My Prius is bug out ready and set up to be a power generator today.
Discussion in 'Gen 2 Prius Main Forum' started by Kaptainkid1, Mar 17, 2020.
  1. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I have a natural gas generator installed at my house. It uses an Automatic Transfer Switch to make sure I never try to power the house from Grid Electricity and the generator at the same time. Power goes out. the ATS waits 5 second to be sure power is out, then switches, and starts the generator, which gets up to speed in 5 seconds, and I have power again.
    Generac Power Systems - Automatic and Manual Generator Transfer Switches
    These come in various sizes. Mine is a whole house unit, as I am unwilling to give up A/C in MS. Like this, but no Wifi as it is old
    Generac Power Systems - 20kW Guardian Series Home Generator with Transfer Switch - 7039
    This is important so my generator, and your prius, don't electrocute Linemen working to restore power.
    #21 JimboPalmer, Mar 19, 2020
  2. Kaptainkid1
    Kaptainkid1 Active Member
    308
    246
    Los Angeles
    SM-J737T1 ?
  3. Leadfoot J. McCoalroller
    8,074
    7,554
    Pennsylvania
    2018 Prius c
    Guessing that reply was meant for someone else?
  4. George W
    George W Senior Member
    911
    514
    San Antonio
    KaptainKid1
    Is that YOUR video, or are you just handing off responsibility to someone else?
    Kaptainkid1 likes this.
  5. Kaptainkid1
    308
    246
    Los Angeles
    The many Prius owner who have done this mod. You can find tons of videos regarding this set up. It's someone else..
    Here is part 2:
    Watch "Prius Home Generator - Part II" on YouTube
    SM-J737T1 ?
    #25 Kaptainkid1, Mar 19, 2020
  6. T1 Terry
    T1 Terry Active Member
    929
    481
    Please, do not make or use a male to male suicide lead, it is always the innocent that electrocuted, like mum or the kids. Why can't you just plug the power board into the inverter? As you are only using a 1000w inverter, you can't power the house, but you can power the essentials like the fridge/freezer, a few lights and recharge a phone or computer so you remain in communication with the local area.
    Here in Australia we have just been through a major fire season followed by a few flooded areas, now we are getting locked down because of an imported virus, so being prepared if a smart thing to do, but do it safely, a male to male plug is not a safe option in any circumstances, it a dead waiting to happen.
    T1 Terry
  7. George W
    911
    514
    San Antonio
    But yet you refuse to answer my question. Have you done this yourself? Are you going to show us your home installation from your house to your Prius?
  8. CarlB
    CarlB Junior Member
    70
    67
    2020 Prius Prime
    Consider the risk reduction of a robust engineered solution, such the power transfer switches mentioned.
    Consider the risk reduction of keeping the gun under lock and key, until things finally become so dangerous that they represent something real to be protected against. Actual physical threats.
    If your goal is to increase family member's chances of survival, the above will help.
    Mad-Max survivalism should not get you or a loved one killed. It's not helping if the risks created are greater than the probability times the severity of the perceived risk.
    Though your estimate of the probability of risk and severity is much higher than most others posting here, you still do best for yourself making your mitigations safe, and effective.
  9. R-P
    R-P Active Member
    804
    288
    Netherlands
    Let's start by saying: I like your thinking, so view this as constructive criticism.
    Does it have enough power to run your fridge? Compressors (which 99% of household fridges have) can have huge start-up currents up to 10 times their normal operating current.
    ALWAYS, lets repeat, ALWAYS fuse any wiring you use. A fuse near the battery is NOT to protect the equipment, but to protect the car. If a wire in a car rubs on the chassis, the fuse between that spot and the battery should blow long before the cable becomes hot enough to light the car on fire. That is the function of the fuse. And logic dictates that this fuse should be as close to the battery as possible, so there is virtually no unfused wire anywhere in the car.
    My (other) car has an unfused OEM wire between the startermotor+alternator in the front and the battery in the rear. This is NOT fused and poses a real risk even though it is considered to be one of the safer cars in the world... (2004 Volvo). Most newer cars with this setup DO have a fuse, even if it is a 500A fuse (it needs to withstand the starting-current).
    I think enough people have said useful things about this. Even if you think you know what you're doing, others may somehow get in contact with your setup and not know that it is a live male plug...
    My dad had a tube amp and huge (4x4x4' folded horn) speakers, bought from a collegue in the 70's.
    My brother had a party. One of his classmates helped setting things up and saw a 220V~ plug lying around and plugged it in the wall socket. Dad's collegue had build it all himself and used 220V~ plugs for connecting the speakers to the tube amp... The 1970's 12" speaker probably made some noise for a split second before going to speaker heaven.
