My Theory on Toyota's Unintended Acceleration Problem
Discussion in 'Gen 2 Prius Main Forum' started by Walk_the_walk, Mar 12, 2010.
  1. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    I think he was using that term as civiliand do all the time to mean his speculation, certainly not a scientific theory;):D
  2. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    I think the problem may come from cheap outsourced Chinese Ompa Loompas. They all look alike to at a glance, but the Chinese ones just don't get the same level of testing and training. Some of them are even malnourished. And besides, I keep finding chocolate wrappers in the footwells from chocolates that I don't remember eating, also my brakes often come on and the car veers to the right when I go past a Fanny Farmer store. The Oompa Loompa theory would explain these puzzling items. Anyone know where in the CANBUS I should check for Oompa Loompa related activity??
  3. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    That is a totally different issue than was talked by KK6PD.
  4. Walk_the_walk
    Walk_the_walk Junior Member
    23
    Central Florida
    Re: My Theory on Toyota's Unintended Acceleration Problem - MORE
    UPDATE TO ALL:
    Prompted by something I read just now in one of the postings, I searched the NHTSA website and found that NHTSA ODI has opened an investigation into the 2004, 2005, 2006, 2007 and 2008 Priuses for "VEHICLE SPEED CONTROL:ACCELERATOR PEDAL" i.e. unintended vehicle acceleration. This investigation was opened across the board on ALL of these models on Feb. 16, 2010, almost a month ago.
    Note what I also found linked to these open investigations (THIS IS VERBATIM):
    "NHTSA IS SEEKING INFORMATION ABOUT HOW TOYOTA VIEWED COMPLAINTS AND OTHER REPORTS TO TOYOTA AND HOW TOYOTA ASSESSED POTENTIAL ELECTROMAGNETIC INTERFERENCE. THE AGENCY ALSO REQUIRES INFORMATION FROM TOYOTA ON WHY SOME MODELS OF VEHICLES WITH ELECTRONIC THROTTLE CONTROL WERE NOT INCLUDED IN THE RECALLS. THIS INVESTIGATION DOES NOT DUPLICATE TQ10-001 OR TQ10-002."
    I HAD NOT SEEN THIS INFO BEFORE TODAY. I CAME UP WITH MY THEORY ON MY OWN AFTER REVIEWING THE BENTLEY TECH MANUAL THIS WEEK. You can draw your own conclusions.
  5. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    Probably a pretty good clip from there. And, I doubt that those analog radar signal could mess up the digital signal.
  6. Walk_the_walk
    23
    Central Florida
    Not to put too fine a point on this, but it was related, just something that contrasts with what he wrote, which was this: "One thing that I was looking for during the install was Vehicle grounding and Electronics shielding. I did not want to turn on the radios and all I hear was a constant harmonic computer generated buzz. I was quite impressed with both the level of shielding and grounding used in this car..."
    I guess I have the opposite POV, since I had to go out and buy a Radio Shack Ground Isolator and install it in the console, just to hook up an XM Sat radio unit to the Aux port. Then, low and behold, a few weeks later, I find out about the TSB from Toyota for this same issue.
    My point, albeit subtle for some, is that the shielding IS NOT that great everywhere in the car, if you have to install a GROUND FAULT ISOLATOR on the AUX port of the audio system. What other Oopses are there in this car when it comes to shielding?
    The NHTSA seems to think it's a valid issue at the least. See Update just posted.
  7. daniel
    14,487
    1,519
    Spokane, WA
    I never insulted you. I critiqued your "theory" (actually a speculative hypothesis with faulty logic and no evidence). I don't much care if you call me a pinhead. I won't even stoop to replying in kind. And, no, I won't shut up. I will continue to express my opinions and offer my reasons for them, as I did in my earlier post.
    Item: You argue that you believe bluetooth to be the cause of the presumed interference because you don't have bluetooth and you've never had unintended acceleration. Don't you see the failure of logic here? Arguing that bluetooth is the culprit because you don't have bluetooth! When a problem occurs in maybe one car out of a hundred thousand, the fact that you don't have the problem is not grounds for any conclusions at all. Then consider, as someone above pointed out, that hundreds of thousands of people who do have bluetooth have not had the problem, and your hypothesis is on shake ground indeed.
    And telling me to shut up does not strengthen your case.
    3 people like this.
  8. Walk_the_walk
    23
    Central Florida
    I took it as an insult, just like your current retort. It seems there is always someone ready to provide loads of criticism without any suggestions or original thoughts of their own. There's one in every crowd - looks like you're it.
    Apparently, you didn't read my initial posting well either, perhaps you were too busy simmering up your sarcastic retorts, as I pointed to SEVERAL possible causes, not just Bluetooth (although BT was first in the list).
