My Synthetic oil still looks new after 10k miles of driving
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Mar 29, 2020.
  1. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    There is a big difference between a motor that started using synthetic oil for the first time @ 40k miles...
    And a motor that has been using synthetic oil since new!!!
    Data Daedalus likes this.
    51,946
    that's what i am afraid of
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Is there?
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    No there isn't.
    There are a lot of other factors involved but generally that is NOT true.
    Where did you get that idea ??
    Kaptainkid1 likes this.
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    ski.dive, thank you for sharing!
    I think there are at least two other factors to ask about to get the results mentioned:
    Fuel quality, ie. Top Tier or not, grade?
    Air filter/Air quality?
    Driving style is a variable I’ll ask in another way:
    What average MPG are you getting please?
    I learned from somewhere as an example silicate (from dirt) contaminates engine oil when a poor efficiency air filter is used.
    I use a dry synthetic aFe filter which may allow more contaminants through the intake.
  6. Mendel Leisk
    41,463
    Myself mostly. It's something to do every 6 months, costs me around $21 CDN.
  7. qmanqman
    qmanqman Active Member
    431
    149
    CO
    Goodness. You definitely do not have what it takes to be a member of the Cheap Bstrds (CB) club. LOL
  8. Mendel Leisk
    41,463
    My engine and cabin air filters are 9.5 years on the car. And I just replaced the front wiper blades. C'mon, let me in.
    nssdiver and Merkey like this.
  9. qmanqman
    431
    149
    CO
    No partials. You must go through great lengths to never spend any dime that does not need spending.
  10. ski.dive
    964
    244
    Yes there is!!!
    = A big difference between conventional oil and synthetic oil- I don't want to argue about oils!
    #30 ski.dive, Mar 31, 2020
  11. ski.dive
    964
    244
    On my 2008 /110K MILES------I average 43.8MPG & I run the Prius hard.
    I use Regular 89 fuel,
    I always change the engine and cabin filters once a year,
    original traction battery, ORIGINAL SPARK PLUGS,
    +++Always running on Valvoline synthetic oil since new!
    #31 ski.dive, Mar 31, 2020
  12. bisco
    51,946
    those filters are a lot more expensive than oil, but mine look like new after 10k/1 year
    Data Daedalus and Mendel Leisk like this.
  13. qmanqman
    431
    149
    CO
    I can throw my $.02 in on this. My brother has a 2004 F150 that is knows for an engine failure that has to do with tiny oil journals that get plugged up with oil sludge. This doesn't happen however with synthetic oil.
    So my conclusion is that there is a difference. A dino oil engine is all sludged up all over the place whereas a synthetic only engine is not. What I do when I buy a car I do all my oil changes with synthetic and a quart of Marvel Mystery Oil just because they claim it is a cleaner. Is it? Hell I don't know for sure. I just take their word for it in hopes that I'll get the engine there.
  14. sam spade 2
    7,035
    2,803
    2017 Prius c
    Of course there is a difference in the oils.
    But in most cases it is NOT enough of a difference for the engine (not a motor) to show any noticeable difference after only 40K miles. It just isn't.
    Then......MMO is a very light oil. It will dilute the viscosity of your base oil. Putting in a whole quart is way too much.
    If you MUST do that, consider reading the label and cutting back on the amount.
    If you use good synthetic oil, there really is NO reason to add anything.
    Well then you shouldn't have brought it up in the first place. :eek:
    Synthetic oils have several advantages over conventional oils.
    But basic wear protection is NOT one of them.......in general.
    No arguement. That is a fact.
    P.S. You need to work on your post quoting.
  15. qmanqman
    431
    149
    CO
    I meant in the engines which was the original post by ski.dive. He said something like:
    "There is a big difference between a motor that started using synthetic oil for the first time @ 40k miles...
    And a motor that has been using synthetic oil since new!!!"
    I gave you an example of an engine who's never used synthetic was all sludged up.
  16. sam spade 2
    7,035
    2,803
    2017 Prius c
    There are exceptions to every rule.
    That situation is NOT typical.
    And what kind of mileage was on that 15 year old truck ?
    I bet it was a LOT more than 40K.
  17. Mendel Leisk
    41,463
    Yeah I seriously doubt going to a synthetic is going to keep your piston rings from clogging. The spec'd Prius c and 3rd gen Prius oil in 0W20, and that's invariably synth. And they are getting clogging, and oil burning as a consequence, anywhere past 100K miles.
    Toyota piston and ring design is more likely culprit.
    #37 Mendel Leisk, Mar 31, 2020
    Kaptainkid1 and Aaron Vitolins like this.
  18. qmanqman
    431
    149
    CO
    No idea probably a lot. That may or may not matter though. I doubt sludge builds up one day. An engine with 40k on it will have 40k worth of sludge and who would know what damage because of it.
  19. bisco
    51,946
    if the oil is clear, it's clear. i don't want to argue about oils!
    Prius Rising likes this.
  20. Mendel Leisk
    41,463
    OP has yet to clarify if he's talking about oil-on-dipstick or a jar of oil. For good reason I think...
