my Prime sipped some gas today
Discussion in 'Prime Main Forum (2017-2022)' started by MNdriver, Sep 26, 2018.
  1. MNdriver
    MNdriver Senior Member
    549
    577
    I last bought gas in December, and still have about 40% of that tank.
    This morning I noticed a little gas sipping going on according to the monitor. It showed the ICE going on for a couple of seconds; then battery for a minute; then a couple more seconds of ICE.
    Would this likely be because the car is sensing that the gas is getting old? If so, can I prevent it from happening by filling back up now?
    I did blow a little air on the windshield this AM - it's starting to get cold in Minnesota. Didn't use the defroster, though, and the temps were around 40.
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    At some point, it is likely to run for the sake of keeping things fresh. Not sure what the criteria is for this generation though.
    My gas is from mid-July with "only" a distance of 2,500 miles on this tank, so I can't relate.
    Nic Steussy, DLC82SV and MNdriver like this.
    52,895
    could be. it might be a good idea not to let the gas get too old, idk.
    52,895
    pip manual recommends using up gas every 6 months. now that i have a fairly reliable routine, i'm only putting in 3 gallons at a time.
    DLC82SV likes this.
  5. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Make sure you use ethanol free and or staybol additive. That is probably bad gas from Dec
    DLC82SV likes this.
  6. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Remember low fuel in tank allows more condensation in it.
    DLC82SV likes this.
  7. bwilson4web
    16,552
    Only if ambient air can enter.
    DLC82SV and axle2152 like this.
  8. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    The ICE will start under certain conditions even while in EV mode, if the battery pack is too cold, too hot, under heavy current load, SOC is too low, SOC is too high while going down hill/braking, etc. The outside temp being 40 degrees is most likely why the ICE started.
    Not sure what will be the best advice when it comes to those who never drive the car in HV mode, other than don't let the gas sit unused for more than 6 months. If it were me I'd just drive it in HV mode until I needed to fill up.
    DLC82SV likes this.
  9. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Putting 3 gal at a time would seem to provide plenty of opportunity
    DLC82SV likes this.
  10. bisco
    52,895
    prius fuel system is sealed. hopefully, older advice from pre emissions days doesn't apply anymore, but i'm no expert.
    when i was a teenager, i used to drive around with between 0 and one gallen all the time.:p
    Trollbait and DLC82SV like this.
  11. bisco
    52,895
    the problem with plug ins is how long the gas stays in the tank. so you drive a long time between fill ups, or keep topping up after a certain level drop. but there is nothing in the manual for pip except not letting gas get older than 6 months.
    some here recommend a fuel additive like stabil.
    DLC82SV likes this.
  12. john1701a
    12,840
    5,312
    58
    You don't really want to have Winter formula gas in your tank during the Summer and the reverse is true about Summer and Winter.
    DLC82SV likes this.
  13. JonW
    JonW Member
    55
    65
    Texas, USA
    Would this still be the case for people in Texas where we really don't have a winter? It's very rare for us to get below freezing.
    DLC82SV likes this.
  14. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Do they sell winter-blend gas in Texas?
    Nic Steussy and DLC82SV like this.
  15. JonW
    JonW Member
    55
    65
    Texas, USA
    I've never paid attention. Are they supposed to put up signs or something?
    DLC82SV likes this.
  16. axle2152
    266
    210
    Atlanta, GA
    2018 Prius Prime
    No signs, you'll just notice you're getting worse gas mileage and assume it is cold weather...winter blend in warmer weather still yields worse fuel economy...
    Bottom line is folks, if your gas is getting old better burn it up in HV mode or expect repairs on the fuel system. Although the fuel system is sealed, leaky gas caps and so on will eventually occur after some time. The Prime already will get better gas mileage so it takes longer to burn in HV mode anyway. So if you don't drive that much something to keep in the back of your mind...
    DLC82SV and Salamander_King like this.
  17. Salamander_King
    11,024
    8,980
    New England
    Not in areas where I have lived (all northern states). Transitions are seamless. It all happens in refineries, so us consumers at pump are not notified. That said, usually in spring/early summer when they switch to summer blend there is some price hike due to cost of summer blend being higher than winter blend. And opposite is true for winter changeover in fall.
    #17 Salamander_King, Sep 27, 2018
    DLC82SV likes this.
  18. Trollbait
    12,832
    Car fuel tanks are much better sealed than the can used for the lawnmower gas. So fuel stays 'good' longer in them. IIRC, the Volt will go a year between fuel ups before starting a fuel maintenance mode to burn off the old fuel.
    The systems in place to reduce evaporative emissions will stop some humidity from getting into the tank when air enters to replace used fuel. The volatile compounds that came off the gas and got trapped by the carbon canister will come off the carbon and re-enter the tank with that air. The little bit of humidity that gets into the gas will be picked up by the ethanol in most climates of the US. The tank itself is likely plastic.
    You'll see the fuel efficiency difference, but it isn't something to worry about. The difference between the blends is to help older cars(think carburetor) start in winter, to improve emissions, and to let the refineries get rid of stockpiles of less valuable things(butane gets mixed into winter gas).
    Diesel is a different story. Summer bend diesel can gel up in the fuel lines with colder temperatures.
  19. MNdriver
    549
    577
    My friend Mr Google tells me that gas stations start switching over to winter gas on September 15. Think I’ll wait to fuel up until late October. The majority of my gas usage happens in winter when our temps fall below 14 degrees.
  20. Salamander_King
    11,024
    8,980
    New England
    I think you need to fire some more gas before filling up! Sip is not enough, let's have a drink! :p
