My rear driver window doesn't go up or down from both switches
Discussion in 'Gen 4 Prius Technical Discussion' started by antk, Oct 12, 2023.
  1. antk
    antk New Member
    los angeles
    2018 Prius
    I just got 2018 and rear window doesn't move from both driver control or the rear passenger. I don't think it's fuse cause Prius doesn't have individual window fuses for each door or do they?
  2. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    Do you hear something when trying to lower it?
  3. antk
    antk New Member
    los angeles
    2018 Prius
    No, I don't hear anything. I also checked front door switch and rear door switch and absolutely nothing happens when I press
  4. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    Def sounds like a fuse.
  5. antk
    antk New Member
    los angeles
    2018 Prius
    I don't think there is fuse for seperate windows. I believe there is only 1 for all 4
  6. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Check section 3.5 of your owners manual. It is possible that the jam protection or the catch protection function has activated. Section 3.5 will provide instructions on how to possibly alleviate the problem.
    antk likes this.
  7. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    I misunderstood you said switch thought you meant both front and rear window.
    antk likes this.
  8. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    antk likes this.
