if you have an outlet, it will take me less time to hook everything up than it does to charge the car.:)
  6. mitch672
    1,077
    198
    Randolph, MA
    Yu
    Yup, I have an L6-20R, which is a 240V 20A twistlock outlet for you, the OpenEVSE will have a matching L6-20P plug, plus I have an adapter for you, standard 120V plug to L6-20R, twists onto the L6-20P on the OpenEVSE so it can be used on a 120V standard outlet as well.
    I also figured out a way to put a switch on the ground input on the monitoring circuit, so you can use the OpenEVSE on a GFCI outlet if you have to (a small current is passed from hot to ground, resulting in most GFCI outfits tripping).
  7. bisco
    52,854
    excellent, thank you!
  8. mitch672
    1,077
    198
    Randolph, MA
    Awaiting J-1772 cable for one, and Anderson PowerPole quick disconnects for all 3... But they are completed and tested.
    The small toggle switch seen above the relay connects/disconnects the ground for the L1/L2 sense circuit, as a small current is passed to ground, which results in most GFCI outlets tripping (that's what a GFI looks for).. So it can be disabled if you have to use a 120V GFCI outlet.
    FYI: Leviton is having a %20 off sale until 12/2, use code "cyberlev" on checkout. Received an email with this in it a little while ago, could come in handy if you need a J-1772 cable:
    J1772 Charge Connector and Cable : Electric Vehicle : Leviton Manufacturing
    mrbigh and Tracksyde like this.
  9. lensovet
    2,615
    496
    Burlington, NJ
    Gotta love how the 15A version is more expensive than the 30A one.
    trentofdestiny likes this.
  10. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    Very impressive all around!
    I was considering building my own open-evse unit, but I went the EVSEupgrade(dot com) route instead.
    I ran a 240v outlet to my weather protected front porch last weekend (about $30 for parts- I already had the 40 feet of 12/2 sitting around). For $240 + $30 the EVSEupgrade was the best option for me.
  11. bisco
    52,854
    how is the charging time?
  12. mitch672
    1,077
    198
    Randolph, MA
    240V (L2) will be about 90 minutes, has been consistently for me. One of the above units is yours, just waiting for a few more parts and the Leviton cable to arrive (should be here on Wednesday)
  13. bisco
    52,854
    thanks, i was wondering about robs conversion. i think cheslyn said 2 hours?
  14. mitch672
    1,077
    198
    Randolph, MA
    Evseupgrade is great, the benefit of an OpenEVSE is 2 things:
    1. You don't have to modify your factory provided EVSE, and it can stay in your car for destination charging, no packing/unpacking or forgetting it.
    2. You "own" your own L1/L2 EVSE, which can be used on future PHEVs and EVs, and it's a 2nd seperate EVSE (spare)
    The cost is probably $150-$200 more, so not a massive cost difference.
    P.S. evseupgrade and OpenEVSE at 240V, 12A will both charge the PiP in 90 minutes
  15. ny_rob
    1,968
    814
    L.I.- NY
    I just sent my stock Toyota EVSE cordset in for upgrade today, it will get to CA by Thurs or Fri- I expect it back some time next week. From what I've read (and from my experience w/the 240v ChargePoint station) the full recharge should be around 90min give or take...
    One other nice benefit with the EVSEupgrade is that you can still use the OEM cordset on 120v outlets w/the $25 adapter.
    mrbigh likes this.
  16. mitch672
    1,077
    198
    Randolph, MA
    The same adapter works with OpenEVSE, installing L6-20 plugs on the OpenEVSE, and using that same adapter.
    (Which BTW, are usually $15-$20 on eBay)
  17. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Thanks for the promo code, Mitch! The 15A Leviton cable is on its way! Now, all I need is a progammer, and some time to assemble the thing, I guess lol.
  18. mitch672
    1,077
    198
    Randolph, MA
    No problem, I ordered another one myself...
    Take a peek at the Anderson PowerPole connectors, just installed the first set on one of the 30A OpenEVSEs last night, these are so the J-1772 cable can be "pulled" from the EVSE and disconnect. You make the "pilot" wire (usually orange) the shortest wire, so it disconnects first, followed by the 2 hots (red/ black), then finally the green ground wire is the longest, so it would disconnect last.
    FYI, if you are interested in getting these connectors, they are fairly inexpensive:
    Individual Housings, Contacts & Roll Pins: Separate or extra powerpole parts and components
  19. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I really wish I would have used the box with the clear lid like you did. But I'm not going to add the LCD so I guess that leaves the programmer. Is it better to use a straight FTDI or the Adafruit programmer? Is it even possible to use an FTDI cable to program?
    You know what I should do? Send it to you, have you program and test it, and give you all the extra components I have and 2 other PCBs lol.
  20. mitch672
    1,077
    198
    Randolph, MA
    I could program it for you, not a big deal... The AdaFruit programmer is what I use, that's a kit as well :)
    You need to setup the Arduino environment as well, so you can compile/upload the code.
    Yes, the OpenEVSE V4.0 has the FTDI port, so it's possible to program it that way, but I don't think it can initially be done that way.
    If you want me to program your OpenEVSE, you could just send the ATMEL chip, since I have the same OpenEVSE V4.0, put it on my PCB and program it for you, but you might just want to learn how to do it yourself? :)
