My Prius is down 4 quarts of oil 9000 miles after oil change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by southjerseycraig, Apr 13, 2017.
  1. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Not even remotely close. You're thinking of the roughly 14-15 pounds (or other mass unit of your choice) of air per pound of gasoline. A pound of air occupies a lot more volume than a pound of gasoline.
    fuzzy1 likes this.
  2. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    He's probably referring to stoich air fuel ratio 14.7:1
  3. MeGuinness
    MeGuinness Member
    217
    78
    UK
    2010 gen3 210k on the clock.....6k done from last service and the low oil warning light keeps coming on everytime already when I go around a roundabout or when I brake hard.....JUCYYYYY lol
  4. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    You better check your oil or have it checked. Pronto. Your car may be burning oil the way mine is.
  5. southjerseycraig
    438
    107
    Cherry Hill, NJ
  6. southjerseycraig
    438
    107
    Cherry Hill, NJ
  7. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Is been the same from the past 60k...It burns alot of it ...can the pcv valve been not working?
    Why the duplicate posts ??
  8. southjerseycraig
    438
    107
    Cherry Hill, NJ
    My apologies. The board wouldn't post my message, so I tried again several times.
  9. Mendel Leisk
    41,448
    The warning is "low oil pressure", but it is pretty much synonymous with low oil level. Have you been regularly checking and topping it up?
    How many miles again? I recall you were having your share of woes, just can't remember the particulars.
  10. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    when the oil light comes on the pressure is way low & the oil level is already low low //
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    +++++1 on that. I've had the wonderful experience a few times of checking oil on different cars and there's nothing on the dipstick, but still not low enough to trigger the warning light.
    About 10 years back, I purchased an old 1975 right hand drive postal jeep from a seller in St Louis. Towed it back to Columbia, SC using my old reliable 1995 F150 with 260+k miles on it, a 300 I6 and dual fuel tanks. The mountains were tough on that poor engine. When I got local, I stopped for gas. I turned down the radio and all I could hear was a loud clacking noise. Uh-oh....checked the oil and oops. Took 3.5 quarts to get back in the lines. Found that all the piston ring blow-by had actually popped the oil pan gasket out over a section about 4 inches long. The front of that jeep and the U-haul tow dolly were very well lubricated. Thought for sure she was a goner. The truck didn't even blink and is still going today with 290k. Just put a new battery in it about a month ago.
  12. MeGuinness
    MeGuinness Member
    217
    78
    UK
    The car as 210k on the clock,it started consuming oil from when it was at around 160k..... I now do a full change of oil at about 7k to 8k .
    Other problems are a rattling sound at low speed on acceleration from somewhere under the engine or the back of it ,it sounds like a diesel car noise if you know what I mean,it goes mostly away if I unplug the egr valve.
    amos likes this.
  13. tvpierce
    tvpierce Senior Member
    951
    882
    Maine
    2013 Prius v wagon
    The low oil pressure light should not be used as a reminder to add oil. It should be viewed as an alert that the engine is experiencing irreparable damage due to oil starvation.
  14. amos
    amos Active Member
    372
    283
    los angeles
    Other problem ? Seems like its more than just other problem.
    many of us had this other problem . ended in replacing head gasket.
