My scanner tells me this about my emissions system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Dec 1, 2022.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    My scanner presented a bunch of alerts when I plugged in it
    They were Emmision related as follows. CAT, O2S ,HTR, EGR
    Does this mean I won't pass my next smog test?
  2. PriusCamper
    PriusCamper Senior Member
    13,468
    5,438
    Pacific Northwest, USA
    Didn't you already post this elsewhere? Regardless, what kind of scanner are you using? Many scanners are not programmed with Prius specific error codes and subscodes and people end up repairing things that are not broken because of this.
    In the meantime while you make sure you have good scanner software/firmware, clear all those codes and see how quickly they come back. Many vehicles will have irrelevant/old outdated error codes if it's been many years since a scanner was last hooked up.
  3. Taxi/Limo
    526
    107
    I did but decided to make a seperate post
    Innova 5510
    I will do that and recheck
    Thanks
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    But that’s one of the ways to reach senior member status quickly.
  5. Mendel Leisk
    42,358
    Three threads started on that scanner, in one day.
  6. ChapmanF
    19,039
    Do you remember if your scanner showed trouble codes? (These are five-character things that always start with a letter P, C, B, or U, and end with a 0 through 9 or A through F.) Or did it just tell you that certain emission monitors were not complete yet?
    If there were trouble codes you should tell us; they give useful information. Generally you won't pass the test if you have them.
    If you have incomplete emission monitors, that just means you haven't driven enough for all of them to complete yet. The inspector won't pass you in that case, or fail you either; they'll just send you away to come back once all the monitors have run.
    There is a kind of strategic decision involved here, because any time you clear any codes (or even do a "code clear" whether there even are codes or not), that resets all the emission monitors back to incomplete. Then you will not be getting an inspection pass until you have done enough driving for all the emission monitors to complete again. If you're only waiting for four of them to complete now, resetting them all would be a step back.
    Taxi/Limo likes this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    He’s got hook ups with priuschat admins, they don’t merge his posts.
    Taxi/Limo and Mendel Leisk like this.