    My exact quote was: " Information Carrying Radio waves, Bluetooth and/or hands-free devices as a possible cause of UA in these recent Prius incidents. If my theory turns out to be correct, it would be easy to add shielding, using shielded cable or after-market installed toroidal coils, to reduce the hazard if it is caused by radio frequency interference."
    It almost mirrors the latest info from the NHTSA Prius investigation posting, so I think it's spot on. If you have a better idea, I challenge you to post it. Your negativity so far has not been helpful, just hurtful.
  9. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Walk,
    I think the problem you have here, why your post hasn't been taken very seriously, is that you propose nothing new at all in a rather arrogant "Hey look what I thought of!" manner. Do you really think none of the engineers involved have considered and checked out what you propose? It's been discussed here before. I don't mean to insult, rather to point out how the post comes across.
    Yes, NHTSA would like to get documentation on exactly how Toyota has already tested and discounted this as a possibility. That's great and I hope they get satisfaction one way or another. Never know, if there is anything to this at all it could turn out to be radio interference related, but it's not a new idea.
    - D
  10. Walk_the_walk
    23
    Central Florida
    Setting squabbling aside for a moment, let's look at some of the facts of this issue, as they exist at present:
    1. The Prius, as well as several other Toyota vehicles, uses a "drive-by-wire" electronic throttle system that includes redundant sensors (like potentiometers) and circuits to feed the gas pedal position to its ECU. According to testimony on Capitol Hill, (and I do not recall the exact wording but hope to find it and post it here), this control circuit uses a very tiny amplitude signal, in the millivolts level to indicate pedal position.
    My service rep states that the two sensors work exactly opposite of each other, one reading a higher signal when the pedal is fully depressed, while the other reads the opposite signal level. I cannot confirm this statement at this time.
    2. Gen II Priuses are not supposed to be affected by the UIA problem at all, as all Toyota hybrids are supposed to have the brake override software routine installed already. This was told to me by my service rep last week, and similar verbage was stated in the Congressional hearings (...and I listened to all of them). So, stepping on the brake at any speed should override the tiny amplitude signal coming from the gas pedal and the ECU should "ignore" any gas pedal signal, and slow the vehicle.
    THIS APPARENTLY DID NOT HAPPEN IN MR SIKE'S VEHICLE, in spite of all the jokes about his mishap including lack of knowledge about "the secret Neutral gear". His brake override software and system failed. (Like many others, we have tested ours and it works under normal conditions.)
    3. Several other non-Priuses are more widely affected such as Lexus ES and Camry and some Tacomas. 52 people have been killed, mostly not in Priuses.
    4. My theory is that there is an electronic signal interfering with the ECU that receives the gas pedal signal. I suspect Bluetooth or other information carrying radio waves, or it could be some kind of hands free device, or just plain old radio interference. It's just a theory, and one that would explain a randomly distributed occurrence that is hard to pin down.
    6. NHTSA apparently knew about a yet-to-be publicized problem with the Prius back in Feb. 16, 2010, at least a week BEFORE the first Congressional hearings. Yet, there was almost nothing mentioned about this problem with the Prius in the Congressional hearings, and there is no recall of Priuses, other than the floormat. (correct me if I am wrong on this point). I do not recall if any Priuses had their gas pedals trimmed, tweaked or modified, as did other Toyota cars - mine warranted no recall whatsoever.
    7. The Prius floormat hooks in place and is difficult to remove and is about the least likely suspect for this problem. In fact, with some of the incidents of UIA discussed on Capitol Hill, the floormats had already been removed from the vehicles in question.
    8. The NHTSA website now has a statement on it that indicates that they suspect electromagnetic interference. It reads: "NHTSA IS SEEKING INFORMATION ABOUT... AND HOW TOYOTA ASSESSED POTENTIAL ELECTROMAGNETIC INTERFERENCE. THE AGENCY ALSO REQUIRES INFORMATION FROM TOYOTA ON WHY SOME MODELS OF VEHICLES WITH ELECTRONIC THROTTLE CONTROL WERE NOT INCLUDED IN THE RECALLS." This parallels my theory.
    9. Some Priuses are known to have a minor ground fault if an external audio device (Ipod, sat radio, MP3 player) is attached to the Aux port of the audio system. Toyota has a fix for certain models, or you can install a Radio Shack Ground Fault Isolator like I did. Newer Prius may have this fix, or not. It may only affect the audio and nothing else.
    10. A ground fault, grounding problem, or short circuit is another possible cause of this kind of problem. A professor from Southern Illinois University was able to duplicate a UIA situation in a toyota (not a prius) in 3 hours time with a makeshift box with pots and switches wired in parallel with the velocity pedal circuit. In these vehicles the brake override software may not have been present, or it may not have worked at all.
    Those are the facts that I know about so far.
