My Review of my Prime Advanced package
Discussion in 'Prime Main Forum (2017-2022)' started by kmlipps, Jan 15, 2017.
  1. ruby
    ruby Member
    130
    78
    Uh, warehouse store, you guys! LOL
    bwilson4web likes this.
    51,944
  3. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    I shop at Costco and Bjs all the time with my Prime. We go to Costco once a week and BJs about every other week. Costco actually we tend to buy less bulk and more staple items like yogurt and fruit. BJs is where we buy our paper goods and some produce. I am about to pull the cover off my prime, it just isn't meaningful. I could put luggage under it unless we were traveling with only a single piece of luggage. This is disappointing as the Prius we rented several years ago had room for us to slide our luggage under the cover and slide the cover closed. I was hopeful they would eat up that space too much but they did. I still bought this car, but that is the one thing that really makes me growl each time I get into the hatch.
    Nice review overall, the rear window does seem to be a collection point. I also find myself reaching down and wiping off the camera frequently.
    ruby likes this.
  4. Prodigyplace
    12,564
    11,779
    Central Virginia
    The camera seems to be an issue on the Gen 4 Prius too.
  5. David F
    David F Junior Member
    Since you have the Advanced model I wanted to ask you. Toyota says the advanced model has 10 speakers but the photos and reviews don't seem to show them? (Maybe I can't find them)
    Does it really have 10 speakers? And how does it sound if u crank up the volume??
    Thanks
  6. Tideland Prius
    16,559
    It's 10 speakers in 6 locations.
    1. Midrange & tweeter on the dash
    2. Subwoofer in the front doors
    3. Full range & tweeter in the rear doors
    See attached PDF.
    dalcon95 likes this.
  7. David F
    Thanks for the info! Now how does it sound? Lol
  8. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    I think the system sounds great!!
  9. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Note that the EPA now lists Prius Prime as 25 kWh/100 mi.
  10. Mendel Leisk
    41,463
    Yes. My brain hurts looking at the Initial Post. Will read it if-and-when some paragraphs are incorporated. C'mon @kmlipps : edit it please. Maybe difficult to do using a mobile app??
  11. kmlipps
    kmlipps New Member
    US
    If you look through the comments, someone had fixed it to have paragraphs already.
  12. Mendel Leisk
    41,463
    Oh, is the initial post locked for you then? I've seen that. Maybe you could report (use report button, lower left button) initial post, request the moderators to unlock it, if that's the case.
    Addendum: ok, see it's bob's post here:
    My Review of my Prime Advanced package | Page 2 | PriusChat
    If you're still able to edit initial post, and you're completely happy with bob's rendition, you could copy and paste it, replace your original text with his. Maybe remove italics though.
    #52 Mendel Leisk, Jan 29, 2017
  13. Prodigyplace
    12,564
    11,779
    Central Virginia
    I just looked and did not see that. I see several other reviews, bit not yours corrected.
    I believe you can still edit the first post to fix it.
  14. Prodigyplace
    12,564
    11,779
    Central Virginia
    Strange. I have gone back and corrected typoes in older posts.
  15. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    There's a time limit, then you can no longer edit. I don't know what that limit is, but I can not edit my posts on the first page.
  16. Mendel Leisk
    41,463
    Yeah same here, but sometimes edit is locked out. Maybe more so with intitial posts. Mods attempting to avoid confusion??
  17. kmlipps
    kmlipps New Member
    US
    following is my review of the all new prius Prime Advanced package! I've had it for about a month now, which has been long enough for me to make an opinion.
    I'll start with the cons: if you looked into this car at all, you know that the back windshield has been changed compared to any other prius. It has a dip that is supposed to be more aerodynamic and also used to drain water, snow etc. Here in Pennsylvania we've had a plethora of weather over this month and I've come to realize this rear windshield sucks. Water does not run down, snow does not slide off, and now without a back windshield wiper, it's almost impossible to see. I'm sure it helps my mpg, but it does not help me to see out the back.
    Next, is the backup camera. Because of its location under the dip of the rear windshield, I find its always dirty! I'm constantly having to wipe it before driving in order to use it! Its either wet, dirty, or covered in salt from snow. With my 2010 prius, I never had this big of an issue with the camera getting so dirty!
