My Prius needs a battery, Toyota denies warranty due to EV button
Discussion in 'Gen 2 Prius Main Forum' started by naterprius, Jul 19, 2007.
  1. Winston
    Winston Member
    614
    SF Bay Area, California
    In my mind it seems pretty clear why Toyota does not want to warrant a Prius with an EV switch in the US. Here is my reasoning.
    1. One of the main worries of US customers is that the batteries will wear out, necessitating an expensive replacement.
    2. The more that you charge-discharge (cycle) the battery the quicker it will wear out. Toyota has done a lot of things to increase battery life in the Prius. Mainly they restricted the battery charge range to 40-80 percent, and the computer actually tries to keep it in the middle.
    3. Using the EV switch can cause you to increase the level of charge-discharge when driving the prius. That WILL make the battery wear out a bit sooner. It won't make it fail right away, but the batteries life WILL be reduced.
    4. By trying to deny warranty coverage on cars with EV switches, fewer people will install the switches. Thus, overall, Prius batteries will last longer. ie. longer "mean time between failure" (MTBF).
    5. The fewer Prius batteries that fail, the better reputation the Prius car has.
    My 02.
  2. sparkyAZ
    sparkyAZ übergeek
    311
    Mesa, AZ
    Toyota USA makes no secret of it's view of the EV button:
    Reference http://www.toyota.com/prius/faq.html
    " 25. Does Toyota support the modification of my Prius to be a plug-in Hybrid and run on electric mode only with a switch?
    Any such alterations, modifications or tampering with the vehicle voids the warranty and is likely to be counterproductive for air quality and Prius’ durability and safety."
    Still, for most it's not a matter of air quality or trying to get a higher mpg. There are times I don't want the ICE to kick on unnecessarily when moving the vehicle short distances. I plan on adding it to mine even though it's still under warranty. I'm putting a quick disconnect connector behind the EV button and popping it out before it goes in for any dealer service. If anyone wants to donate a JDM button for my mod, let me know. :rolleyes:
  3. jk450
    jk450 New Member
    55
    <div class='quotetop'>QUOTE(Frank Hudon @ Sep 12 2007, 10:28 AM) [snapback]511249[/snapback]</div>
    Which is not common in the automotive world, though it does happen more and more since the introduction of OBD-II. Do remember, though, that Prius vehicles with EV buttons are from other countries, which have different emissions cycles.
  4. wogue
    wogue Lexus CT200h
    61
    EU/Austria
    <div class='quotetop'>QUOTE(priusmaybe @ Jul 20 2007, 12:32 PM) [snapback]482137[/snapback]</div>
    well well well. lucky you!
    i always thought the ev button we have here in the EU is nice but may damage the battery.
    how often did you use it? and even more important: how intensive did you use it? meaning: did the system have to activate the ICE after a "long" electric ride or did you just use it to drive a few silent meters?
    thx and kind reg.
    wogue
  5. Virodeath
    Virodeath New Member
    102
    NW Indiana
    WoW reading the first post I am left wondering... When I bought my 2005 Prius the dealer said a replacement battery was $500 when it goes bad......
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(Virodeath @ Sep 18 2007, 07:18 AM) [snapback]514213[/snapback]</div>
    LOL! Add it to the list of made up stuff/lies told by dealers.
  7. Virodeath
    102
    NW Indiana
    Well that BS I didn't go with the extended warranty because the battery was so cheap to replace should it go bad (not the only reson ofcoarse) and was told that it would be good for 150k miles atleast...... Now I am pissed...
    Viro
  8. HeyKB
    HeyKB Not so new member
    108
    Philadelphia, PA
    <div class='quotetop'>QUOTE(Virodeath @ Sep 18 2007, 08:44 AM) [snapback]514221[/snapback]</div>
    The extended warranty wouldn't help you in any case. Do you know that the standard battery warranty is 100,000 miles and 7 years?
    So you made the right decision for the wrong reason. B)
  9. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    <div class='quotetop'>QUOTE(HeyKB @ Sep 18 2007, 09:34 AM) [snapback]514329[/snapback]</div>
    No, the standard battery warranty is 8 years/100,000 miles, except in California and other CARB states, which have a 10-year/150,000-mile warranty. I think you're confusing it with the Platinum Extended Warranty, which can be up to a maximum of 7 years/100,000 miles (but covers more than just the battery).
  10. Bob Boyce
    Bob Boyce New Member
    Turtletown TN
    2003 Prius
    Hello Nate
    Pardon me for the question, but where were you able to find and purchase the factory EV mode button from? I would like to install one if I can get it, as I really want this to look factory for aesthetic reasons. If I have to, I know I can just drill a hole for a pushbutton in one of the blank cover plates, and run a wire to the ECU connector. But I know it won't look as good ;-)
    I just aquired this 2003 Prius on sunday, and it is out of warranty at 110K miles. I hate to have the engine start and warm up for short trips to the mailbox and back, and I know that the battery bank would get plenty of charge from the once or twice weekly Dr appt trips. Being disabled makes walking to the mailbox and back something that I just can't do.
    I have plans to convert this to a plug-in hybrid, so I will be doing a lot of reading. Would love to charge this car from the PV solar power system that runs my house.
    Thank you in advance
    Bob
  11. efusco
    19,891
    1,196
    Nixa, MO
    Bob,
    sigma automotive sells the EV button...but it won't do you any good if you have an '03. The mod only works on the '04+, The '03 and earlier were not programmed for that functionality.