    As Donald Rumsfeld would say, "there are known knowns, there are known unknowns, and there are unknown unknowns".
    My effort is to try to narrow the field and find the cause, before someone else gets killed.
    Please post your suggestions, or comments (please skip the criticisms - they aren't helpful).
  11. don_chuwish
    823
    190
    Southern Oregon
    Heheh, I only mentioned it in the tone that daniel replied with:
    Maybe some super secret military experiment at Miramar could have been testing a radio interference weapon or something. The anti-Prius ray gun.
    - D
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    Walk, as pointed out before, if interference were getting into the CAN bus (LAN as you call it), there would be codes logged. CAN bus is a tough little bugger, and it doesn't give up easily. The inter-ECU messages would be repeated if garbled, and an error code would be logged. So far this has not been a common problem.
    Tom
  13. Walk_the_walk
    23
    Central Florida
    Thanks, Don. I am new to this forum. It's a new idea to me. Everyone I asked said it was floormats... I am certainly not trying to be arrogant (that is your interpretation), and if it's been discussed before, that's great.
    If you don't take my posting seriously, that's your choice. I came to my conclusions independently. Haven't posted here in years. And, from the kind of responses I keep getting that show a lack of courtesy, understanding, or even interest, and a high degree of techno-snobbish sarcasm, I don't know why anyone would want to post any idea on this site for some of you to trash.
    It's easy to trash someone else's idea, folks. But, unless you have a better one, why would you want to do that.
  14. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Mostly correct. Increased errors on CANBus can and will flag error flags. Whether the host bus supports logging these flags is open to interpretation
    Here is an example of a MSO properly flagging a CANBus error glitch
    Here is an example of randomized noise - injected using a Agilent 81150A Arbitrary Noise Generator - effect on CANBus
    Here is an example of a purposely introduced major glitch into CANBus to induce a state change
    A properly designed CANBus system, whether industrial or automotive, is designed to fail gracefully in such a situation. Eg: shut down or "limp"
    There is no commercially available vehicle I know of that meets appropriate MILSPEC requirements for HAEMP. The cost to meet those specs is astronomical to say the least
  15. Walk_the_walk
    23
    Central Florida
    So, as a closing post for the weekend, I challenge all those on this forum to post their best idea for the cause of this problem. Hold the sarcasm and snotty remarks - just your best idea. Provide as much detail as you can.
    JAYMAN's posting for example, is excellent and helpful. I think I get the gist of what this digital oscope snapshot is showing, but even the best designed systems have their flaws. Like O-rings on the space shuttle, for example.
  16. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    The theory is not credible. The CAN bus in the car uses high voltage differential signals. The interference from other electronic devices would barely alter a +13.8v signal. Also CAN has a lot of parity check bits. This means if something were to happen to a message, the check would fail, the computer would *know* that there was an error, and disregard the message. Probably also logging the error.
    Interference on the CAN bus signal even if it were to happen would have no effect on the system. If you did the worst and just tied the line to high or ground so no messages could get through, the entire car would throw codes and die.
  17. don_chuwish
    823
    190
    Southern Oregon
    Any member of this site has the same challenge in coming up with a "new idea" as Toyota does: all the possibilities have been beaten to death but that won't satisfy anyone. I've been in their shoes and even when presented with the clear cause/effect/solution it wasn't accepted because it wasn't what the audience wanted to hear.
    - D
  18. KTPhil
    KTPhil Active Member
    1,379
    22
    Walk the Walk needs to get a life. He actually tried to contact the guy who was involved in this alleged runaway Prius? Sounds a lot like a stalker type to me.
    His posts are full of half-truths, leaps of logic, and some downright ignorant misreadings of the facts. It is a good example of how a small mind coupled with the questionable info obtainable on the web makes for some oddball, if amusing conclusions.
    For example, he states it is a fact that this guy's brakes failed. No one but the driver has alleged this, and he is hardly impartial when faced by a speeding ticket and months of late loan payments. To say the brake signal overrides a millivolt accel signal shows ignorance of how the two operate and interact.
    And now this "expert" is challenging us to post our theories, as if he is going to hold some sort of theory tribunal? Laughable!
    I would no sooner engage in that process than to have the same discussion with my dog.
  19. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    I don't think the Bluetooth caused it. It is caused by the Coldfeet of the driver.
  20. fuzzy1
    10,722
    OP's hypothesis (it isn't a theory until there is a body of evidence to support it) is a very narrow slice of the field of EMC (Electromagnetic Compatibility).
    This potential problem has many more possible sources and many more possible receivers than OP mentions. Overall, it is a very common problem. All respectable manufacturers design and test for the most common forms of it, but proving immunity to all possible forms is not a finite task.
    Without some actual evidence, OP's 'theory' it is just a SWAG -- Stupid Wild-A**** Guess.
