Myself vs. The Evil Glove box
Discussion in 'Gen 3 Prius Main Forum' started by The Electric Me, Aug 26, 2016.
  1. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Just posting this as a heads up.
    The top Glove Box in my Gen 3 is moderately filled.
    The other day, I got a important receipt and some paperwork I wanted to be sure NOT to lose. I needed it to pick up merchandise in the future. For a pair of glasses.
    So anyway, I get in my Prius and throw the receipt and paperwork in the glove box, and proceed on with the rest of my day.
    I get home to unload everything, and pop open the glove box. No receipt. No paperwork.
    Now...I'm getting old enough that I occasionally question myself. Did I throw the paperwork in with some stuff I bought?
    I unload everything and look in every bag. Nothing.
    I search drawers and counters thinking maybe I just subconciously or automatically filed it away. Nothing.
    I go back to The Prius. Open the glove box, carefully check again. No...Nothing.
    I actually start to wonder if someone would of possibly broke into my Prius and stolen just my paperwork?
    But that makes no logical sense. Why would they NOT steal more valuable items? Outside of potential identity theft, stealing a receipt and order for glasses- makes no sense.
    Finally I reach Occams Razor. I've ruled out every other possibility...well except one.
    I open and disconnect the glove box, as you would if replacing the cabin air filter. I still see nothing. But then, way in the back, down a vent like section...just the tip of piece of paper. I reach back and carefully pull out the long receipt and the paperwork, which evidently got sucked out of my glove box and behind to the venting.
    Well...just a warning. The Prius Glove Box can be evil and act with it's own agenda.
    If it's at all full, it can suck paper behind itself into an alternate and probably evil realm. Requiring retrieval by sticking your hand into darkness.
    I have since thrown out a few mint containers and some gum. As well as decided I didn't need a few gadgets I was carrying around with me. Thus making the glove compartment emptier and thus deeper...and so hopefully less likely to toss any papers I might file in this area behind it.
    Seems like a bit of a design flaw that it can happen at all.
    xliderider and jdcollins5 like this.
  2. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    what you think why it got sucked out?
    airflow from the fan or some negative pressure build up?
  3. The Electric Me
    9,083
    5,801
    I suspect 4 things.
    My glove box was too full.
    It angles back when you close it.
    I had the air conditioning blasting.
    It's Evil.
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    The lower box is open on top and indeed angles back when closed, providing an avenue of escape. But in your post you said your "top" box was moderately filled, so my assumption then was that this is the box where the receipt was placed. Maybe that was the reason you did not use the top box and instead placed it in the lower box. Wasn't clear. I was checking airflow differences and observing damper motion once with the lower box removed, car made READY, and the A/C on, and when switching between external vent and internal recirculate things can get a little "windy" right above the open lower glove box. Especially if the fan speed is up there.
  5. The Electric Me
    9,083
    5,801
    Sorry, I meant "lower box".- Just stupid.
    It was the lower box.
    AzWxGuy likes this.
  6. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    No worries. I wonder why there is this assumption that when a machine intelligence approaches sentience it will almost always be evil. The Hollywood effect?
  7. RaZa
    RaZa Member
    480
    93
    i find the upper box equally evil. just big enough to want to put stuff in there, but no real room to organize anything without it becoming a huge mess. so i installed a shelf in my upper box to at least help organize it a little. was thinking about adding dividers to the lower box, but since I don't use it much haven't gone through the trouble (yet)
  8. Mendel Leisk
    42,205
    I didn't realize I had an upper glove box, for at least the first couple of years. :oops:
  9. CR94
    CR94 Senior Member
    2,799
    1,231
    Northwestern S.C.
    What did you think the button just above the (lower) glove box release button was for?
  10. Mendel Leisk
    42,205
    Never noticed it, lol.
