Mysterious Drop in Gas Mileage
Discussion in 'Prius v Fuel Economy' started by zzzzhu456, Apr 24, 2019.
  1. zzzzhu456
    zzzzhu456 New Member
    new york
    For the last two months there’s been a significant drop in my 2012 v’s gas mileage that I can’t explain. Since the weather warmed up at the end of June and for several thousand miles I’ve been averaging 46-48 mpg per tank in highway driving over the same route. I use eco mode and try to drive at speeds between 60-65 mph, modulating the peddle pressure to keep the HSI from exceeding two bars past the center mark.
  2. Air_Boss
    Air_Boss Senior Member
    4,245
    1,195
    New Yawk
    Any service or TSB work done on or to the car? Tire pressures, air filter and 12V battery condition checked?
    52,773
    what has it dropped to?
  4. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Could be a weak traction battery..................
  5. Ronald Doles
    Ronald Doles Active Member
    230
    280
    Columbus, OH
    2015 Prius v wagon
    What were the temperature changes? Our mileage drops when we have to run the air conditioning more.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I don't think he wants to talk to us anymore. :cry:
    Raytheeagle likes this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Might be napping based on their name:whistle:.
    jerrymildred likes this.
  8. Mechanics Daughter
    Mechanics Daughter Junior Member
    Redondo beach
    My 2017 Prius Prime has the A/c stuck ON.
    It won’t turn off when I push ‘off’ in the A/c screen.
    My driving scores have dropped from the 80’s+ range to 50’s. Then screen asks if I can charge traction batter with a/c on.
    Is it broken?
  9. bisco
    52,773
    sounds like it. try pressing the auto button
  10. jerrymildred
    11,517
    14,164
    Tampa, FL
    Is it still under warranty?
  11. mikefocke
    4,072
    1,857
    Sanford, NC
    On this site, there are separate sections for the various models and model years and the one you posted in is the v wagon section. You may get better answers if you ask this question in the Prime area of the forums. Not all Prius models are the same.
  12. Prius4Life!
    Prius4Life! New Member
    Dallas, TX
    Four Touring
    I have been experiencing the same issue for the last month or so in my 2012 Prius V. I just turned it in for a diagnostic at Pep Boys this last weekend after I started getting an intermittent misfire in the engine (codes P0300 & P0301). It turns out that I have water in two of the engine cylinders.
    My guess would be that a drop in mileage could very well be indicative of the beginnings of the need for an engine rebuild.
    Hope this helps!
