my prius not reliable any more
Discussion in 'Gen 2 Prius Main Forum' started by brucefern, May 28, 2007.
  1. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(galaxee @ May 28 2007, 08:08 PM) [snapback]451278[/snapback]</div>
    Duh. Of course. There would still be 12v at the battery cables coming from the 200v system.
    Although I assume the 200v system only charges the 12v periodically, on and off as necesary. So if the 12v battery disconnected momentarily, wouldn't all the 12v equipment see a momentary power loss?
  2. brucefern
    brucefern New Member
    <div class='quotetop'>QUOTE(Rick Auricchio @ May 28 2007, 09:51 PM) [snapback]451272[/snapback]</div>
    hi Rick
    now that you mentioned it ,there was a flashing sign on the road warning "rough road ahead 5 miles " on the 680 .i can remember going over atleast 1 bump . if it was within this 5mile patch that the failure happened, (cannot say for certain but yes this could be a possibliltiy) . I did not release the gas pedal during this time. Also I Wasnt paying attention to the display. I exited and pulled over there was a sign board saying 3mile to Mt Diablo .I had completed the 10K service a week ago and did 390 miles without any hiccups.
    Bruce
  3. landstander
    landstander darling no baka
    108
    A place where the nuts hunt the squirrels
    <div class='quotetop'>QUOTE(brucefern @ May 28 2007, 05:04 PM) [snapback]451133[/snapback]</div>
    You do realize, I assume, that this board isn't actually run by Toyota... calling for "a complete investigation" here won't initiate anything of the sort. You didn't say if the car was taken to the dealer for troubleshooting, but that's most likely what would be required to get any official action moving.
    I don't mean to downplay the numerous helpful responses that you've already received, of course.
  4. richard schumacher
    7,683
    1,066
    United States
    You may have bumped the shift lever while/after adjusting the A/C. You would not have been the first one to do that.
  5. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    This could happen in any car, at any time. It happened on my '85 Mustang, at 10 pm on the 118 freeway a few years ago. Do you think all the broken down cars, many of them new, are parked along the freeways to enjoy the view? I also had a rented RV that blinked the alternator charging light, and died on Hiway 99 near Delano in the middle of the night. What makes you think the Prius is a SUPERCAR ! that will never die at any time at any place? Just like power outages, PC crashes, s*** happens. Take it to the dealer and get it checked out.
  6. brucefern
    <div class='quotetop'>QUOTE(landstander @ May 29 2007, 07:59 AM) [snapback]451407[/snapback]</div>
    hi All
    the dealer said there was no code stored and nothing is wrong with the car
    B
  7. priusincc
    priusincc Member
    332
    16
    NV
    Would be interesting to see what dealer will say about incident. The 07 owners manual says car is equipped with a "black box" recorder something like a commerical airplane. I wander if that would record anything significant in this case? Don't know if 06 has it. Also, don't know who would have access to the recorder.
    Update:
    Missed the reply from brucefern, scratch the recorder idea.
  8. rachmaninoff
    rachmaninoff New Member
    25
    perhaps i am misinformed but my dealer told me specifically after i signed that i should never fill up with premium gas. infact filling up with more than regular on a regular basis was decidedly bad for the prius.
    is this false?
  9. dogfriend
    7,512
    1,191
    Carmichael, CA
    <div class='quotetop'>QUOTE(Prius Toric @ May 30 2007, 05:43 AM) [snapback]452009[/snapback]</div>
    In the Toyota service manual, it specifically notes that using Premium gas (aka 91 octane US) may cause starting issues. It also notes that starting issues will be more problematic than a regular car because the Prius starts the engine more often (whenever the HV ECU commands).
    There is no advantage to using Premium gas because the engine is designed to use Regular (87 octane US).
  10. rachmaninoff
    25
    <div class='quotetop'>QUOTE(dogfriend @ May 30 2007, 09:54 AM) [snapback]452039[/snapback]</div>
    so maybe this could be an issue for the OP? vpower, atleast at my shell station is 93 octane. you might want to try using the right octane gas in your prius
  11. brucefern
    <div class='quotetop'>QUOTE(Prius Toric @ May 30 2007, 09:51 AM) [snapback]452064[/snapback]</div>
    Toyota is going to have a prius specialist look at the vechile at the dealers
    Kudos to Toyota for the effort
    Bruce
  12. hill
    9,014
    This guy "Jay" ... who works w/ me sometimes. Yesterday, May 30th 2007 ~ he had a massive heart attack after going to the hospital for what he thought was a panic attack. Spent 10 minutes in the waiting room. Then BOOM. Flatline for 5 minutes. They barely managed to bring him back. HE almost died.
    Years ago, I had a motorcycle rear tire blowout on the freeway doing 70mph. Fishtailed over all three lanes of the 5 freeway, but managed to NOT go down. Walked away. I did NOT almost die. Right? I would have at least had to have hit the ground, or gotten run over by the 3 lanes of cars behind me.
  13. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Where we are so far in the informal investigation here:
    - No code stored, which isn't a surprise;
    - Possible VSC/traction control triggered by the rough road, causing the power loss. A good bump across the road (like where they stop paving progress) will almost always trigger the VSC. Maybe this is the most likely cause?
    - A momentary ICE problem caused by the high-octane fuel (though the engine would always have been running at freeway speeds). It could have hiccupped and wouldn't restart till the next power cycle.
    - The 10K service would not be a factor, since it was over 300 miles earlier.
  14. hschuck
    hschuck Member
    385
    bay city, ca
    <div class='quotetop'>QUOTE(Rick Auricchio @ Jun 2 2007, 11:00 AM) [snapback]453967[/snapback]</div>
    Why do you not include the accidental shifting to reverse or park; this, as suggested by several posters, matches the symptions and is also in line with the drivers fiddling with the A/C at the time as.
  15. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Sorry, I forgot about the possibility of accidental shifting.
  16. zang
    zang New Member
    28
    <div class='quotetop'>QUOTE(brucefern @ May 28 2007, 09:40 PM) [snapback]451268[/snapback]</div>
    i
    In the rare case of Park or Neutral engaging by accident on the freeway (or elsewhere) while driving, what's the fastest way to get power back on? I'd like to practice this so in the event of it happening I'll know what to do...
    Thanks, newbie
  17. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    <div class='quotetop'>QUOTE(zang @ Jun 3 2007, 12:20 PM) [snapback]454494[/snapback]</div>
    Apply the brake very briefly--just long enough to shift back into D--and you'll be on your way again. No need to shut off the car and restart if the car is just in Neutral.
  18. zang
    zang New Member
    28
    <div class='quotetop'>QUOTE(mcbrunnhilde @ Jun 3 2007, 05:05 PM) [snapback]454584[/snapback]</div>
    Thanks, I think I'll practice it. Zang
  19. hschuck
    hschuck Member
    385
    bay city, ca
    Nothing is required except to shift to drive. You can shift in and out of neutral at any time while in motion; it does not matter how you got to neutral.
  20. geeky teacher
    geeky teacher New Member
    393
    West Suburban Chicago
    My husband is 6'2". We had the Prius for two weeks. Halfway through a 5 hour interstate drive he lost power. We had a few seconds of confusion and some mumbling, including the words "lemon like the Chevys" before I noticed his knee had shifted the car into neutral. I knew that was a possibility having read about it in PriusChat. Thanks to all who share info and entertainment!