  12. Bob Boyce
    Turtletown TN
    2003 Prius
    Thank you Evan
    Been a long time since I have been to this site and have learned a lot about the Prius since asking that. I now have a pair of the NHW-11s, and bought 3 very good spare HV battery packs for them from salvage yards. I bought a full manual set from Toyota, and located the HV ECU to Engine ECU harness wire that allows the engine to be switched off for EV mode operation. I tested it and it worked, but decided not to implement it long term after considering how it would likely impact the service life of the HV battery. I am up to about 158K miles now on that original battery and it is still going strong!
    I did discover a way to implement lower cost PHEV using spare HV batteries when I was testing one in a NHW-11 while the original HV battery was still mounted. It requires data switching, but essentially you can parallel most of the HV battery connections. The data path is split and data allowed to flow from the HV ECU to all HV battery ECUs at the same time. This keeps them all synchronized and responding to the HV ECU. However, only the active HV battery ECU is allowed to actually communicate back to the HV ECU. All onboard HV battery packs can be carefully charged fully via external power, then used one by one until all are equal in charge at normal hybrid operation levels. I do not recommend running any of the HV battery packs any lower than Toyota permitted in order to avoid HV battery damage. When a HV battery ECU detects full charge condition however, the will NHW-11 operate primarilly in EV mode to dissipate the excess charge detected.
    Bob
  13. Mjolinor
    Mjolinor New Member
    229
    Greece
    2002 Prius
    Do you have any specifics about this, which wires etc.?
    Scrap Prius in the UK are as rare as hens teeth but you do get them occasionally and, time permitting, I will get stuck into making EV mode work on a mk2 (NWH11)
  14. bwilson4web
    16,138
    Actually it has a use for auto-stop when the vehicle is stopped and the coolant is less than 70C. This would avoid burning gas when stopped at a light.
    Is it a 'level' signal or digitally encoded?
    You don't get an error code when using it?
  15. Floyd2
    Floyd2 progressio per sententia
    106
    23
    Netherlands, Europe
    From what I've heard the EV button had to be left out due to a class act between GM and Toyota. GM claimed the Prius would be an Electric Vehicle as well as a Hybrid car.
    So it seems you owe the lack of an EV button to GM. For the record: this is hear say but it sounds credible.
    I'm glad the EV button was standard on mine, makes it much more fuel efficient.
    The Prius system is designed for use of EV mode, the US version just as well. The only thing different in the US model is that the button and a single wire are simply not there.
    Toyota knows this and that is probably why Naterprius got his battery for free after all.
    Anyone who added the EV button themselves and having problems with the battery, simply switch the button temporarily for a blank before taking it to the dealer.
    Glad it turned out well for Naterprius in the end.
    Floyd, Netherlands
  16. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    My Prius needs a battery, Toyota requires appeal due to EV button
    Nate, congrats on the positive outcome and I'm sorry for your pain.
    I am a bit curious about your battery condition and premature failure. I take it that you probably have more EV experience than most of us, so what follows is more of a generalized thought than my opinions on your particular issue.
    What has me curious is that fact that your battery fans came on. I have had that happen and did some simple mods to fix it. Turns out that the inlet vent wasn't getting good airflow into the battery, so I moved the car seat to the other side of the car. Also my trunk well was full of stuff. This had the effect of putting a blanket over the battery. It kept the heat in and made it harder to vent. The third aspect to the problem was high amp assist and high amp regen. To fix the trunk well, I simply removed it and kept the back uncovered for a few days. Battery cooled much quicker and wasn't going all thermal nearly as often. My trunk now holds nothing! Ever!! Eventually I hope to be able to read battery temp without a CanView so I can keep a better eye on it. And as for the heavy Amp regen and assist, I just baby her a bit more so I don't encounter those situations as much. Makes me bit more pokey on the on ramp, but there you go. Now my battery rarely gets outside the blue range now.
    As for the EV mod. I almost hired my dealer to install it. They certainly offered on multiple occasions. In the end I opted against it. I think they were gonna charge $250 labor to do it and that's when I decided against it. My dealers policy is that if it's a Toyota part, they will install it. Since I got the sigma OEM button it qualified as a "Toyota" part.
    I think Toyota would still shy away from a media circus but it's such a technical issue for the average couch potato, that they may just roll their dice with the PR department leading the charge.
    As for my info on why EV was left out in the US. I was told it was to simplify emissions testing. EPA had a fit over the EV button and Toyota found it easier to cut a wire than to fight the US bureaucracy.
    11011011
  17. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Dan, Nate hasn't been around for over a year and a half (unless he's lurking).
  18. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    Yes but anyone with a Rav4EV marks high on my envy-o-meter ;)
    11011011
  19. Floyd2
    106
    23
    Netherlands, Europe
    I bought mine a few weeks ago and have used 63.5 MGP on average until now. Others told me efficient and experienced use of the EV mode can increase that to over 65 and almost reach 70 MPG on the standard P2 version.
    Don’t know if this will have a negative effect on the battery or it’s life expectancy Dan. I don’t think Toyota would take a risk adding this button unnecessarily, thus receiving more claims about worn down batteries within the warranty period. Warranty here is 9 years and up to 180.000 kilometers, that’s about 105.000 miles.
    You can easily install a button yourself, seach for calcars and EV button. The have a nice howto PDF on their website. It’s a matter of one single wire (unfortunately from the back) and a simple button. Would save you $ 250,-. Maybe there's even an unused wire in your version, I don't know.
    Your envy-o-meter? Seems to be a downside to the Euro version after all, we only have the odometer. :D
    Floyd
  20. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    I doubt EV mode would have much effect on battery life. It uses the same operating profile, with the low SOC the same as in hybrid mode.
