My Toyota dealer is selling refurbished traction batteries
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tj S, Nov 16, 2016.
  1. bisco
    51,822
    check you tube, pretty sure there are some. also threads here with pics.
  2. Mendel Leisk
    41,260
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,418
    3,293
    Madison, Wisconsin
    The biggest issue I see is that most DIY folks ARE NOT paying attention to torque specs.
    I would venture to say that there is a 99% chance that TJ S did not use a torque wrench to correctly tighten each of the connections in the battery or the battery wires.
    DIYers seem to skip over the idea of correctly torquing the nuts/bolts and "tighten by feel", assuming everything will be fine.
    This is an unsafe way of doing things. Especially when we are talking about high voltage, high amperage DC connections.
    Take your time. Purchase a torque wrench and use it.
    Your safety is worth it.
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,737
    Bay Area
    I'm waiting patiently for my HV battery to die... I will keep you guys updated :ROFLMAO:(y)
  5. Mendel Leisk
    41,260
    D
    Do you have a cheat sheet of torque values, what you'd consider the main, most critical ones?
  6. Falcon Hybrid
    Falcon Hybrid Junior Member
    Hawthorne NJ
    We do occasionally partner with dealerships but we mark our cells and cases to ensure our customers/people who end up with our packs can get in touch with us for info or repairs if needed.
    -charlie
  7. bisco
    51,822
    argh!!!!:eek:
    Raytheeagle and m.wynn like this.
  8. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    This.
    Is why I DIY.
    Raytheeagle likes this.
