my prius not reliable any more
Discussion in 'Gen 2 Prius Main Forum' started by brucefern, May 28, 2007.
  1. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    <div class='quotetop'>QUOTE(hschuck @ Jun 3 2007, 09:05 PM) [snapback]454790[/snapback]</div>
    Y'know, I never go into neutral--maybe you don't have to use the brake to get into drive from there. I guess you can put it into neutral on purpose and try both ways (hold the shift lever to "N" for several seconds to put it into neutral). I always go to drive from park, and you do need to use the brake there.
  2. rachmaninoff
    rachmaninoff New Member
    25
    <div class='quotetop'>QUOTE(mcbrunnhilde @ Jun 4 2007, 03:27 AM) [snapback]454850[/snapback]</div>
    I use neutral sometimes if i got a long shallow downhill road and i dont feel liek feathering the while way. you do not need to use the break at all to go from neutral to drive again. it goes in and out smoothly.
  3. brucefern
    brucefern New Member
    <div class='quotetop'>QUOTE(Rick Auricchio @ Jun 2 2007, 10:13 PM) [snapback]454183[/snapback]</div>
    hi Rick
    accidental shifting ruled out there no way this could have happened
    i can double confirm with my passenger
    Bruce
  4. richard schumacher
    7,683
    1,066
    United States
    Impossible to diagnose now without seeing the cabin video or the black box data. Let us know if it happens again.
  5. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    Notice how we haven't heard from the original poster in a week. Guess he's scared to post "Oops! Looks like... heh heh... it was my fault after all."
  6. dogfriend
    7,512
    1,191
    Carmichael, CA
    <div class='quotetop'>QUOTE(Stev0 @ Jun 7 2007, 07:30 AM) [snapback]457305[/snapback]</div>
    Actually, he just posted yesterday; two posts above yours.
    When trying to do failure analysis, it is sometimes useful to try to recreate the fault under the same conditions. It occurs to me, that someone could try to duplicate the same conditions as much as possible. According to the OP, the trigger for the malfunction was changing the A/C settings. (however, it may have been coincidental)
    The only anomaly was the possible use of 91 Octane fuel instead of 87 Octane fuel. The Tech Training manual indicates that this may cause starting problems.
    It would be possible to try to recreate the situation using both 87 Octane and 91 Octane fuel .
  7. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    <div class='quotetop'>QUOTE(dogfriend @ Jun 7 2007, 09:47 AM) [snapback]457322[/snapback]</div>
    You're right (my fault, probably did typo in search).
    Well, we'll just have to see what the Black Box says...
