My own personal "gas station"
Discussion in 'Gen 2 Prius Main Forum' started by hiremichaelreid, Jun 16, 2008.
  1. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    I don't like the idea of transporting the gasoline; storage is bad enough, but to have a full gas can on the road is really dangerous.
    I do like the idea of dumping in a full can and not worrying about a fill-up.
    If things get so bad you need to use your stored fuel, forget the darn MPG calculations. You've got bigger problems than that.
  2. hill
    9,036
    Maybe not. Our first Montana home was on nearly 6 acres, & we had a 500 gallon propane tank, that fueled one car, the central furnace, the dryer, the hot water heater, and the emergency generater. But it is DESIGNED for long term storage. Gas can and WILL go bad, if not used (anywhere between 6 to 16 weeks).
    Then theres those 'plastic' containers. Not safe enough. If you have a bunch, they all must be kept in a flamable liquid / fireproof cabinet (or multiple cabniets) to truly be safe. Otherwise, it's simply an unnecessary risk :target:
  3. NotAPriusOwner
    NotAPriusOwner New Member
    U.S.
  4. pviebey
    pviebey New Member
    78
    My only thing here is that you're using a 'approved' storage thingie (either plastic or whatever). I'd be worried for a variety of reasons otherwise, but I think you are already doing that.
    If I read it right, I think one was question to start with was 'how do I transfer the fuel?'. Check out Northern Tool (they also have tanks, etc.) Tuthill Fuel Transfer Pump — 12 Volt, 15 GPM, Model# FR1210CANT | DC Powered Pumps | Northern Tool + Equipment
    I do have a 25g and a 5g portable storage I keep out at my house (well, actually, in a detached barn/garage), since I burn about 3g a week running powered equipment (and, yeah, also as a hedge against the next hurricane...)
    Also regarding the EFuel100, from all I've heard, the Prius isn't certified for E85, much less pure Ethanol. The statement on the website that any vehicle can be easily converted I think has had a lot of discussion in other PrChat threads...
  5. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
  6. hiremichaelreid
    451
    I
    I'll shamelessly repost something I posted on my poll thread:
    I read an interpretation of the Ontario Firecode regs relating to gas ( Storage of Gasoline ). Ontario is adjacent jurisdiction; I imagine my Quebec is similar and perhaps more lenient. Anyway, the interpretation of the code seemed to be mostly common sense, with a few parameters and recommendations. There were very little "You must" type statements.
    For example, they recommend no more than 7.5 US gallons be stored in an attached garage. They also said that more than 7.5 gallons you should store it in a detached (from main residence) structure, protected from light, heat etc.
    I'm currently storing the cans behind the insulated shed I use to "surf the net" and get away from the house/family. It is detached from the house. The cans are covered and protected from rain by an overhang and from the sun by the overhang and some trees.
    Yes, if the shed ever catches fire, the fire may eventually be bigger because of the gas, but that's life, IMO. Not much different than your garage catching fire and stored gas and gas in cars igniting eventually. On the plus side, the shed is well enough away from the house (I think they recommended minimum of 10 feet, but I am about 40-50 ft away), that I don't have to worry about the house and family.
    The also recommend a gasoline fire rated extinguisher nearby, so I'll get one of those.
  7. hkazemi
    hkazemi Junior Member
    I've seen where squirrels (or some other critters) got into a garden shed over the winter and chewed through the bottom corner of a plastic gas can, spilling whatever gas was left over from fall. I wouldn't trust a plastic gas can to survive unprotected. Storing in a cabinet or in a critter-proof container would be important.
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    It's all but impossible for a citizen to have a UST here. There are permits, inspections, and also huge liability if and when the thing springs a leak.
    The UST must be the modern double wall design, with an inspection port to check for leaks from the inner liner. There must be a drywell next to the UST to check for fuel leaks into the soil.
    An AST is the preferred choice here, they are also double wall design. The AST's at my hobby farm are older single-wall that were Grandfathered in. They require routine inspection. On my own initiative I poured a concrete slab with berm retainers and moved the tanks to that area.
  9. BIGGDOGG
    BIGGDOGG New Member
    298
    Morristown,NJ
    be carefull for theives. My parents keep their gallons of gas in their shed with the lawnmower and snowblower. plus they live on a dead end street and own 5 acres and have a huge deer fence surrounding their property so Nobody will be breaking in for 5 gallons. Not yet at least
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    That's a problem here. Gangs from Winnipeg are raiding surrounding farms and smaller communities. In theory there is Gun Control in Canada.
    What it really means is that criminals have easy access to guns, and civillians cannot defend themselves. Forget about the "justice" system, the punks get bail almost immediately especially if they are underage
  11. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
  12. hiremichaelreid
    451
    I
    Yes, critters.
    One of the recommendations was to place all gas containers in a tray that has sufficient capacity to contain a complete spill of at least once container.
    So if 1 can bursts or a critter eats into it, the spilled gas is contained.
    Also, should have sufficient rags or sand or kitty-litter or whatever to cleanup a spill of one full container. Dispose of rags or whatever properly of course.
    Yes, thieves. I'll just keep it hidden. Out of sight, out of mind. My shed hasn't been broken into yet in this semi-rural area, and I usually leave unlocked.
    That said, 100 litres or 25 gallons of gas is worth $132 here in Canadas' capital now, and the cans are worth $60 for a total take of $192.
  13. Fraser
    Fraser New Member
    667
    Navarre, Florida
    Sounds like you have the right ideas on safety, etc. On the basic question of filling the Prius tank, maybe this is a possibility:
    Determine approximate number of gallons you need to fill -- divide mpg into miles driven on the consumption screen. Say it comes out 7 gallons. Pour a five-gallon can into the tank. Power ON, let the pips rise to wherever they will. If it looks like you can fill another gallon or two, do that. (I might suggest having a variety of 2- and 3-gallon cans; your call.) Power ON again. Let the pips run up to where they will. This never will attain mathematical certainty, but it might be close -- besides, assuming you are using this plan for emergencies, at that moment in time your exact mpg probably will not be your primary concern.
  14. patsparks
    10,664
    569
    Adelaide South Australia
    I shall not be engaging in such behaviour. I like my house and I like my family.
    One assumes you also rush to the store and buy 18 loaves of bread and 20 pounds of rice if the weather bureau predicts a thunder storm.
