My prius lost its power while driving this morning!
Discussion in 'Gen 3 Prius Main Forum' started by G3priusV, Jun 1, 2010.
  1. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    my car is a gen II. i know what caused my incident. i had a jumper boxed hooked up at the time (12v battery was dead).. as i turned the corner, the jumpers shorted and everything turned off. (it was a really dangerous turn with a cliff on the opposite end.. no rail guards.. and a fire truck in the opposite lane!) my car coasted as if in neutral and i was able to finish the turn (uphill) and pull to the side. power steering went out, and brake assist went out.. it wasn't hard to keep control.
    your scenario sounds like something new...
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I think you had a one time electronic glitch. The important thing is, you bought it to the dealer and you have documentation in case of a future occurance. The car is still warranted. Electronics, computers are weird, and the Prius is still a new and experimental and full of electronics.
  3. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    It's odd.
    If I were the owner, I would not feel scared, but definitely pissed off!
    And there is some of my understanding of many posts referring unexplained malfunctions over the Prius. Sorry if I may look too hard on these posts/threads. I read too many times "scared"...
    51,948
    this happened to me as well. it's u/d and i now drive only in the right lane in case i need to pull over quickly. luckily, it still coasts and the brakes don't apply!
  5. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    How long did the car traveled from the time the engine quits or lost power to a full stop?
    At what speed you were traveling?
  6. bwilson4web
    16,217
    I'm curious about this:
    Did you feel like there was a braking action going on?
    Was there a loss of power and you applied the brake to come to a complete stop?
    Flat or up grade or down grade?
    This would be scary but I've only experienced the loss of motive power when the car runs out of gas and the traction battery state of charge drops too low.
    You mentioned an "oil" warning light came on later, sorry for the quality but one of these:
    Thanks,
  7. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Years ago the family car lost power going freeway speed and it was a conventional car. Maybe it was a freak thing but this shows it isn't unique to hybrids or a car full of electronics.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Well, to me it's pretty simple. In a situation like yours, you can't afford to ignore the problem. Even if nothing is able to be discovered you owe it to yourself and your potential safety to have it checked out. If you have future problems, you want it documented that you tried to find resolution and were having problems anyway.
    So take it to the dealer and hope it's something easily discovered and repairable. You are under warranty...good luck.
  9. Sneezy
    Sneezy Member
    185
    Upstate NY
    From what has been explained to me, Toyota does NOT have a limp home mode when a short or fault is detected. GM does.
    Toyota monitors some systems but not all hence the pedal issues. A limp home mode should be required on all cars today when a short or fault is detected.
    Again, this is what has been explained to ME. While I think it is true, I can't prove it.
  10. bisco
    51,948
  11. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    Not according to some of the videos Toyota put out after the whole Sudden Unintended Acceleration stuff started hitting them hard; they showed a simulator and talked about various conditions where the engine would either be shut off or go to limp mode, depending on whether it was safe or not. (The videos were not specific to the Prius, but it's not clear whether you are talking about the Prius or Toyota vehicles in general.)
  12. G3priusV
    G3priusV Member
    131
    17
    UT
    Yeah, tell me about it! Wish it warned me before it happened but nothing was lit before or after the incident except that 'Oil maint. required' big rectangle message showed up when I started the car a couple of hours later and I really hope this didn't trigger the stall and I hope it won't happen again every 10000 miles? :)
    But anyway, since then, I've driven the car for about 100 miles with no problem and I still do love my car as no other kinds of car can beat its great gas mileage and special perks like HOV lane and clean air car parking lots! :)
    iPhone ?
  13. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Most trolls don't make 80 posts over a period of 8 months before the decide to say something bad about the Prius. Not everyone who has a problem with their car is a troll. One of the most useful functions of sites such as this one is people posting their problems and, hopefully, finding solutions. The same kind of thing could happen to you or me and we might be glad to read we were not the only ones with the problem. We might even find a solution.
    If this site were only a Toyota love fest none of us would learn anything. :)
    2 people like this.
  14. G3priusV
    G3priusV Member
    131
    17
    UT
    Am I a troller? No!
    Did it really happened to me? Yes!
    Hope it will happen again? Noo!
    Hope it doesn't happen to me again and anyone else! :)
    iPhone ?
  15. Sneezy
    Sneezy Member
    185
    Upstate NY
    According to independent tests, Toyota in general.
  16. bisco
    51,948
    sorry! just wondered where you disappeared to.:rolleyes:
  17. andyprius
    2,212
    188
    Years ago, I had a Peugeot that apparently had a limp home mode, I could drive by moving my feet thru the open floorboard, I could not go too fast and sometimes the cars behind me would get impatient. This was at Wiesbaden Air Base in Germany. Fortunately this was only a recurring Dream. I never did figure it out.
  18. bisco
    51,948
    what would make the car just stop when traveling 35-40 mph? i would think you could coast over to the shoulder?
  19. derkraut
    derkraut Member
    299
    28
    SAN
    I'm thinking the same thing. Maybe you inadvertently bumped the lever while engaging the cruise? Or adjusting a radio knob? I'd call the dealer and explain the occurrence to them; see what they want you to do.
  20. derkraut
    derkraut Member
    299
    28
    SAN
    You must be joking, Bisco? If you feel that paranoid driving a Prius, I'd suggest you get a HUMMER.:confused:
