My Prius drifted backward at a ramp.
Discussion in 'Gen 3 Prius Main Forum' started by Troy Heagy, Jul 9, 2014.
  1. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    First, a little truth.
    The Prius system does indeed have "automatic transmission creep" built in. Unlike the ancient design automatics it isn't a disadvantageous part of the operation, it had to be added. And yes, it will hold the car on a -slight- incline. And just like an ancient design automatic transmission, when the slope is steep enough it won't hold the car.
    That's why we have brakes! ;)
    fuzzy1 likes this.
  2. Troy Heagy
    Troy Heagy Member
    1,218
    The slope from US 101 exit ramp to Hollywood Boulevard isn't that steep. My extinct Dodge automatic would have held it just fine. My prius acted as if the EV motor was not turned-on at all. :eek: Freewheeling basically.
    Other topic: I hate driving manual shift in San Francisco. It wouldn't be so bad if I could keep moving, but the city puts a stop sign on uphill corners. Good way to destroy a clutch trying to get the car moving. :(
  3. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Try doing it on a motorcycle... with a passenger. Shoot, Lombard St Downhill... now there is some serious downhill creep!
    Seriously, that's why they added the Hill Assist on the Prius. Works like a charm.
  4. Prius 2014
    Prius 2014 New Member
    Manassas, VA
    Gotcha
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    This is NOT a problem at all.
    It's the responsibility of the driver to know the capabilities and characteristics of the vehicle they are driving. The Prius is equipped with something as mundane as "brakes" and as exotic as Hill Assist.
    With these "tools" at your disposal, if you drift back several feet on a ramp without noticing it? The fault is with the driver not the vehicle.
    xliderider likes this.
  6. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Why would anyone prefer the car to waste electricity holding position on a hill when the car comes equipped with brakes, which are operated mere inches away from the gas pedal? This behavior is similar to the horrible practice of feathering the clutch on a manual car to hold position on a hill.
    Isn't hill assist for those that are terrible at operating a clutch? Very odd that it's included on a car that has an automatic transmission.
  7. Mendel Leisk
    42,383
    The Prius transmission's not bad at holding on an uphill grade. Better'n our last car, with a regular CVT.
    I only need to resort to Hill Hold on insanely steep situations.
  8. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
    I guess it would be easier if you drive with both feet.
  9. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    FWIW the Prius does have a creep built in, I seem to recall its been estimated at about 500W. If you let your foot off the brake on a flat it will start moving forward. If you are on an incline it will either move forward, hold still, or roll back depending on the angle of the incline. Same as an AT.
    Rob
  10. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    I would normally put my left foot on the brake and the right foot on the gas to keep a car from rolling back, but I understand that the Prius gas pedal doesn't work when the brake is applied, courtesy of so called run away acceleration.
  11. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    ^^ Is that really true? Guess I'll try it tomorrow to see.
  12. orenji
    orenji Senior Member
    5,887
    3,490
    You are right, Honda Honda Honda, oh wait where is the insight now!?
  13. MikeDee
    1,581
    597
    Don't back up a grade with a Prius; absolutely gutless. It uses battery only as there is no reverse gear. My front wheels were on dirt and there was a step up to the pavement. I had to almost floor the gas pedal to get the car to move.
  14. MikeDee
    1,581
    597
    Update: I'm not sure this is true. I had my left foot on the brake and gave it gas. The car was trying to pull forward.
  15. orenji
    5,887
    3,490
    Maybe you are driving a JDM model :eek:
  16. Heat Gun
    Heat Gun Junior Member
    56
    Los Angeles, California
    Wow, thank you! that was my wife's only complain (of course about car only :)) )
    KennyGS likes this.
  17. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    My foot generally has two modes of operation. It's either on the gas or the brake pedal and almost any given moment.
