My prius 2012 won’t turn on
Discussion in 'Gen 3 Prius Main Forum' started by Mohammedzayi, Jun 8, 2018.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    To Reboot the Prius. The safest is to disconnect the red cable, the positive , from the positive terminal on the battery. On the negative side I was thinking in terms of removing the the chassis connection. If your careful, nothings going to happen, Rebooting is only a temporary disconnect anyway..
    As far as shorting yourself out thru a ring or watch that takes a special talent. My resistance used to be 165K ohms, I=E/R = 12/ 165,000 ohms = .0001 amperes. As tiny as that is I still don’t make a practice of touching both polarities at the same time. Thru a ring or a watch, conduction doesn’t improve, it’s still 1/10 of a milliamp
    Agree if you’re using a long wrench on the battery, for me, those days are gone forever. If the tool spans the distance of the terminals or adjacent chassis ground, get a shorter tool.
    #21 Andyprius1, Jun 10, 2018
  2. Mendel Leisk
    41,463
    My brain cells can barely comprehend electricity, but there seems to be a lot of internet lore pointing to "disconnect negative first, and reconnect last". This being for the very widespread negative-ground system. One example:
    Replacing Your Car Battery, DIY Battery Replacing | Pep Boys
    I can recall too the first time I purchased a replacement 12 volt, I already had heard it, but the service guys were telling me the same mantra.
    Andyprius1 likes this.
  3. Andyprius1
    2,327
    859
    Cool CA
    I agree with that, but, if either is disconnected and then covered in a plastic bag, then nothing will happen.
    If I’m going to leave a cable off, I always cover it anyway. Including 110VAC.
    Danny33xd and Mendel Leisk like this.
  4. Mendel Leisk
    41,463
    Yeah I stuff loose leads into heavy leather work gloves, keeps them shielded. I hope...
  5. Andyprius1
    2,327
    859
    Cool CA
    Great idea.
  6. fuzzy1
    10,452
    Humans are involved, so that talent is occasionally found.
    The problem happens when that human resistance is completely bridged by an all-metal circuit path, and current suddenly jumps to hundreds or thousands of amps. And it is even worse then the high current creates a minor spot-weld so that the electrical connection gains some mechanical strength, requiring some noticeable force to break loose.
    The wedding ring case happened between electrical terminals at a traditional non-hybrid starter. I don't remember details of the watch band incident. Neither case was bad enough for the victims to have residual battle scars to show off.
    jerrymildred and Andyprius1 like this.
  7. Andyprius1
    2,327
    859
    Cool CA
    Starting current can be enormous 150-300 amps and more with larger truck batteries. we are speaking of a Prius, any year, any model.
    Anybody that works on a live starter is a nut case.
  8. fuzzy1
    10,452
    We are still speaking of general electrical safety. Even a Prius battery can put out damaging levels of current.
    By the time I met him, he had matured into a well regarded mechanical engineer.
  9. Andyprius1
    2,327
    859
    Cool CA
    Glad to hear it.
  10. bisco
    51,944
    that's one reason i have never worn a wedding ring, or any jewelry. table saw is another.
    Raytheeagle likes this.
  11. Andyprius1
    2,327
    859
    Cool CA
    For 20 years while in USAF I always removed my ring, whether in the field or working the bench.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    That explains your closet watch collection ;).
    As long as Mrs. Bisco is ok without the ring, you’re good(y).
  13. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    On the negative terminal first, @fuzzy1 has nailed it. I missed seeing the event, but I did see the nasty burn mark all the way around my father-in-law's wrist when his metal watch band and his wrench combined to complete a circuit between the frame and positive when he still had the negative connected. Musta hurt like a sununvagun.
    On the ring, I'll just tell you about the time in the factory that I went to the nurse's office for an aspirin and she was patching up a guy's left ring finger. She said, "Jerry, where's your wedding band." I held up my hand to show them the tan line and said, "It's in my toolbox with my keys." She turned to the guy she was working on and said, "See?" I think I can guess what they were talking about before I came in. LOL!
    fuzzy1, bisco and Andyprius1 like this.
  14. Andyprius1
    2,327
    859
    Cool CA
    Oh, it happens, no doubt about that. By talking about it we may save somebody.
    fuzzy1 and jerrymildred like this.
  15. jerrymildred
    11,517
    14,152
    Tampa, FL
    Yup. Won't kill you, but it won't be the highlight of your day, either.
