Mysterious misfire ONLY when low HV battery, but No DTC’s
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Baz2473, Jan 23, 2019.
  1. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    I would rather replace the plugs
  2. Baz2473
    Baz2473 Junior Member
    37
    16
    Kent. England.
    What, again? They’re only a week old...
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    If you're curious as to whether it's actually a misfire or not, Techstream should be able to give you a misfire count for each cylinder.
  4. tankyuong
    1,555
    661
    Central MO
    Try ngk
  5. Baz2473
    37
    16
    Kent. England.
    Thanks for the tip. I looked into it and Techstream is showing misfires on cylinder 2 in the “View Monitors (Misfire)” section but No problem misfire DTC codes ???
    Took the egr system off again for another clean up and noticed that the intake plenum for cylinder 2 is fairly oily! Whereas all the other 3 intake plenums seem fairly dry.
    Anyone come across this before? Does it sound like intake valve stem oil seals leaking?
    Tiff likes this.
  6. Tiff
    Tiff Junior Member
    86
    Crawley
    Baz
    Keep me posted pls. Im going through exactly the same thing. The only thing i have done is injectors. And spark plugs were genuine Toyota sc16hr11 which apparently replace sc20hr11 which i replaced 15,000 miles ago but im going to do again to rule out
    The engine feels like its gonna go bang internally when it does this and being intermittent is really mind boggling.
  7. Baz2473
    37
    16
    Kent. England.
    @Tiff Do you have Techstream?
    Tiff likes this.
  8. Tiff
    Tiff Junior Member
    86
    Crawley
    Yes
  9. Baz2473
    37
    16
    Kent. England.
    What is your EGR flow value result in the monitor values section?
    Also
    Have you tried the EGR test procedure with it? If so, What result do you get from the MAP sensor during the test?
  10. Baz2473
    37
    16
    Kent. England.
    I’ve established that every time I remove the entire egr system and the intake manifold then I get a good 1000 miles of trouble free driving before the problem comes back again. I’m trying to work out what part of this process is temporary fixing it? The complete egr system is clear of all blockages (so much so that I can breathe easily through the cooler) yet when the problem comes back if I remove it all and clean it again it still seems to fix it for a week or so (1000 miles). I’ve narrowed it down to either the MAP sensor or the EGR stepper motor. (I think) argghhh!
  11. Mendel Leisk
    41,457
    That sounds very interesting, a good reason to acquire Techstream. (y)
  12. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    You got an oil catch can installed?
  13. Baz2473
    37
    16
    Kent. England.
    Yep I sure do.
    Mendel Leisk and Raytheeagle like this.
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Is the coolant level stable?
    When is the last time the spark plugs have been changed?
    Have you cleaned the MAF sensor?
    What about the MAP sensor, have you cleaned that?
    When cleaning the intake manifold, is there still a puddle of spooge at the bottom?
    How much buildup is there after a thousand miles?
    Where is the catch can mounted?
  15. Mendel Leisk
    41,457
    ^ One noted anomaly. Dig into that more?
    Raytheeagle likes this.
  16. Baz2473
    37
    16
    Kent. England.
    Coolant stable.
    Spark plugs changed 3000 miles ago.
    MAF sensor untouched.
    MAP sensor wiped every time intake removed.
    Not really a puddle. Just a small smear.
    Hardly any buildup after 1000 miles.
    Mounted next to the inverted against the wing.
  17. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Good catch;).
    Any oil consumption @Baz2473 ?
    I wouldn’t wipe the MAP sensor, I would just spray it with cleaner until the oil layer has been reduced.
    How are the readings on Techstream? Anything out of the ordinary or look odd?
  18. Mendel Leisk
    41,457
    I sprayed (and gently Q-tip wiped what I could reach through the cage, though didn't do much to clean) the MAP sensor with CRC MAF sensor cleaner. MAP sensor seems quite durable, comparing to MAF. Has to be, swimming around in the bilge at the bottom of intake manifold.
  19. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I’m leery about touching sensors, particularly the wired ones ;).
    Had some bad experiences at work with some of my staff messing with sensors :cool:.
    Definitely gets your attention and changes your perspective (y).
  20. Tiff
    Tiff Junior Member
    86
    Crawley
    Interesing baz. How do i get into the egr flow bit on techstream and map sensor
