My stealth Subwoofer install
Discussion in 'Prius c Accessories and Modifications' started by Tyler Wilson, Jan 2, 2017.
  1. Tyler Wilson
    Tyler Wilson Junior Member
    16
    Spokane
    Got all finished up with my Subwoofer install in my 2013 Prius C. This is my first post but wanted to see what you guys and gals thought about the setup.
    My main goal was to add some good bass to the factory system without sacrificing any cargo space. Especially since there is not much to begin with, cargo space or bass :)
    Equipment used:
    JL Audio 8w1
    JL Audio XD 300/1
    Montgomery and Veliksam like this.
  2. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
  3. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    Btw, how much for a box shipped to Orlando? I'll consider buying one of you start making them.
    Montgomery likes this.
  4. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Dude, you are definitely gifted in wood work! People here are going to ask you make one for them!!
  5. Tyler Wilson
    16
    Spokane
    I would actually like to start making them, would youwant it complete with the sub and amp? Or just the box?
  6. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    Just the box
  7. Tyler Wilson
    16
    Spokane
    Thank you! And I would love to make some more of these!!
  8. Tyler Wilson
    16
    Spokane
    How does $500 shipped sound?
  9. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    I guess it's a good price given the labor it takes, I just don't have that kind of $ available right now. I'll pm you when I get the lot together.
  10. Tyler Wilson
    16
    Spokane
    Sounds good, I'm working on an easier design, I'll keep you posted. Planning on making one for the other side as well.
  11. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    Would fiberglass be a good option as a material in terms of quality and build cost?
  12. Tyler Wilson
    16
    Spokane
    Quality yes, built cost no. A lot more labor involved with fiberglass, at least if you're just making a few of them. Making vacuum mold setup would probably cost less if I start making a bunch of them, high cost initially though.
    Veliksam likes this.
  13. Montgomery
    2,254
    2,242
    Orange County, CA
    Personally, coming from a music background, the resonation and vibration of tones bouncing against wood is the best sound there is. Hence the Strattavarius Violin. Just my two cents. I feel people will like the end result of you using wood over fiberglass. Vibrational tones will seep through the fiberglass material. Wood is just plain made for music to resonate from. And just another amatuer tip, build one, send it to one of the people here that has a Prius C at a discount so they can hear it, then let that person be your salesman. Seriously, once people hear how it sounds with wood, you will be busy!!
  14. Montgomery
    2,254
    2,242
    Orange County, CA
    Another option is to build it without the felt, selling it less without the felt cover. Helps save you construction time and the end user can cover it on their own. Charge more if they want you to cover it with felt.
    Tyler Wilson likes this.
  15. Tyler Wilson
    16
    Spokane
    Thanks Montgomery!
    I also prefer the sound of wood over fiberglass, great suggestions!
    I'm working on an easier design at the moment that should reduce labor costs quite a bit.
  16. Tyler Wilson
    16
    Spokane
    New design in progress. Building one for both sides if you really want it to get after it. :)
    djdawn and Montgomery like this.
  17. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    I think im going to need to get one of these from you. It looks great!
  18. Montgomery
    2,254
    2,242
    Orange County, CA
    You are truly gifted at this!! Way to go!
  19. djdawn
    djdawn Active Member
    256
    116
    Escondido, CA
    2014 Prius c
    I'll all for reclaiming that negative space in the trunk. If I can make one side work for me as a sub, even better. Definitely keeping tabs on this thread for updates.
  20. Kenny94945
    Kenny94945 Active Member
    861
    437
    Sausalito
    2016 Prius v wagon
