My real-world experience with the PHV
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by TonyPSchaefer, Jul 13, 2010.
  1. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Yes and closely. Applaud the good and criticize the bad. This whole experience is more than just "just a guy a car" but more like, "give a guy in the middle of the hybrid community a car and give enthusiasts a lot of stuff to talk about."
    Rookie. :(
    Also, if anyone would like to present a topographic elevation study of the course I think you would find some serious hills on the Southern side. Every driver I spoke with was taken aback by them. And as I wrote, lugging a couple hundred pounds of dead batteries up those hills was not a lot of fun.
    S Beltline Ct to S Beltline Ct - Google Maps
    Perhaps I wasn't clear. I had already driven home which depleted the pack and heated the ICE. So it was not technically "the first 5 miles."
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Which is why we like Toyota so much. Doug is alright too.... :p
  3. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Like many people, I'm sure, I'd also have no trouble using a long grade to fill up whatever battery capacity was available. It makes sense to me that the entire battery array could be charged fully by whatever means are available, but I don't know enough about it to say Toyota's doing it wrong. :)
  4. TonyPSchaefer
    14,816
    2,501
    66
    This topic's been all over the place so I forget what's been said and what hasn't.
    I want to believe that for production, there will be a single pack and that the pack would be fully rechargeable. In my opinion, I'm thinking that this PHV is using the existing system and the plug-in is just an add-on. In other words, the best they could do with the time provided. I'm really hoping that right now there are smart engineers working on a 3kWh battery pack that is capable of plug-in charging and regen. As I said, Toyota clarified with me that the plug-in batteries can accept regen as long as they are online. So the capability and technology is there.
  5. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Given what Tony just theorized, I wonder if the question is one of protecting the batteries. How many charge/discharge cycles can the current hybrid battery go through before you start noticing a capacity drop? Obviously a lot, especially with the sophisticated battery management they have in place. How many can the two lithium battery packs go through before you start to see a decline in capacity?
    In changing the battery chemistry used, they have to understand the change in properties. Having the cells be non-rechargeable would help to extend battery life.
    Just a thought... one I'm not to fond of, but a possibility none the less. I hope Toyota found a way around that problem with Lithium batteries :)
  6. mrbigh
    3,686
    699
    Long Island, NY
    How many charge/discharge cycles can the current hybrid battery go through before you start noticing a capacity drop? ...............
    The current NiMH cells manufactured by Panasonic are warranted by Toyota for up to 7 to 10 years depending on the geographical location.
    Example, recharge daily x 8 years =2,920 times.
    On the additional Plug in pack, if LiON is being use and if we have the specific type of LiOn cell used in the extra pack, will be easy to determine.
    As a reference, A123 are expected to last at least 3000 charging cycles. These batteries are being manufactured in China. But Panasonic has been the supplier of choice for the Hybrid series of vehicles.
  7. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    My thought is that the current setup will help keep initial cost down as there's less risk for Toyota:
    - The heavily-used HEV pack is the tried-and-trusted NiMH
    - The lithium batteries will be used a lot less than the NiMH: that should protect them and reduce warranty failures. An additional benefit of protecting the battery is that warranty failures are more obviously going to be due to problems with the battery instead of use.
    - In case of failure they'll only have to replace a 1.5kW pack instead of 3kW.
    In an accident it should also be easier to protect two smaller packs than one larger one.
    I hope that it's a conscious choice instead of due to engineering difficulties.
  8. TonyPSchaefer
    14,816
    2,501
    66
    Whoa right there. The PHV is, according to Toyota, 100% Lithium. Three packs of the stuff.
  9. Jands
    Jands New Member
    88
    UK
    Tony - have you been able to do one of your regular routes in HV mode only? I'm wondering what effect the extra weight of the batteries has on mpg when compared to a Gen 3 (or 2 in your case).
  10. TonyPSchaefer
    14,816
    2,501
    66
    Here's one trip in particular: http://priuschat.com/forums/prius-h...al-world-experience-phv-blog.html#post1153154
    It was a 102 mile drive with less than 3 miles of EV charge. I still overwhelmingly outperformed what I would have expected in my car.
    (all calculations are in U.S. figures)
  11. Jands
    Jands New Member
    88
    UK
    So the Plug-in achieved 71.5 mpg (Prius readout)...what would you expect from your 2004 Prius? (or did I miss that bit out of your post...apologies if so).
  12. TonyPSchaefer
    14,816
    2,501
    66
    I didn't provide that in the original but added the following text:
  13. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    I hear you, but my perspective is I get on the freeway and have few techniques at my disposal, and the wind resistance quickly takes the day's EV charge. Done. Gone.
    If I can force hybrid on the freeway, then EV all day around town in EV mode, I avoid multiple warm-up cycles. Use the ICE once instead of many times. An advantage of the MGs is low-end torque. That is irrelevant at freeway speeds, but huge in town.
  14. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i echo others here by thinking that we do not have a final product and the regen limitation for the traction batteries seems more odd than a mistake.
    balancing the two packs would be the main issue i would think but i dont understand why regen would not be able to do that effectively.
    now if regen can work as long as the EV batts were not "completely" depleted, then maybe you could simply turn them off before depletion if you knew you were coming to a long descent?
  15. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Presumably when the ICE first comes on to warm up it does not provide much power with much delayed ignition timing? Do you still have the ScanGauge to take a look at IGN?
  16. TonyPSchaefer
    14,816
    2,501
    66
    I have to admit that I am not overly techie (some might argue) and that I am not fluent or even very familiar with the ScanGauge. It probably would have been best to have had someone with ScanGauge knowledge ride along with me on a few different trips to take the readings as the car went through various scenarios. Unfortunately, I didn't have access to any PHVs during Green Drive Expo and I have to give the car back this evening.
  17. 2009Prius
    2,705
    512
    63
    No problem! Thanks for sharing your experience. :)
  18. bwilson4web
    16,533
    Can you cycle in and out of EV - hybrid mode like this:
    • EV up a hill
    • just before crest, hybrid mode to get gas to start
    • hybrid down hill 'coasting' during warm-up
    • when hill flattens go back into EV
    What this does is let the warm-up proceed without a strain on the ICE. This will warm-it-up without the higher fuel consumption of a significant load. Then on the back-side of the hill, the engine should stay on (speed above 46 mph) and the warm-up continue at minimum fuel consumption. At the bottom when the fuel consumption starts to pick up, slide back into EV mode.
    This is load driven, terrain driving at its best with the EV letting the ICE coast.
    What I'd like to see would be a pre-hybrid mode threshold so before EV ended, the ICE would run but at idle. The reason is the time to warm the engine coolant does not change that much whether under load or not. So if the ICE is going to warm-up, use the least amount of fuel with an engine in idle.
    It would be fascinating to see MG2 temperature during EV mode. If it gets significantly warm, it would be great if the engine coolant passed through the gallories to keep MG2 cool and bring the ICE closer to operating temperature.
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm late to this party, but I'm happy for you Tony, I'm sure you are enjoying the opportunity for cutting edge experience and evaluation.
    Honestly though? I think Toyota is being conservative in giving a Toyota Prius lover, a PHEV for only a week. A week is just long enough to fall in love but not long enough to really, really evaluate outside of the almost immediate impressions.
    I suppose we are in virgin enough territory where immediate impressions based on a weeks worth of exposure are interesting and have some validity, but why not 6 weeks?
    Hey, I'm just trying to buy you some more time....
  20. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    conservative?? nah... just building up a little "want" in a potential customer i think
