My Prius Eco Mode Not Working after couple of thousand Kilometres
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Umair90, Jan 29, 2019.
  1. Umair90
    Umair90 Junior Member
    34
    Pakistan
    12V health seem fine to me. By the way what’s the best value? I checked mine, i guess 11.something
  2. Umair90
    34
    Pakistan
    I always use 4Litre Engine Oil. Not above that.
  3. Umair90
    34
    Pakistan
    Currently, 12V Battery Health
    51,966
    you need a reading after the car has been off overnight, with a voltmeter. what you're seeing there is the inverter voltage.
  5. Umair90
    34
    Pakistan
    Let me share few things.
  6. bisco
    51,966
    Looks good (y)
  7. Umair90
    34
    Pakistan
    Noooooo. The Gas range is disturbed after Battery negative terminal reinstalled. And it’s not showing the exact Number of Kilometres now.
  8. bisco
    51,966
    It looks like it has just moved one step further with the display button.
    Try cycling through it
  9. Umair90
    34
    Pakistan
    New codes appeared now.
  10. Umair90
    34
    Pakistan
  11. Mendel Leisk
    41,479
    All or most of the codes are apparently about communication loss. Wiring? Connectors? Here's code descriptions:
    B15C1: Open in GPS Antenna:
    1. DCM (Telematics Transceiver)
    2. Wire harness or connector (Telephone and GPS antenna cord)
    3. Telephone and GPS antenna assembly
    U0073: Control Module Communication Bus OFF: CAN communication system
    U0100-211, 530 Lost Communication with ECM/PCM "A"
    The trouble shooting instruction in the Repair Manual are very complicated. If you want I can send you link. Techstream loaded on a laptop is mandatory I think.
    A first step you might do, is just look under the dash, say for botched wiring work, someone installing something incorrectly. Or rodent damage. Or corrosion on connectors.
    #31 Mendel Leisk, Mar 13, 2019
    Umair90 and bisco like this.
