Mysterious connector - driver door - UK version
Discussion in 'Gen 2 Prius Main Forum' started by Jerzy, Nov 8, 2023.
  1. Jerzy
    Jerzy New Member
    London
    ----UK----
    Prius 2006 T Spirit
    I purchased the car last Saturday and I've just realised that one connector sticks out of the door panel (see photos). - Driver Side. It's quite strange because all works.
    Does anyone knows what it might be?
    Thx
  2. PriusCamper
    PriusCamper Senior Member
    13,449
    5,430
    Pacific Northwest, USA
    Usually car dealerships or fleet managers install stuff like this for security, tracking or access purposes...
    52,822
    I wonder if they were running some aftermarket product. Any power?
  4. Jerzy
    Jerzy New Member
    London
    ----UK----
    Thx,.
  5. Tombukt2
    Tombukt2 Senior Member
    13,847
    2,515
    Durham NC
    That's in its own little piece of ductwork and everything that's made to look like it's part of the car It's not in the United States and if it wasn't your country it'll show up on the parts break down or what have you I never seen a plug in the door like that with that little piece of duct work over it or piece of plastic or whatever that is and it must go right through to all the business right there on the other side of that unitized construction depending upon what hand drive the car is.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    maybe it goes to the JBL speaker? likely someone worked on the car and made an error putting it back together.
    The more I think about it, the more I believe it does go to the speaker. If I remember correctly, the last time I had to replace one of the exterior door mirrors, I was able to do it by only partially removing the interior door panel, but it required disconnecting the speaker. Maybe they did the same job but forgot to reconnect the wires.
    #6 TMR-JWAP, Nov 8, 2023
    PriusCamper likes this.
  7. Jerzy
    Jerzy New Member
    London
    ----UK----
    I think this might be the case, but the speaker seams to work ( or appears to work) . I am waiting for a strap stopper. Once I've got it I will have to take off the panel so my mystery might get solved.
  8. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    it may even go to the mirror. Been a while since I swapped one. Does the mirror move normally?
    nvm. definitely the speaker connector. I have a speaker on the shelf still connected to a complete door harness.. Speaker part number is 86160-68010. Matches that plug
    #8 TMR-JWAP, Nov 8, 2023
  9. Jerzy
    Jerzy New Member
    London
    ----UK----
    it does. Just I don't know whether the demister works or not and I assume that they fold manually.
  10. Tombukt2
    13,847
    2,515
    Durham NC
    The demister is in the plug that works the complete mirror that goes to the door panel harness
  11. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    If I recall, the wiring for the pillar tweeter comes up from inside the door, no?
    Tombukt2 likes this.
  12. Jerzy
    Jerzy New Member
    London
    ----UK----
    I think I found the culprit.
    It looks like the bottom speaker.
    I need to investigate it further.
    thx
  13. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Are those your photos or some that you found on the net for comparison?
    #13 TMR-JWAP, Nov 10, 2023
  14. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Here's a photo of the small speaker, and its plug. The speaker looks weird because it's removed from the plastic housing.
  15. Tombukt2
    13,847
    2,515
    Durham NC
    My car has this JBL mid base driver in the same position with the same plastic ring and the plug I do believe I'm sitting in the car right now but can't see the driver.