    Speaking of the camera, it is less than impressive. If you've ever been in other newer vehicles, their back up cameras have lines that tilt and move to better help assist you. On this prime, it looks like toyota wanted to make it look helpful by taking the camera they've always used and just adding lines. They only help if you're backing up in a straight line, they do not tilt or turn and honestly just get in the way most of the time.
    The next problem is the GPS. It has not been updated, it looks the same as it always has. There's nothing special to it. I know with my 2010 I did not trust or use my GPS and it's looking like that's how this will be too. It seems to not know most roads and always takes way longer than if I just use my phones gps. Come on toyota get with it!
    Also, this car is only a 4 seater, Toyota got rid of its 5th seat to cut down on weight and improve mpg. I'm sure in the years to come they'll bring 5 seaters back, but if that's what you need this isn't the car for you right now.
    Now with that being said here are my pros: in all honesty I do love my car. It's looks are great, the interior (black leather) is comfortable and does not give off that harsh leather odor. The heated steering wheel and front seats heat quickly and perfectly. If you don't already know, this car has no belts under the hood. The heat/air conditioning are controlled solely by electronics and the outside air, which probably contributes to how fast it heats up and also means that in cold temperatures you don't need to turn on your car prior to leaving which is nice!
    I charge my car overnight, and this car has a setting that you can tell it what time you leave so that it will be fully charged by that time and also heated up and ready to go based on what temperature your heat or air is set to! Which is super great for cold mornings.
    The car also seems to be getting used to my commute, or I'm getting used to the car, but I find that it has been doing better and better each day mpg wise.
    The automatic/sensing high beams are nice for night driving, no more having to remember to switch high beams off for oncoming traffic, the car does it for you! Not to mention the lights on this car are amazing!
    This car also has a rain sensing windshield. There's a sensor that senses a dirty/ rain soaked windshield and automatically turns on your wipers for whatever speed it feels is adequate. A nonimportant feature, but it is nice!
    The get up for the car is better than your average prius! It almost feels like a newer corolla would. It doesn't lag as much, especially with a charged battery. Though when the electric battery is dead, it does go back to the normal prius feel, no biggie!
    This car also has radar cruise control. So, you can set the cruise to whatever speed, but if a car going slower were to go in front of you the car will sense that and match it's speed until that car moves from your lane. It'll keep you at a 3 car distance away. So you could have your self set for 80mph but if the car in front of you is doing 20, you will go 20 safely! It's very nice!
    This car has plenty of safety features such as heads up display, blind spot detection, rear cross traffic alert, parking assist, and lane departure warning. Which if you've never had the lane departure it can be shocking at first! The car detects the lines on the road and if you cross them (or leave your lane without a turn signal) the car will beep at you, if you don't correct yourself the car will correct your driving for you so it literally steers you back into your lane. It's not aggressive, if you're really switching lanes the car will let you, but it's still nice.
    As for the mpg, its amazing. The electric battery allows around 20 miles of gasless driving at speeds up to 84mph. And for those who work close to home you'll almost never touch your gas tank! The car allows you to use only battery or have it switch from hv to ev based on the driving conditions (hills, straight aways, or based on your speed).
    I use the hv/ev mode to go to work since I live about 35 miles from my job to get the best mpg. Once the battery is dead the prius does not lose its mpg! I still get my mpg in the 60s with the normal hybrid battery. If you're wondering how this car is better than a chevy volt, I'll explain.
    Volts charged battery can get you around 38 miles on a battery until it dies. But once that battery dies the mpg plummets. The battery is now at 0% with nothing saved to help your mpg from then on. You're driving an average car at that point with low low mpg. The prime does not allow its battery to completely die. The all electric driving is over when the battery is around 20%, leaving the remainder to help keep your mpg high even while using gas. A great feature of the car for those with long commutes.
    Overall, there are more pros than cons with this car. I love it's new sporty look and fun new gadgets. It does need tweaking but I'm sure it'll come in time! If anyone has any other questions about anything I mentioned or hadn't mentioned don't hesitate ask
    Tideland Prius and Prodigyplace like this.
  18. Prodigyplace
    12,564
    11,779
    Central Virginia
    Perhaps. I have not started many threads.
  19. Mendel Leisk
    41,463
    Now I'm the Sorcerer's Apprentice...
    @kmlipps : Are you able to do a cut-and-paste per your post #57 in your post #1?
  20. kmlipps
    kmlipps New Member
    US
    Fixed
