My Prius 2005 shuts down on its own
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ruberoid, Nov 5, 2018.
  1. Ruberoid
    Ruberoid Junior Member
    Madison,WI
    I know it's my first post, but I've been on this forum for ages without registering, never had a need to participate in interactions.
    I bought my Prius 2005 in used condition, but as far as I know, besides a road accident, it never had any electrical issues. Yesterday, upon arrival from the store, I removed the key from the socket and left, came back a bit later to empty the trunk, though I couldn't unlock it, I kept pushing on 'unlock' on my keypad, but nothing happened. I immediately inserted the key into the socket and pushed on a brake pedal, but nothing happened, the car seemed DEAD, even headlights! Since it was dark outside, I couldn't do much, so I went back home to get a flashlight. I opened the hood and didn't see any burnt wires or smoke,etc., so I decided to give it another try and inserted the key again and nothing happened, so I pulled it out and suddenly the lights turned on WITHOUT A KEY IN A SOCKET.I put the key back into the socket and I was able to start the car.This incident happened to me again, twice today.Though I was able to finish my errands.
    I am lost, I don't want to drive to a dealership, since I do not trust them. I changed oil 4 days ago and the only thing that I need to do is to change cabin air filter, I was told that everything is in good condition. I was driving in the rain prior to the incident, but there wasn't much rain that day. Any advice is appreciated!
    52,863
    welcome!
    start with the 12v connections. especially the negative to body ground
    make sure everything is clean and tight, and test the 12v health. any idea how old it is?
    after that, look to the accident area for wiring repairs and corrosion.
  3. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Check you 12v battery for state of charge. You're in Wisconsin, so it must be getting cold, a weak battery will be most affected by colder climate. Also, check the connections of your battery for tightness and corrosion, especially the negative end connected to the bare metal of the car body.
    Lastly, check the fob battery, it might be time to change.
  4. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Geez, Bisco do you live on this forum, you're usually the first to answer at all hours of the day. :D
    Raytheeagle and bisco like this.
  5. bisco
    52,863
    shut in:cool:
  6. bisco
    52,863
    wouldn't it be cool to have a screen time counter like a phone?
    Raytheeagle likes this.
  7. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    I think you would dominate.
  8. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    For the OP.
    SFO likes this.
  9. Ruberoid
    Madison,WI
    I checked the 12V battery via hidden service menu. It shows 12.1 and 14.1 in running mode , I don't know if it is reliable, but it went down to It's 30 degrees outside.
  10. bisco
    52,863
    i do not know. i'm only on at lunch and dinner thru bedtime typically. some people are on their phones 24/7.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I wonder who fits that bill:whistle:?
  12. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Just so you know the keyfob in the socket does nothing to start the car. As long as the RFID can be read the car will start. SKS has a more active transponder system so it can be detected all around and from in your pocket. The other low models need a short range. There is a transponder in that socket and also by the power button. So turning on with the key not in the socket is pretty normal.
    Your electrical issues sound like a dead 12v battery. Start there first. Just replace it. 12.1v as you measured is dead. A healthy 12v battery should be reading closer to 12.6v minimally.