    (Knowing this is a largely US forum: we had 220V~ 50Hz in the 70's and 80's. They raised this slowly to 230V~ (and lowered the 240V~ of the UK to 230V~ iirc) after this. We have never had 110, 115 or 120V~ during my lifetime).
    #29 R-P, Mar 20, 2020
  10. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    KEEP THE PARANOID BS COMING= &Yes=You've been watching too much of the walking dead!!;)
    Your Prius will get a flat tire and you'll run out of gas in a few days in the middle of nowhere.
    = Then what are you going to do BIG BOY.:LOL:
    #30 ski.dive, Mar 20, 2020
  11. Kaptainkid1
    308
    246
    Los Angeles
    Everyone is correct regarding the dangerous suicide 3 prong plug set up. This set should only be used by experience home owners who know about electricity.
    My Inverter mod is just an example to prove it can be done. It seems many people don't understand once you try to copy or implement this set up you need make sure your power consumption requirements are at minimum under 1000 watt. Also is the wiring in your house is up to code and is wired correctly. Many houses in my neighborhood has shotty old clothes rubber wires. These houses I would stay away and just plug the fridge right into the power cord attached to the inverter and any other devices you want to power.
    EXAMPLE:
    So my fridge is a LG French door unit is under 10 years old and all my housing has new wiring less than 10 years old too. If your house has older wiring can be dangerous and start a fire in your house.
    "GEORGE": stop antagonizing me!
    This is why I'm not going to show more photos about my set up since it may not work at your house. Secondly I bought 2x 1000 watt inverters, 1x from Harbor freight 1000 watts with 2000 peak and that was junk. I test it and it was more like 800 watts and 1600 watt peak and not PURE SINE. The second inverter I bought was from Amazon and that unit was as described. It tested 1000 watts by using my hair dryer no problem.
    Of course I did all this research before implementing this mod on my Prius and at my house. Also I know my fridge only draws 375 watt when the compressor motor is on and it spikes 1200 watt peak at start up for 5-10secs max, then drops to 175 watt for normal use. My 1000 watt inverter has a 2000 watt peak. That means I'm well under the total watts needed to start my fridge. Plus my 75 watt internet modem and my 250 watt 50" LCD HDTV. If I have all 3 devices on it well under 1000 watt continuous.
    So people must do your research about your house set up. How old is your fridge? If the fridge is large vs an apartment fridge? New vs very old fridge? An old 70's fridge can spike 10x the regular draw at start up. So 400 watt x 10. You'll need a 4000 watt peak inverter. My thread can only let you about this mods availability and it's up to read to determine whether it can or should done for your set up and needs.
    I CAN NOT COVER EVERY FACTOR TO MEET YOUR NEEDS! I WILL NOT BE RESPONSIBLE FOR ANY DANGEROUS SHORT CUTS TO MAKE THIS MOD WORK FOR ME. Ie: the suicide plug. The lack of 80amp fuse between the battery and the inverter.
    It's up to the reader to do your own research.
    I can bring you to water and it's up to you whether it is safe for you to drink.
    This is not a DIY thread but if a readers want to chime in so be it and help out.
    SM-J737T1 ?
    #31 Kaptainkid1, Mar 20, 2020
  12. T1 Terry
    929
    481
    Just a note regarding the overload capacity of an inverter. There are two types of inverters in the PSW field, the light weight high speed switching type, and the much heavier transformer type. The high speed switching type can handle a 20% overload for a split second in the cheapie units up to a few minutes in units like the Projecta IP2000, but they aren't cheap. The much heavier transformer type can eat a lot of battery power just sitting idle, but they do have a big overload capacity, over 100% in some models and can maintain that overload for up to 10 mins in some units. The W7 3000/9000 is a good example, not real expensive, can waste up to 2 amps just on standby, but strong as an ox and will start up big loads.
    T1 Terry
    jzchen and Kaptainkid1 like this.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    I don't begrudge anyone in California preparing for Armageddon the shit those people have been through. Not sure why anyone would live there the news is horrific. Kaptain is just getting ready for a bug out. Would any catastrophe surprise anyone at this point?
    You have to get yourself ready and count on yourself there will be no white knight riding in with a bag of food and fuel. Those days are over. Be ready for anything.
    Our Govt has done nothing. South Korea has it more together than ours. Not hard to see why. They reacted.
    WH has there head up there tookus and there incompetence is criminal. The people in charge now are spending there time trying to figure out a way to make money off this suffering instead of helping US citizens. New News report out today that Trump was briefed at the beginning of the virus months ago and did nothing. We could have gotten an handle on this. He Refused to listen to Intel.
    Now we daily get to listen to Trumps ignorant and ridiculous pie in the sky rants then Dr Fauci has to get up there and fix it. Doesn't make you have any hope whatsoever.
    And as far as back feeding the ac panel thats pretty common but not recommended for anyone not well versed in AC. At the least I would put some red tape over the main breaker and breakers not used. Everyone I know here either has a transfer switch or back feeds there panel.
    I'm personally not a big fan of the death cord. I take the panel cover off and have a empty standby 220 breaker that I use as 110V connection point. I just connect both poles together so it hits both sides of the 110V breakers and connect my 110V generator to that breaker. Then all 110V breakers are being fed. I shut off all 220 breakers and any 100V breaker not being used.
    You can use any 220 breaker in your panel just pull the exiting loads off it.
    Every 110V breaker except the ones I need powered are shut off and big red tape goes over the main breaker and 220 breakers not being used. That paralleled 220 breaker is a small load rated breaker 15 amps each pole. But my dual fuel gen has breakers too. So I am double breakered.
    Works great do it every Hurricane. We lost power on my street for 8 days after Erma. Other side of my street came back on after 4 days.
    Idiot at the end of the street rental unit owner out of state let there oak trees with dead limbs get entangled with the power drop to my side of the street and the wind took the tree limbs and our line down. Took Duke a few days to get there and chainsaw this huge tree up and hang a new drop. All in 100 degree heat and 100% humidity and the skeeters were nuts. That's one of the worst parts of hurricanes after there done the humidity and skeeters are intense. Everything is soaked to the bone.
    Pre Storm Duke staged about 400 trucks in our county. Maybe more. Lots from different states.
    Duke was everywhere and I thought they did an excellent job. I took water to them while they were working on my street and there were 6 guys from all over the country came in to help. They said hundreds of lineman came in from all over the USA. Really hard work.
    And now Hurricane season starts on top of all this. Gonna be rough. Don't think Duke is going to come to our rescue like that again.
    So yeah be prepared.
    #33 edthefox5, Mar 21, 2020
    R-P and Kaptainkid1 like this.
  14. T1 Terry
    929
    481
    To be on the safe side, rather than trying to back feed the house power, why not just use a power board and leads to each appliance you need to power. That way you are less likely to over load the inverter and accidentally attempt to power the whole neighbourhood creating a dangerous situation for any line worker who may be trying to repair damaged wiring etc.
    We will be taking our house completely off grid when I get the time available to complete what I started over the Christmas/New yr break. Because we build off grid battery/solar/inverter power systems for a living, we have been flooded with work lately, but mostly for RV's of all forms including houseboats as we live on the banks of the Murray River. People looking to self isolate to avoid the whole thing rather than survive a failure of the basic requirements to live in a house, water, power, sewer etc. You can live quite comfortably from fishing in the river and buying/trading for meat and vegies from farms along the river or on the back roads throughout the country.
    T1 Terry
    Minima Domum and Kaptainkid1 like this.
  15. ski.dive
    964
    244
    CRAZY PARANOID PEOPLE= Thinking the world is ending tomorrow!!!
  16. George W
    911
    514
    San Antonio
    I only asked you a practical question. I'm not the one who actually tossed a taunt your way. However, if you are going to preach to everyone how they can do something, shouldn't you should set the example?
    I'm not going to rebuild a HV battery on the advice of someone who hasn't done it. In contrast, I would consider advice from someone who failed at it, but owned their mistake.
    For your safety, I hope that 2 inverters do not blow the 100A fuse in your Prius. Their combined draw, under rated load, would greatly exceed that number.. You don't say whether you plan to use them simultaneously or if they are as backup. One way is smart, the other way could disable your car. .
    You've got a great rig for mobile self-reliance, but adding the part where you endorse a potentially dangerous install without actually having done it yourself, is irresponsible.
  17. Mac Guru
    Mac Guru Junior Member
    Los Angeles, California
    I'm in LA also. La Palma on the edge of OC. here's my number below. I have some tips on where to bug out to (Friend's ranches at yosemite etc). But my advice is to store all you need up in Ventura county. Maybe we could share a small plot of land and or a storage unit up there. I planned on making a tiny house on wheels up there on land bought at auction. Put some sweet potatoes in the ground at least. they have the most nutrients per ease of growing I hear.
    John 310-429-9391
  18. Mac Guru
  19. Kaptainkid1
    308
    246
    Los Angeles
    We had a black out on Friday which killed power in my neighborhood for 25 hours.
    https://abc7.com/la-power-outage-stay-at-home-los-angeles-pico-robertson-out/6059190
    The Prius Generator work like a charm and it saved all my food. I'm glad I got prepared and did all my work a week earlier. Like everyone I had like 4 weeks of food for the long sleep. I was the only house on the block with lights and power.
    So those who laughed at my mods I laugh last.
    SM-J737T1 ?
    #39 Kaptainkid1, Mar 29, 2020
  20. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    What's the name of the brand of inverter you've up there sir?!
